FS: '91 RRC Hunter Edition - 1 of 405 made - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 09-13-2018, 05:16 AM Thread Starter
signalMTB's Avatar
Quoted: 3 Post(s)
For sale on Second Daily Auctions, bidding currently at $7500
https://seconddaily.com/1991-range-r...unter-edition/
Year: 1991
Make: Land Rover
Model: Range Rover Classic Hunter Edition
Mileage: 186k miles
Engine: 3.9L EFI V8
Transmission: 4-speed auto
Drivetrain: 4WD
Ext. Color: Eastnor Green
Int. Color: Brown cloth
Key Features: rare NAS Hunter edition, lots of recent maintenance, great driver quality
One of the 405 Hunters sold. It is finished in Eastnor Green over the Brogue Brown cloth manual adjusting seats. Power comes from the standard 3.9L fuel injected V8 mated to a 4-speed automatic transmission. It wears the proper tri-spoke 16″ wheels and appears to be in all-original condition with 186k miles ticked away since new…that’s 6900 miles per year if you’re doing mental math. The seller reports the frame to be in excellent condition, with only a few small rust spots on the floor and lift gate and a prior repair was made to the driver side floor pan. The seller has included over 100 high-resolution photos and a long list of items replaced over his 3 years of ownership. The seller, being one of those enthusiasts, has done an excellent job providing pictures throughout and very detailed written descriptions of his observations. Rather than view them as problem areas, respect them as an honest representation from someone who knows these trucks and has full disclosure of the items listed.
This one ships from Pennsylvania with a clean clear title. Second Daily will cover up to $200 of the cost of a pre-purchase inspection (PPI) if you order one and then go on to purchase the car. So bid with confidence knowing we’ve got you covered. You must make arrangements prior to auction close and successfully win the auction to receive the $200 credit.
The Eastnor Green paint is believed to be all original and looks to be great overall shape. It retains its factory badging and lettering, and the clear coat shows no signs of pulling away. The pictures show a few bumps and scratches this Classic has endured over the past 27 years, nothing of any unusual note or concern. The right rear panel has a scratch. The rear D-pillar vinyl has some small tears. The lift gate looks to be in good shape. A tell-tale sign of goodness is all 4 mudflaps are still intact. Might seem silly, but Rover enthusiasts know what this means. The sellers notes the driver side front floor seam had a rust repair, minor rust present at passenger side front floor seam, driver and passenger side rear floor and rocker, and minor rust present at the lift gate. All exterior lights, indicators, and horn function correctly. New tires were recently added, as was a 1″ Old Man Emu coil spring lift.
The interior is very clean and seemingly all original. The brown cloth interior shows well for its age, and the headliner and wood trim were recently replaced. The dashboard, gauge cluster, and center console are all complete and intact. The upper right dash has a crack in the plastic. Heat blows well while the wipers, lights, signals, and gauges all work exactly as they should. The seller upgraded the heat system with an Atlantic British blower motor kit, resistor pack, heater core, and changed out all pipes. The stereo is not installed, but a factory unit with code is available. Seller reports the cruise control and rear defroster are inoperable, the A/C belt will squeal on occasion. The OEM bottle jack is still present. There are no reported illuminated dash warning lights, no squeaks, rattles or other annoying noises says the seller.
The seller reports the tailpipe will need to be replaced, the steering box has the typical Rover leaks, as do the swivel balls and some minor engine oil leaks. The washer fluid reservoir also has a small leak. The following maintenance report was provided by the seller:
Spring of 2016:
Drained and replaced transmission, transfer case, differential, and swivel ball oils.
Replaced front axle CV joints
Replaced rear differential pinion seal
Replaced water pump
Performed general tune-up:
Replaced spark plugs, wires, and coil
Replaced all belts
Replaced windshield
Summer/ Fall of 2016:
Replaced all suspension bushings with OEM rubber
Replaced all shocks
Installed OME 1” coil springs
Replaced all steering ball joints
Replaced power steering hoses
Installed oversized tires
Spring/ Summer 2017:
Replaced all prop shaft u-joints
Replaced all wheel bearings and seals
Refreshed brake system
Replaced all rotors, pads, and calipers
Drained and replaced brake fluid
Fall 2017:
Upgraded heating system
Installed Atlantic British heater motor kit, resistor pack, heater core, and all pipes
Spring/ Summer 2018:
Repaired A/C system
Replaced drier; evacuated and charged system
System had previously been converted to R134
Replaced interior wood trim
Recovered headliner
Oil changes at 3k mile intervals. 15w40 in summer, 10w30 in winter.
Swivel balls topped off at oil changes. 80w90.
Power steering topped off at refuel. App. 8oz every 300 miles
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (1).jpg
ID:	86379   Click image for larger version
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (5).jpg
ID:	86381   Click image for larger version
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (7).jpg
ID:	86383   Click image for larger version
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (9).jpg
ID:	86385   Click image for larger version
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (12.jpg
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (18.jpg
ID:	86389   Click image for larger version
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (27.jpg
ID:	86391   Click image for larger version
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (42.jpg
ID:	86393   Click image for larger version
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (47.jpg
ID:	86395   Click image for larger version
Name:	1991 Range Rover Classic Hunter edition for sale second daily classics auction bringatrailer (11.jpg
1995 RRC 25th Anniversary Edition
2005 RR L322 HSE
2005 V70R
1995 Nuke Proof Titanium Race
2010 Moots X-YBB
signalMTB is offline
post #2 of 4 (permalink) Old 09-19-2018, 06:16 AM Thread Starter
signalMTB's Avatar
Quoted: 3 Post(s)
Closes tonight, reserve has been met. Current price at $8600
2005 RR L322 HSE
2005 V70R
2010 Moots X-YBB
post #3 of 4 (permalink) Old 09-24-2018, 05:14 AM Thread Starter
signalMTB's Avatar
Quoted: 3 Post(s)
Relisted due to non-paying winning bidder
2005 RR L322 HSE
2005 V70R
2010 Moots X-YBB
post #4 of 4 (permalink) Old 09-28-2018, 07:01 AM Thread Starter
signalMTB's Avatar
Quoted: 3 Post(s)
And sold again
2005 RR L322 HSE
2005 V70R
2010 Moots X-YBB
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only Classifieds > Land Rover Vehicles
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Wtb: RRC Hunter edition abrooks Land Rover Parts and Vehicles Wanted 0 01-18-2015 10:08 AM
Newbe 91 RRC Hunter Sacramento, CA. jimmyk New Member Introductions 1 02-10-2010 04:11 PM
91 Hunter Edition rover tech Land Rover Vehicles 7 11-01-2009 07:45 PM
£405.37 For A Mirror?? LRMATT Discovery 3 / LR3 0 06-23-2008 12:13 PM
FS: 91 RRC - Hunter edition Karst Rover Land Rover Vehicles 1 05-21-2007 03:48 AM
You may post new threads
You may post replies
