Blower Motor Resistor - 2008 LR2 HSE (Pics included) - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
  • 1 Post By dcarlso3
post #1 of 5 (permalink) Old 01-05-2016, 06:45 AM Thread Starter
Quoted: 0 Post(s)
Hello all,
I recently had the displeasure of my blower taking a dump on me this past week. After figuring out the issue being the blower motor resistor, I went right to replacing it. I finally found the thing (after reading diagrams related to a right hand drive version and getting totally confused). The only things in its way are the plastic trim that is easily removable, and the accelerator pedal for easier access. The problem I am having is actually removing the resistor itself. I am under the impression that the casing should (somewhat) easily turn to the left and come right out. Unfortunately, I have little room for leverage (see pics), perhaps an inch, maybe 2. There does not seem to be any play in the resistor at all. Has anyone performed this fix before? Any suggestions? I will post more pics if they can be helpful in any way once I figure out how to get this thing out. Any suggestions are VERY much appreciated!
Also, as you can see I tried to get a pliers to grip the housing and gain some leverage. They did not hold!
ID:	63185   Click image for larger version
logman is offline
post #2 of 5 (permalink) Old 09-11-2016, 03:10 PM
Quoted: 0 Post(s)
I would love someone to respond to this as well. Having the same issue, took off the passenger side fascia on a LHD to find nothing there... Can anyone post pics of this install/replacement? I would be happy to pay pal someone who did this...
mtier0067 is offline
post #3 of 5 (permalink) Old 09-11-2016, 03:26 PM
sierrafery's Avatar
Quoted: 246 Post(s)
The answer for you might be in the following document
http://www.d-lander.com/manuals/Freelander2_Manual.pdf (PLEASE NOTE : This is a very large PDF file. You will need Adobe Acrobat Reader to open it.)
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is online now
post #4 of 5 (permalink) Old 09-17-2017, 05:50 PM
Quoted: 0 Post(s)
Did either of you ever get it out? I have the same part in my 2007 Volvo S80. Removed the accelerator pedal and cut away some insulation, but still could not turn the existing control module counter clockwise even a little. I spent 20 minutes trying to devise a makeshift tool to get more leverage until I ran out of time and had to put the pedal back in and clean up.
dcarlso3 is offline
post #5 of 5 (permalink) Old 09-19-2017, 06:19 PM
Quoted: 0 Post(s)
Results
Day 2: After trying a second time from 2 different angles and using a large pair of vice grip pliers, the blower motor regulator came loose with just a very slight turn counter clockwise. In fact, the turn was so slight that I didn't at first realize it was loose. Once it was, I had to cut away a little more insulation to wiggle it out of the hole in the side of the blower/filter/housing assembly, then I had to wiggle it in 10 different directions to get it past the accelerator pedal bracket. Getting the new one in was another 2-3 minutes of wiggling it back and forth until it was clear I had it fully inserted into its place. Turning it back into a locking position was again a very slight movement and a very unsatisfying experience. I am still uncertain it is fully seated and secure, but I'm done pushing and pulling. Even the electrical connector failed to make a comforting "click" when it went back into position.
In my case, the blower worked at full speed when I bought the car second hand with 103,000 miles earlier this year. After a month of driving (and, oddly, within a few weeks of installing a new aftermarket cabin air filter), the blower would work at all speeds up to about 50%. Turning the knob past 50% resulted in no further increase in blower speed. Again, a few weeks later, it would only operate at speeds up to about 25%. And, finally, last week, it would operate intermittently, and only at what I perceived to be the lowest possible speed.
After putting the new regulator/blower motor control module in (some might still want to call it a resistor, but I can say after measuring the impedance across all 4 terminals of a good one and a bad one, it is not a resistor in the same sense as similar looking parts are), reconnecting the battery, and then reaching into the car to put it into key position II, and then waiting for a few seconds until the lights on the dash mostly went out, I was delighted to see that the blower motor was working normally again. The check engine light stayed lit until I started the car, which I did only after I was certain the airbag light was out, and nothing was whirring and whizzing inside the dashboard while the ridiculous number of modules were coming back to life.
