Engine won't start - Land Rover Forums : Land Rover and Range Rover Forum
 2Likes
  • 1 Post By Sajohnson
post #1 of 10 (permalink) Old 03-19-2019, 06:47 AM Thread Starter
Quoted: 3 Post(s)
Engine won't start
I have a 2010 LR2. This morning i went to start the car. Pushed the key in the ignition, stepped on the brake, pushed start. The engine started cranking then stopped. This has been happening occasional lately. I usually take the key out. Start the process over and the engine starts. Not this time. After pushing the key back in, stepped on the brake. The brake was stiff. I pushed the start button, no engine crank. The instrument lights come on but that's it.
I thought maybe it was the battery. I bought a new battery but same result.
Any suggestions on what to try? Look for?
Thanks
Peter
pvidulich is offline
post #2 of 10 (permalink) Old 03-22-2019, 02:07 PM
2008 LR2 SE
Quoted: 0 Post(s)
We had an alternator go bad and produce similar symptoms. Apparently it didn't cause any warning lights for some reason, it may have been making some voltage but enough to keep the battery charged for starting.
merlinj79 is offline
post #3 of 10 (permalink) Old 03-24-2019, 09:11 AM
Quoted: 0 Post(s)
Thanks
Peter
How many miles on the car? Sounds like a starter. Do you have a multimeter or access to one?
ThorInc likes this.
Sajohnson is offline
post #4 of 10 (permalink) Old 03-25-2019, 10:13 AM Thread Starter
Quoted: 3 Post(s)
I have 80,000 miles. No I don't have a multimeter.
post #5 of 10 (permalink) Old 03-25-2019, 10:54 AM
Quoted: 0 Post(s)
my starter went right around 100k miles. After inserting the key, I'd get lights on the radio, dash, etc... But when I pushed the start button the engine didn't even attempt to crank. I'd charge the battery (and even swapped in a new one) and they would almost immediately drain from trying to start it. Does this sound like yours?
post #6 of 10 (permalink) Old 03-25-2019, 10:58 AM Thread Starter
Quoted: 3 Post(s)
Yes, that sounds very similar.
How much did it cost to fix?
post #7 of 10 (permalink) Old 03-25-2019, 11:17 AM
tyl604's Avatar
Quoted: 183 Post(s)
You should wait until there are some more definitive comments about the problem before spending more money. Just throwing random parts at it is not the right approach. Sounds like you may have already replaced a battery when that was not the problem.
Also you might do a thorough search of this forum to see if this same problem has been resolved by another forum member.
tyl604 is offline
post #8 of 10 (permalink) Old 03-25-2019, 04:58 PM
Quoted: 0 Post(s)
It's a cheap and easy DIY... And that starter will go out sooner or later. AutoZone sells a remanufactured unit that is the OEM Bosch part. If I recall after the core charge, it ran me $150. I'd expect to pay $500+ if you had this done at the dealer (or more) and maybe $300 or so at an indy.
As the above suggested, it's worth testing first if you feel obligated. You can buy a cheap multimeter at your local parts shop or harbor freight and test it for yourself in a under 10 minutes (assuming you have some ramps or a jack/jack stand).
Post up here which method you decide to go and I'll try to help anyway I can. I believe I have photos from my install.
ThorInc likes this.
post #9 of 10 (permalink) Old 03-25-2019, 05:03 PM
tyl604's Avatar
Quoted: 183 Post(s)
Redtruck - are you out there? Need help here.
tyl604 is offline
post #10 of 10 (permalink) Old 03-25-2019, 07:44 PM
redtruck12's Avatar
Quoted: 283 Post(s)
Garage
I will agree with not just throwing parts at it until it’s fixed.
Yes a starter is a possibility but not the ONLY possibility.
If it is a push button system it could possibly be electrical/ communication issues.
I would recommend having it scanned for codes and/ or properly diagnosed.
Assuming if you don’t have a multimeter you probably don’t have a scan tool either??
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Help needed, 02 Freelander won't start, won't even crank over. Ken in Red Deer General Land Rover Discussion 1 09-16-2017 07:28 AM
Washed engine, now won't start. Ideas? tmai246 Range Rover Classic 9 04-17-2009 11:30 AM
Rover Won't Start After Turning Engine Off!!! Disco2Nole Discovery Series II 0 03-22-2009 11:15 AM
95 Disco deep puddle, wouldn't start, now really won't start littleg Discovery Series I 3 10-07-2008 08:08 PM
P38 Engine won't start after being powerwashed-Need Help! afox04 Range Rover P38, Mk III and Range Rover Sport 2 04-27-2008 07:44 PM
You may post new threads
You may post replies
