Wow............. - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 03-04-2019, 06:18 AM Thread Starter
Quoted: 0 Post(s)
Cool Wow.............
1 year ago, I bought New Discovery 5. Now it is 15,800 miles and went to service for Oil change.
Service consultant asked me to change rear brake pad and rotor and it cost more than 1,000 dollars.
Does it make sense?
This means every 15,000 miles I have to pay more that 1000 dollars to change brake pad and rotor.
Does it make sense?
YEKIM1015 is offline
post #2 of 7 (permalink) Old 03-04-2019, 06:33 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 111 Post(s)
Seems awfully early but driving styles and traffic varies. Have you looked at the pads and rotors to see if they are needing replacement?
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #3 of 7 (permalink) Old 03-04-2019, 06:52 AM
tyl604's Avatar
Quoted: 191 Post(s)
At 16K miles it seems way too early to need new rotors unless they were warped. You should learn to change the brake pads yourself; very easy. I would have asked for the specs on the rotors; if they were still in spec, I would not have changed them out. And no, you should not have this expense every 16K miles. Suggest you look around for another mechanic unless this would void your warranty.
By the way, your rear pads should last much longer than the front so I have no idea what happened. I have had my '99 DII for over fifteen years and have not changed the rears more than once or twice that I remember.
tyl604 is offline
post #4 of 7 (permalink) Old 03-04-2019, 06:54 AM Thread Starter
Quoted: 0 Post(s)
No, I don't.
I leased Lexus GX460 before this car and I did not change pads and rotors till I return at 30,000 miles.
post #5 of 7 (permalink) Old 03-15-2019, 09:37 AM
VW Dieselgate beneficiary
DieselRanger's Avatar
Quoted: 19 Post(s)
I have over 20,000 mi on mine and my brakes are still practically new. And I drive regularly in the Rockies, though I'll say I have the 3.0L diesel and I downshift on long downhills.
If an amber warning light was not on, then your brakes were not worn. The D5 has wear sensors that will trip as the pads wear down through the sensors and break a connection.
My 2010 Touareg 3.0 TDI got 77,000 miles out of the OEM pads - and that was when the sensors tripped and indicated the pads needed to be changed.
Yes, I do take it off-road.
2017 Discovery HSE Td6
DieselRanger is offline
post #6 of 7 (permalink) Old 08-12-2019, 01:27 PM
Duff
Quoted: 0 Post(s)
You will find the service department will tell you the brakes pads need changed with 4 mm of pad remaining. They will also change the rotors with every pad change. It is possible that if you have a piston sticking or a pad sticking you do need new pads. You only have sensors on the rear right and front left wheel. They are on the piston side pad and will not touch the rotor until about 1.5 mm of pad is left. If you are inclined and have the equipment to remove the wheel you can check the pads yourself. If not find a good independent and have them check the brakes. I got an extra 10 k miles after the dealer told me the rear brakes need changed on my 2015 LR4. I changed them myself for less than $150. Not a difficult job they have videos on how to do it at Atlantic British website for the LR3 and LR4. Should be about the same for your Disco 5. The also have them for the RR Sport if yours are that type.
howrdduff is offline
post #7 of 7 (permalink) Old 08-12-2019, 03:15 PM
WLADiscoII99's Avatar
Quoted: 238 Post(s)
Brakes are a serious issue but you have to understand beforehand that 9/10 mechanics just want your money.
They told me I needed new rotors thinking I knew nothing and there was barely a lip on the rotor. I drove another 30,000 miles before changing and did not even need it.
They just want your money.
1999 LR DII Performance Package with various Mods
Valentine One
Passport 9500ix
6 x Anti-Theft Camera System
2 x Anti-Theft Tracking devices
Veil Laser Paint
Anti-Laser Police Laser Jammer (5 heads + Dragon Eye protection) + Parking Sensors
Police Scanner + Waze
Powerful Pro-tuned CB-Radio with Fire-Stik
Remote+Hardwired License Plate Concealer
Armormax Bullet Proof Glass
Armormax Caltrop Deployment System
Steel Undercarriage Guards (Steering, Diff axles, Gas tank)
Voyager Roof Rack+six Jerrycans and five stacked Rotopax
Maxxis Razr Offroad Tires+Lift+LED bar
Allisport UK Aluminum Radiator
Allisport UK aluminum coolant tank with sight glass and coolant level sensor
WLADiscoII99 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Land Rover Discovery 5 forum
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Wow! This blew my mind. Disco The Lounge 13 10-17-2006 07:58 PM
Wow TsiArt The Lounge 7 12-06-2005 08:59 AM
WOW.....Anybody need a truckload of parts? DallasRover Land Rover Parts and Accessories 1 09-18-2005 11:02 AM
Wow, Look Here!!... 01001010 Accessories 6 07-21-2005 03:45 AM
Wow Wow Wow LRR219 The Lounge 7 06-21-2005 10:03 PM
You may post new threads
You may post replies
