Land Rover Forums : Land Rover and Range Rover Forum
Land Rover Forums : Land Rover and Range Rover Forum (https://www.landroversonly.com/forums/)
-   General Land Rover Discussion (https://www.landroversonly.com/forums/f2/)
-   -   1999 D2 Lift Kit (https://www.landroversonly.com/forums/f2/1999-d2-lift-kit-155269/)
scottz 04-24-2019 03:01 PM
1999 D2 Lift Kit
Recommendations for best all around 3” Lift Kit for the money. Thanks!!
sierrafery 04-24-2019 03:49 PM
I recommend you to forget about bastardising a well enhanced vehicle... lifting it will give you only some extra ground clearance nothing else while you'll loose factory set enhancements... i rest my case.
p76rangie 04-25-2019 06:39 AM
People do not put in 3 inch lifts to go off-road, it is solely for looks. So ground clearance, etc is not really a factor.
redtruck12 04-25-2019 08:46 AM
3” gets you into driveline angle issues as well as suspension alignment issues.
Not likely something you would want to get into unless you are building a severe off-road machine
JUKE179r 04-26-2019 02:53 AM
Like others mentioned a 3" lift will lead to other areas (suspension, steering, brakes) that will need to be upgraded costing more money.
But it's your Disco so check out Terrafirma, Old Man Emu, Fox or Bilstein lift kits.
Some people sh*t on Terrafirma but I've had no problems with my +2" setup.
masantschi 04-26-2019 08:29 AM
Like Juke, I'm a Terrafirma fan too - as in I'm currently using them and like them! :)
redtruck12 04-26-2019 11:13 AM
I have had good luck with Terrafirma as well.
3 years on my current setup-no issues
texanintexas 05-01-2019 04:19 PM
My Disco has had a 2" lift on it for over 15 years now. Aside from the adjustment to the speedometer, there's nothing else effected that has shown itself in the last 15 years and the benefits of clearance far outway any desire to keep it original with respect to OEM.
While I completely respect ones wishes to keep a truck in original condition, there are many good reasons to modify the clearance of a truck. I spent many years in MA, Maine and New Hampshire having to get in and out of nearly impassable locations for IT work I did back then, and there is not a chance in hell I would have been successful without the additional clearance, larger tires and a winch.
I would point out as many just did that at 3" if you are going with suspension only and not a combination of body lift and suspension you might run into some steering and driveshaft change/adjustments. (Again a massive amount of opinions on the subject)
Depending on your needs you might want to consider a cheap spring lift at 2" that will cost about $20.00 and your labor and see if you're happy with that before you go making an investment into a 3" lift.
You can go to a salvage yard (Or contact Paul Grant) pull the rear springs out of like year model, install them in place of your front springs, which give you a 2" lift in the front and then buy hockey puck 2" spring lifts for the rear on eBay for around $!0.00 install them and you're all set at 2". ( I went this route, except used solid steel 2" square stock and drilled out the mounting bolt holes. The eBay spacers are inexpensive and a lot less work)
I run 265.75.16 snow tires with that 2" setup and have never had a problem and have been very happy with the overall performance. By that I mean to say there were no adverse effects in any way to the drivability or the enhancements of the vehicle than before I did the lift.
You should also do a thread search (Before you post a question :)) and you will find many postings with many opinions on the different options available.
Your posting really is not telling enough as to why the 3" lift size and that will also make a difference in the recommendations you get. So maybe a little more about why a 3" lift would help.
Some search parameters that will help are:
Terra Firma lifts
Lucky8
Body Lift
OME
I was on this one today that might be helpful as well:
https://landroverforums.com/forum/di...ma-lift-32464/
Luck,
Tex
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
