Please Recommend Larger Tire Size for Disco 5 W/O Lifting - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 40 (permalink) Old 08-17-2017, 08:44 AM Thread Starter
Quoted: 2 Post(s)
Can everyone please recommend a larger tire size for my Discovery 5? It currently has 255/55R20 and I would like to get bigger AT tires but I cannot add a lift. Any recommendations on tires would be a bonus.
Thank you!
rsclark777 is offline
post #2 of 40 (permalink) Old 08-17-2017, 10:10 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 111 Post(s)
you might be able to get away with a 245/60-20 (31.6") or 275/55-20 (31.9")
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #3 of 40 (permalink) Old 08-18-2017, 05:52 AM
member
SafariDave's Avatar
Quoted: 141 Post(s)
With a lift you can go max 285 50 20
Dave
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my wife's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
post #4 of 40 (permalink) Old 08-18-2017, 09:00 AM
VW Dieselgate beneficiary
DieselRanger's Avatar
Quoted: 19 Post(s)
I plan to fit 275/55-20's to my vehicle. Lots of choices in that size. Here are the ones I would consider:
Continental TerrainContact A/T - aramid fiber armored
Goodyear Wrangler All-Terrain Adventure - Kevlar-armored, have run these offroad a lot and they are awesome
Hankook Dynapro AT-M
BFG All-Terrain T/A KO2 - these don't last all that long on heavy vehicles, but they're great off-road and they're three-peak mountain/snowflake rated, and they're supposedly not terrible all-seasons.
Nitto Terra Grappler G2
Nokian Rotiiva AT - new tire, but Nokian makes excellent winter tires.
Yes, I do take it off-road.
2017 Discovery HSE Td6
DieselRanger is offline
post #5 of 40 (permalink) Old 08-18-2017, 12:44 PM Thread Starter
Quoted: 2 Post(s)
SafariDave, are you meaning to say WITHOUT a lift that the maximum size would be 285/55/20? Do you have experience or knowledge that this is accurate or are you making any assumptions? Thank you.
post #6 of 40 (permalink) Old 08-18-2017, 01:05 PM
member
SafariDave's Avatar
Quoted: 141 Post(s)
I never said without a lift.
here you go!
http://www.landroversonly.com/forums...-tires-143249/
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #7 of 40 (permalink) Old 08-19-2017, 11:34 AM
Quoted: 19 Post(s)
OP was for largest tire without a lift.
post #8 of 40 (permalink) Old 11-26-2017, 12:38 PM
Quoted: 3 Post(s)
I’m sorry but I don’t understand why some of you says that to go 285/50R20 a lift is needed, from factory you can go 285/40R22 that has the same dimensions.
Aviator is offline
post #9 of 40 (permalink) Old 02-04-2018, 09:29 PM
ar077's Avatar
Quoted: 12 Post(s)
Thank you!
Do you have the Capability Package (i.e., with air suspension)? If so, the lowered setting might not have sufficient clearance for larger tires.
2017 Discovery HSE Td6, 5-Seat, Capability Package
2006 GMC Sierra 2500HD 6.6L Duramax Diesel 4x4
ar077 is offline
post #10 of 40 (permalink) Old 02-05-2018, 01:04 AM
sierrafery's Avatar
Quoted: 246 Post(s)
I'd strongly rercommend to not play with different dimension tyres than those recommended by the vehicle's manufacturer on any vehicle with such complex electronic managements... all those systems were calibrated from factory for standard dimension tyres and exceeding that will mix up the whole management and nothing will work 100% OK anymore, you might gain ONLY few inches of ground clearance and ruin other more important capabilities of the vehicle which will be just a bit taller but less responsive ... that's a fact
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #11 of 40 (permalink) Old 02-05-2018, 04:47 AM
ar077's Avatar
Quoted: 12 Post(s)
If that were true then there would be appropriate warnings in the Land Rover owners manual, and Land Rover dealers in America wouldn't be routinely performing suspension lifts and installing larger tyres. Is it possible that Land Rover computers can be reprogrammed to accommodate vehicle configuration changes, as is the case with other vehicles sold here?
ar077 is offline
post #12 of 40 (permalink) Old 02-05-2018, 04:50 AM
ar077's Avatar
Quoted: 12 Post(s)
Nice avatar!
ar077 is offline
post #13 of 40 (permalink) Old 02-05-2018, 06:32 AM
sierrafery's Avatar
Quoted: 246 Post(s)
It is true and tested live, the breaking distance, consumption and EGT level is increased with a similar percentage like the differnece in the tyre's dimensions while the TC and other dynamic systems are less responsive, engine temps are rising as well
if you read the whole workshop(not only owner's) manual and you'll understand how the managements are working you'll find more warnings about messing with tyre dimensions even with pressures
For me the fact that owners have fitted larger tyres and nothing bad happened SO FAR it's not an evidence that it's OK
about LR dealers who are fitting lift kits and larger tyres i can't comment....
as about owner's handbook, maybe you didnt read it carefully, IMO there are appropriate warnings, here is from the D4 one cos that's what i had saved but i checked and for D3 is exactly the same(copy/paste) warning, the only difference is the 8.5J tyres which are only for D4 (the red line is made by me)
Name:	D3-4 Wheels+Tyres.jpg
post #14 of 40 (permalink) Old 02-05-2018, 04:56 PM
ar077's Avatar
Quoted: 12 Post(s)
The new Discovery with the capability package is more off-road capable than any other land Rover or Range Rover sold in America, but the stock tires are not optimum for off road excursions. The increased capability that comes with more off-road suitable tires is worth the small sacrifice in fuel economy. The other adverse effects you cite are so insignificant as to not even be noticeable. If I'd wanted an everyday SUV for on-road use only, I could have gotten one for less than half the price of the Discovery.
ar077 is offline
post #15 of 40 (permalink) Old 02-05-2018, 07:13 PM
ArmyRover's Avatar
Quoted: 111 Post(s)
Someone better warn Land Rover the Discovery 5 SVX is coming from the factory with nearly 32" tires.
Lifting a D5 and putting some slightly larger tires isn't that big of a deal. Ford Explorers have no issue with it
1972 MGB
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Land Rover Discovery 5 forum
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Lifting/Tire Size advice. Newbie. Bason LR Discovery Series II 18 12-12-2011 03:54 PM
RRC spare tire; will a larger size fit? brider Range Rover Classic 9 05-05-2010 11:31 AM
does a larger tire (285/60r18) fit on the spare tire carrier? lipadj46 Discovery Series II 2 02-09-2010 01:50 PM
Disco II Spare Tire Mount (larger tire) xtreme90 Discovery Series II 0 12-12-2004 10:22 AM
Largest tire size for a Disco I? Beauregard Wheels and Tires 2 08-29-2004 04:52 AM
You may post new threads
You may post replies