The local dealer and a trusted independent shop I've used for more than 3 decades both wanted to replace the controller as well as the blower, itself, along with some of the wiring. I was told that there is a service bulletin for this because sometimes the wiring or connectors become corroded. While I'm not happy that the quotes for repairs started at more than $800, and involved parts that are probably don't need to be replaced (blower and wiring), I can understand that they don't have time to pull anyone's dash apart twice, so they will just follow their service bulletin and try to get it all working perfectly the first time.
I spent $54 with shipping to order a BEHR part from eEuroparts. At less than one third the cost of the dealer part, I was convinced it would be inferior. I was happy to see that the original equipment I pulled out of my car (dated September 2006) was also a BEHR part with exactly the same part number.
Unfortunately, I don't think there is any way to test the part out of the car. Resistance measured across the terminals of the "bad" part pulled from my 2007 S80 was identical to the values I measured on the new part. It is possible that my fiddling with the connections, and reconnecting the battery twice, with different sequences of key position/start/etc., is all that was needed. Obviously, I'm leaving the new part in there.
If you're wondering why I'm writing this in a land rover forum, there are so many common parts between the Volvo P3 cars like the S80 II and the Freelander/LR2, it's shocking. While I've found owners of Volvo p3 cars to be less than adventurous with their own maintenance and repairs (unlike owners of older volvos), it appears that owners of Land Rover vehicles are more active on forums, and more likely to dig in a try to learn about their vehicles.
I'm working my way through a list of problems with this car. I believe several of these problems are probably common to the Freelander/LR2. The worst problem, in my mind, is a pronounced noise/slight vibration in the front end that seems to occur once every 2 or 3 rotations of the axle/wheel. The noise lasts for about a quarter of a second, and definitely sounds like a rubbing and grinding noise (it is unpleasant). Sitting in the driver's seat (LHD), it sounds as if it is coming from the area of the left front wheel, but sitting in the passenger seat, it sounds like it is coming from the front right. The vibration is easily felt in the pedals, but also in the dead pedal area, and the steering wheel. The vibration might be what makes me and my passengers locate the noise at the wheel closest to us. 2 independent shops told me it was a wheel bearing. Like the LR2, the S80 uses a press-in bearing/hub assembly that costs hundreds to install properly , with the proper tools to ensure that the inner race isn't damaged by pressing on the spindle/bud face. Not interested in a $650 repair that probably wouldn't work, I ordered an aftermarket FAG bearing and a tool from ebay. I'm now very familiar with the control arm design on these cars. It was not easy to get the job done properly. Unforunately, the original bearing was absolutely fine, and the new bearing did not resolve anything. I'm now thinking the noise is actually coming from an inner CV joint of a locator bearing. I'm not sure that either of these things are bad. I'm going to assume that one or more of the engine/transmission mounts/pads have broken, leaving the inner CV joints open to too much movement. The left hand engine mount (and the torque rod) are identical to the LR2. The right hand engine mount appears to be slightly different between the 2 makes, but time will tell.
sierrafery likes this.
dcarlso3 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Considering a 2008 LR2 HSE... ADVICE? Majik357 Freelander / LR2 9 01-30-2015 08:31 AM
FS: 2008 Land Rover LR2 HSE Kristo03 Land Rover Vehicles 4 04-05-2011 12:52 PM
Locate the blower motor resistor 04 Disco JENEWKIR Discovery Series II 2 02-20-2009 06:34 AM
2008 Land Rover LR2 HSE review torres Freelander / LR2 1 12-22-2007 03:08 AM
New Heater Blower Motor Resistor KIRKSHIRE Range Rover Classic 0 11-11-2006 09:14 AM
You may post new threads
You may post replies
