Hi there
First you should know that I am not automobile-mechanically inclined - at all. I have a 1997 (sorta) Discovery. According to the VIN there was a change sometime in 1997 and my fuel system is "advanced evap" or something like that. Does that mean that the system is not compatible with previous models? Before I bought my beauty, the engine was replaced with a 1995. Possibly this may account for my problem, and even be a source of problems yet to come. Problem: When starting, sometimes it would not catch until third or fourth try. Gradually it took more and more tries. Now it catches for a nanosecond, then stops. Could this possibly be something simple like a clogged fuel filter? There does not seem to be any pressure in the fuel line. If I have to replace the fuel pump, can I use the pump from the 1995 vehicle (still available for parts)? Makes sense that it would be the right one for the 1995 engine. Also, is the present pump (1997) acting up because of having to work with the 1995 engine? I checked earlier forum questions: it is not the fuse, and pushing the fuel cutoff switch did not help. I want to download the correct workshop manual – but which one? Also: will sensors for both models be the same? I need an antilock one for sure. I bought (but have not yet used) an Innova OBD2 – 1003 Code Reader. It is supposed to work – will it? Any assistance would be greatly appreciated. I am in BC and not close to any major centres. I do have someone who will be doing the work but my job is to do the research. Also, money is very tight at the moment and a $750 new pump is not a comfortable expense at the moment. Thanks for reading. I am so looking forward to going out and using this great creation for what it was meant to do. Pamela |
#2 (permalink) | |||||||||
I only worry about myself, screw the others. |
| Thread Tools | |
| Display Modes | |
| Multiple cylinder misfire diagnosis help request | mark-ak | Discovery Series II | 27 | 04-10-2008 07:22 AM |
| Stock disco 1 with 235/85/16 pic request | bt93 | Wheels and Tires | 10 | 11-02-2007 08:25 AM |
| Picture Request | 01001010 | Defender | 8 | 07-09-2006 11:38 AM |
| Salary Raise Request | kellijo | The Lounge | 34 | 04-26-2006 01:10 PM |
| URGENT Series IIA Request | Jonesy | Series Land Rovers | 2 | 06-27-2005 06:58 AM |
