Old 07-03-2006, 02:49 PM   #1 (permalink)
mac55's Avatar
Default WTF! speedometer fluctuating!!!!!!!
going down the road all of the sudden the speedometer drops to zero then back to 55 or what ever speed i'm doing!!!!!
mac55 is offline   Reply With Quote
Old 07-03-2006, 08:09 PM   #2 (permalink)
The Tachometer operates off of your alternator and guages RPM via output.
Causes offluctuation could be:
1). Loose Connection. Clean and tighten on rear of alternator.
2). Loose or improperly routed Serpentine Belt. Check for tension and routing. A routing diagram is located on www.atlanticbritish.com under Tech Tips.
3). Failing Alternator. Check output, should be 14 I believe. The Tach acts as a sort of "canary in the mine" for the alternator.
This is based on the assumption that you have a Disco.
Others may have more to add, best of luck on a fix.
Dunerider is offline   Reply With Quote
Old 07-03-2006, 09:55 PM   #3 (permalink)
mac55's Avatar
Speedometer!!!!
Not Tach!!!!
Old 07-04-2006, 04:36 AM   #4 (permalink)
Sorry, that was stupid?? Too many firewaters.
Old 07-04-2006, 05:19 AM   #5 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Sounds like your VSS (Vehicle Speed Sensor) is going out. You can get one at Atlantic British for $99 plus shipping and it takes about 10 minutes to swap out. The greatest difficulty is getting to the two allen screws that mount it to the back of the transmission as it's wedged between the transfer case and the transmission. Easy fix though with the right tools
Hope this helps.
9dawgs
'99 Discovery I
'99 Chevy Astro 4X2 w/4" Lift (family truckster)
17' Basstracker w/40HP Mercury
11' Jon Boat w/numerous antique outboards
9dawgs is offline   Reply With Quote
Old 07-05-2006, 08:33 AM   #6 (permalink)
Elephantitis penisitis
I second what 9Dawgs is saying....VSS. Call Nathan at Discount Rovers for the best price. www.discountbritishparts.com If it's not on his site, just call him.
Old 07-05-2006, 11:53 AM   #7 (permalink)
mac55's Avatar
I found that in the under the hood fuse fox the battery terminal location wasn't connecting the buse bar to the fuse block just laying on top????????
go figure?
Old 07-05-2006, 08:38 PM   #8 (permalink)
Austin "Danger" Powers
FrankyRizzo's Avatar
Mine did the same and I got a complete cluster from roverguy.com for a great price.
94 Disco
Make something idiot proof and they will build a better idiot.
FrankyRizzo is offline   Reply With Quote
