2008 Land Rover LR2 HSE - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 07-08-2017, 09:33 PM Thread Starter
Quoted: 0 Post(s)
Stalled in traffic a couple weeks ago while just casually driving and wouldn't restart. Tested battery and it was good, also replaced with a new battery and still, I get the same result, Everything works in terms of electronics other than the instrument lights, I have 0 instrument lights, however it won't start, doesn't crank, doesn't do anything, replaced starter a couple months back and no issues until now, checked fuses, found 1 fuse blown (F42) replaced with a new fuse and still nothing. Please!!!! any suggestions will be appreciated and won't go ignored! Need to get this vehicle going asap!
Forgot to mention when you insert the key fob, it'll suck it in, however will not eject it.
ret01022 is offline
post #2 of 6 (permalink) Old 07-09-2017, 01:26 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Check again that fuse 42 cos it's on the ECM's ignition feed circuit, the fact that it was blown means the problem is there somewhere cos that fuse doesnt blow for nothing, if it's good take a multimeter, identify pin 3 of C11L(attached) and measure for voltage on it with ignition on(use a needle if you can't reach the pin with the probe)... though this doesnt look like a DIY job if you are not electrician
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 6 (permalink) Old 07-09-2017, 05:29 PM Thread Starter
Quoted: 0 Post(s)
Fuse hasn't blown since being replaced, hopefully it'll be something as simple as a small short of some sort and I can repair after tracing it down and problem will be resolved (in a perfect world). Fixing to check corresponding pin you suggested for voltages and see what I get in return. Thanks for the fast reply as well, more help than I've had yet. On a side note, My obd2 scanner won't make a connection, so this perhaps is in correlation to this possible short.
ret01022 is offline
post #4 of 6 (permalink) Old 07-09-2017, 11:01 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Check fusible link FE17(60A) in the battery junction box
post #5 of 6 (permalink) Old 07-10-2017, 05:02 PM Thread Starter
Quoted: 0 Post(s)
What exactly am I looking for? a blown fuse? or a faulty connection?
Checked all the connections, but I see what your getting at. Voltages came back at 12.3 to 12.4 on all the 60A connections on backside of box. Please see pic, not my box, but I just wanted to make sure we are on the same page.
ret01022 is offline
post #6 of 6 (permalink) Old 07-10-2017, 10:58 PM
sierrafery's Avatar
Quoted: 246 Post(s)
I dont know if it's blown fuse or bad connection, that's what you'll have to find out and for that you have to get to that exact pin 3 on C11L cos the feed from F42 must get there and F42 is getting feed from FE17, as long as F42 was blown once it means there is a problem on that parth or in the worst case in the ECM, eventually make sure that F42 has feed on it but important is that pin 3 cos there's one end of that circuit which blew the fuse, also replace relay R7 cos it might have suffered when that short occured, i cropped the relevant part of the diagram, see the path from F42 to see what i mean as it goes to C11L - 3 and from there to ECM ignition input.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
2008 Land Rover LR2 - Clean and Well Maintained pvvega817 Land Rover Vehicles 0 09-28-2016 07:37 AM
2008 LR2 land rover $16000 eat my dust Land Rover Vehicles 0 09-19-2013 08:30 AM
Land rover LR2 front bumper 2008-2010 LR Tech SD Land Rover Parts and Accessories 0 11-09-2012 01:49 PM
FS: 2008 Land Rover LR2 HSE Kristo03 Land Rover Vehicles 4 04-05-2011 12:52 PM
2008 Land Rover LR2 HSE review torres Freelander / LR2 1 12-22-2007 03:08 AM
You may post new threads
You may post replies
