Maximum height?? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 11-30-2017, 10:01 AM Thread Starter
Quoted: 3 Post(s)
Maximum height??
Hi guys, I found this sentence in a recent review: “Ground Clearance: Normal height: 210mm. Off-road 2 height: approx 250mm. Off-road 1 height: 284mm. Up to 70mm beyond 284 through Extended and Super Extended modes.”
This means that in case I need I can go up to 354mm ??
Thanks
Aviator is offline
post #2 of 5 (permalink) Old 12-01-2017, 04:06 PM
VW Dieselgate beneficiary
DieselRanger's Avatar
Quoted: 19 Post(s)
This means that in case I need I can go up to 354mm [IMG class=inlineimg]http://www.landroversonly.com/forums/images/LandRoversOnly2/smilies/tango_face_surprise.png[/IMG] ??
Thanks
You can select off-road heights 1 and 2 via the "up" suspension button. Off-road 1 is good up to 50mph. From off-road 1 you can select off-road 2 by pressing the console button again. That's good up to 31mph, and the suspension height will adjust automatically between them per the speed.
Extended mode is automatic only, and only activates when the vehicle gets grounded, you're driving in deep water, and/or it detects you're driving in narrow ruts. From Extended mode, press the brake and hold down the "up" suspension button for more than 3 seconds to activate Super Extended mode.
Yes, I do take it off-road.
2017 Discovery HSE Td6
DieselRanger is offline
post #3 of 5 (permalink) Old 12-07-2017, 11:01 PM Thread Starter
Quoted: 3 Post(s)
Hi DieselRanger, thank you for the information, now I understand.
It’s a little bit disappointing that it’s not possible to go in super extended mode manually, maybe if I know in advance that I’m going to tackle a very difficult passage I could prepare the suspension to its maximum height. But probably if JLR engineers decided this way means that it has to be like it is.
Leo
Aviator is offline
post #4 of 5 (permalink) Old 12-08-2017, 07:09 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 109 Post(s)
I'm sure there will be eventually. It just takes time to get the capability in our hands. I remember when the LR3's came out and we couldn't do anything with there suspension at first either.
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #5 of 5 (permalink) Old 12-12-2017, 11:41 AM
Quoted: 19 Post(s)
It?s a little bit disappointing that it?s not possible to go in super extended mode manually, maybe if I know in advance that I?m going to tackle a very difficult passage I could prepare the suspension to its maximum height. But probably if JLR engineers decided this way means that it has to be like it is.
Leo
I've read that people will "trick" the vehicle into extended mode by staging the jack or a tree stump or something similar under a jack point, then attempt to lower into access height. When the vehicle strikes the object, it will lift into Extended Mode. From there you access Super Extended as described.
Probably less damaging than grinding over a trail obstacle....
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Land Rover Discovery 5 forum
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
convert to 2wd maximum mpg highfructosecornsyrp Range Rover Classic 13 02-22-2013 08:44 AM
iPhone Maximum Contacts reefwalker General Land Rover Discussion 4 04-08-2010 07:36 AM
??Cant get brake fluid to maximum line????? Jahmusac Range Rover Classic 2 04-10-2008 08:51 PM
Maximum Build-Up SCSL Show it off 15 03-21-2006 11:05 PM
Maximum Tire Size Ex_MOD_110 Defender 8 02-01-2006 10:56 AM
You may post new threads
You may post replies
