climate control problems - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 01-21-2017, 12:18 PM Thread Starter
Quoted: 1 Post(s)
2011 LR2 HSE LUX with:
1) no electric heat from seats, Both fuses good
2) no blower output in any speed control position (blower verified good by jumping connections at blower resistor. comes on full blast)
3) no damper door actuation when selecting defrost, dash, or floor buttons.
Everything on dash looks good, all indicator lights come on when selected or pressed. A/C compressor kicks on when selected.
succesfully switches between manual and auto control. no indication of any problems whatsoever.
I thought blower resistor might be bad so I ordered new one and plugged in connector but still no blower output.
I used some spade lugs and 12 ga. wire to temporarily wire in a switch to turn blower on and off just to get some heat in the car.
This is when I found out there was no damper actuators responding to selector buttons and I cant control the temperature from the ducts
I thought the seat heaters were a coincidence but after the diagnostics i prerformed im convinced its all interrelated.
I didn't check every fuse but i dont think it is a fuse issue at this point.
the windshield electric defrost and hatch glass defrost seem to work as the engine idle drops from the increased alternator load.
Anyone have any ideas?
MikeG is offline
post #2 of 2 (permalink) Old 10-27-2018, 02:19 PM
Oaktown's Avatar
Quoted: 1 Post(s)
Did you ever figure this out? I have the same issue on my 2006 LR3. Climate controls light up and change but dont actually do anything unless you put the heated windscreen on and the voltage dips below 13 for a second. Then it will change the blend doors etc and will stop responding again once the voltage normalizes
Oaktown is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Radio and Climate Control Problems axwilson18 Range Rover P38, Mk III and Range Rover Sport 4 04-06-2017 07:48 AM
Climate Control - C to F lucaswhunter Discovery Series II 2 12-06-2010 05:27 PM
Climate Control discofacelift Discovery Series II 1 03-29-2009 05:40 PM
climate control ksk228 Range Rover P38, Mk III and Range Rover Sport 5 10-11-2006 07:21 AM
climate control scotth Discovery Series II 4 07-09-2005 04:36 AM
You may post new threads
You may post replies
