Transfercase output shaft end play - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 09-25-2014, 01:21 PM Thread Starter
Quoted: 0 Post(s)
Just looked at my output shaft and found out that the seal was gone. now I am putting it together and try to get the end float of the shaft. I have 2 shims in there and have lots of play, now what do I have to do to reduce the play take shims out or put shims in between speedo housing and Transfer Case
1978 Series III / Mil
Alberta Big Horn is offline
post #2 of 2 (permalink) Old 04-07-2015, 10:42 PM
Bladesmith's Avatar
Quoted: 0 Post(s)
First remove all the shims. Lightly tap the outer bearing race inward untill you have no play in the shaft. Now bolt on the speedo housing without any shims. Do not tighten it yet as this will squeeze the bearing too tight causing resistance in the turning of the shaft. Just a good finger tight on the nuts. Now use a feeler gauge to measure the gap between the speedo housing and the transfer box (where the shims were). Remove the speedo housing and fit shims to the same measurement you got with the feeler gauge and bolt on the speedo housing tightening to the recommended torque.
Bladesmith is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Lightweight / Forward Control
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Help me find an Output Shaft Speed Sensor, PLEASE! MykD Discovery Series II 7 09-12-2014 09:48 AM
transfercase output shaft zero Discovery Series II 4 01-26-2014 05:55 AM
T-case output shaft seal woes parkerlander Discovery Series II 11 08-27-2012 08:33 AM
Transfer case output play 94svt50 Discovery Series II 6 04-07-2012 07:29 PM
New bolts in rear output shaft. Need to pull the Shaft?? Riflman Discovery Series II 0 11-08-2009 02:22 PM
You may post new threads
You may post replies
