Power Steering whine - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
  • 1 Post By sierrafery
post #1 of 7 (permalink) Old 08-21-2017, 09:41 AM Thread Starter
Quoted: 0 Post(s)
My wife recently bought a 2012 LR2 from a Land Rover dealer with only 25k miles in excellent condition. Nice vehicle. I've noticed a faint whining noise whenever you turn the steering wheel in either direction. I've never experienced this in any other car - is this normal?
Sent from my SCH-I545 using Tapatalk
4corsa is offline
post #2 of 7 (permalink) Old 08-21-2017, 11:20 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Does it have a full service history? ... might worth a check: https://www.youtube.com/watch?v=mym-rC3IPhA , as you see it's not hard and it deffinitely won't hurt, old/worn oil can make the PAS noisy
4corsa likes this.
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 7 (permalink) Old 09-20-2017, 10:18 AM Thread Starter
Quoted: 0 Post(s)
A friend of mine said it might have steer-by-wire steering, and that might be making the noise. It does seem to be coming from the steering column (as opposed to the pump...)
4corsa is offline
post #4 of 7 (permalink) Old 07-04-2018, 01:47 PM
Quoted: 0 Post(s)
Power Steering Whine
My 2011 LR2 also developed a rather loud whine that gets a bit louder at full lock. I took it to the dealer and they found a small leak in the power steering pump. The suspected that the steering rack was also damaged. The repair estimate about around $3K. However, they suggested flushing the power steering fluid and monitoring the level. That make a huge difference. Perhaps you want to start with a power steering flush and fill.
Sassquatch is offline
post #5 of 7 (permalink) Old 07-05-2018, 10:42 PM
WLADiscoII99's Avatar
Quoted: 207 Post(s)
Drain the PS fluid out refill and drain with a turkey baster with the most expensive synthetic you can find until it's clean. Then add a bottle of Lucas PS.
When mine started in whine the mechanic told me I need a new PS pump and wanted $2,000 to fix. This was 40k miles ago. He said the flush might work for a little bit but was just delay and waste of money because "you're going to have to add new fluids when you change the PS anyways".
I've been doing this flush every 3-5k miles since with no noises and no new PS pump. The crook just wanted easy money. That's why their shop is out of business today.
WLADiscoII99 is offline
post #6 of 7 (permalink) Old 07-05-2018, 11:15 PM
sierrafery's Avatar
Quoted: 246 Post(s)
I'm using this https://www.ebay.com/itm/Power-Steer...-/362135131289 in all my vehicles... it really works as advertised provided the leak and whine are not exagerated
post #7 of 7 (permalink) Old 07-30-2018, 03:03 PM
tyl604's Avatar
Quoted: 178 Post(s)
All of this is interesting, but it just sounds like you are low on power steering fluid. Try the simplest fix first.
Directions just in case -
remove the top of the power steering unit
fill it to the line w ps fluid
start the engine and turn the steering wheel to full lock right and left several times
check the fluid level and top up if necessary
repeat until the level no longer drops
tyl604 is online now
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Question about steering box and power steering pump lukyrr Discovery Series I 4 08-15-2012 12:02 PM
Engine whine....Power steering? drewsky General Land Rover Discussion 4 07-23-2012 06:24 PM
Power Steering mjack135 General Land Rover Discussion 3 05-04-2012 03:29 AM
Power steering shelleyt Discovery Series II 2 05-15-2011 12:33 PM
power steering flush and steering box new rover girl Discovery Series II 1 10-01-2005 05:23 PM
You may post new threads
You may post replies
