2005 Freelander - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
  • 1 Post By tyl604
post #1 of 8 (permalink) Old 02-18-2019, 06:44 PM Thread Starter
Haileyjade8491's Avatar
Quoted: 1 Post(s)
Throwing cylinder 1, 3, and 5 misfire codes, has ticking noise that almost sounds like an exhaust leak. Other codes include system to lean bank 1 and 2, O2 sensor bank 1 and 2, and misfire detected with low fuel. car will run fine at times and other times it will hano power on acceleration and compulsive shaking. While coasting on higher speeds the rpms will skyrocket while set on cruise. Shifting hard and at high rpms. Fuel pressure test was fine and fuel injectors tested fine. All new spark plugs and getting ready to replace coil packs. Spark resistance test showed extremely low, could this be an issue with the ecu? Plugged up Catalytic converter? I am completely dumbfounded by this...Anybody else have these similar issues? What was the outcome? I have a video of what noise it's making...only has 80,000 miles on it and did not start acting like this til I started it and drove it when it was -20 degree weather outside.
Haileyjade8491 is offline
post #2 of 8 (permalink) Old 02-20-2019, 06:25 AM
Quoted: 59 Post(s)
Originally Posted by Haileyjade8491 View Post
... and did not start acting like this til I started it and drove it when it was -20 degree weather outside.
Sorry - just to clarify. The car ran normal. Then, one day, you started it and drove it when it was -20 outside?
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #3 of 8 (permalink) Old 02-20-2019, 07:08 AM Thread Starter
Quoted: 1 Post(s)
That was the day all problems started. Could be coincidental.
post #4 of 8 (permalink) Old 02-20-2019, 07:35 AM
tyl604's Avatar
Quoted: 178 Post(s)
Is that -20 C or F? If F, does your antifreeze go that far down?
tyl604 is offline
post #5 of 8 (permalink) Old 02-20-2019, 06:05 PM Thread Starter
Quoted: 1 Post(s)
Farenheit and Idk why it wouldn't? Did 70/30 mix after we changed hoses and assembly.
post #6 of 8 (permalink) Old 02-20-2019, 06:52 PM
tyl604's Avatar
Quoted: 178 Post(s)
Just looked at a chart which said you need about 44% glycol to go down to -20F. I wondered if your coolant froze/got slushy and the vehicle overheated; ie. blown headgasket. But from the chart that should not have happened.
Assuming of course that you had 70% antifreeze and not 70% water.
tyl604 is offline
post #7 of 8 (permalink) Old 02-21-2019, 08:34 PM Thread Starter
Quoted: 1 Post(s)
Believe it's the coil packs, put old ones in and driving a little better. Returned the new ones and got new coming. Hope that fixes the problem.
post #8 of 8 (permalink) Old 02-22-2019, 04:35 AM
tyl604's Avatar
Quoted: 178 Post(s)
What brand were the new coil packs?
ThorInc likes this.
tyl604 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
2005 freelander coolant leak/engine replacement-warranty!?!? notfreelander05 Freelander / LR2 1 05-21-2011 04:24 PM
2005 Freelander Service Question cramposaurus Freelander / LR2 1 06-26-2010 12:21 PM
2005 freelander SE v6 vibration mehdik Freelander / LR2 0 02-03-2010 01:18 PM
2005 freelander vaduz01 Accessories 2 09-26-2006 07:48 AM
User buying advice on Freelander 2005 SE roathd Freelander / LR2 1 12-01-2004 07:22 AM
You may post new threads
You may post replies
