A/C Recharge - service valve location? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 09-26-2013, 07:16 AM Thread Starter
Quoted: 0 Post(s)
I am trying to recharge the Freon in my 2008 LR2 but I am unable to locate the service valves / ports that are usually clearly visible on the lines from the compressor.
Thanks
2008LR2 in FL is offline
post #2 of 7 (permalink) Old 09-26-2013, 08:47 AM Thread Starter
Quoted: 0 Post(s)
Found!
I found the two A/C service ports. The HP is up near the fire wall, passenger side and the LP is inside the compartment just in front of windshield (above and behind HP), also passenger side.
post #3 of 7 (permalink) Old 09-26-2013, 11:23 AM
Quoted: 0 Post(s)
Not much support for the LR2 forum. Did you have any success with the recharge? I also have a 2008 LR2 which seems to take a while to get cool. Have you had any issues worth discussing with yours? I just purchased mine a few months back and wondering what to expect.
Justinv is offline
post #4 of 7 (permalink) Old 10-10-2013, 09:46 PM
Quoted: 0 Post(s)
Don't forget that the AC compressor is lubricated by oil in the AC system. When serviced by an AC engineer this will be extracted and replaced when the freon is recharged. AC compressor changes are expensive. An AC service costs less than £50 in the UK so well worth having done by a professional.
Bossbob is offline
post #5 of 7 (permalink) Old 10-09-2015, 11:23 PM
Quoted: 0 Post(s)
I think if you are having problems with your heating or cooling system, itís important to address these issues as soon as possible. Allowing a problem with your HVAC system to persist may only cause more widespread damage and increase the cost of operating the system. In many cases, if problems are not fixed within a timely manner, they ultimately cause permanent damage to the system that requires full replacement to restore normal function.So whenever need to replace or repair Air conditioning Heating and cooling system call air conditioning repair.
jimsmith is offline
post #6 of 7 (permalink) Old 10-09-2015, 11:29 PM
Quoted: 0 Post(s)
jimsmith is offline
post #7 of 7 (permalink) Old 06-23-2018, 09:52 AM
Quoted: 0 Post(s)
AC Recharge ports not labelled "High" or "Low"
This information is correct for the US model; the high side is just inside the 6 cylinder gas engine by the firewall, the low side is inside the compartment, both on the passenger side. Both are labelled "MAX 6 Nm", not "High" or "Low".
Note: to place the Recharge gauge on the low side port you will need to partially remove the plastic shroud with a phillips screwdriver.
villager7 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Oil pressure relief valve location hall.cullen Discovery Series II 17 08-05-2016 07:26 PM
2008 LR2 Valve Stem broke, does service kit include this? jbassman Freelander / LR2 1 11-20-2011 04:39 AM
Recharge AC DiscoDriver82 Discovery Series I 3 07-24-2010 08:14 PM
Location of Low Pressure Valve on R12 System TampaRRC Range Rover Classic 14 06-14-2010 12:02 PM
Location of Fuel Rail / Schraeder Valve adrianb Discovery Series II 0 08-30-2005 08:35 PM
You may post new threads
You may post replies
