1999 D2 Lift Kit - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 04-24-2019, 03:01 PM Thread Starter
Quoted: 0 Post(s)
1999 D2 Lift Kit
Recommendations for best all around 3” Lift Kit for the money. Thanks!!
scottz is offline
post #2 of 8 (permalink) Old 04-24-2019, 03:49 PM
sierrafery's Avatar
Quoted: 246 Post(s)
I recommend you to forget about bastardising a well enhanced vehicle... lifting it will give you only some extra ground clearance nothing else while you'll loose factory set enhancements... i rest my case.
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 8 (permalink) Old 04-25-2019, 06:39 AM
p76rangie's Avatar
Quoted: 384 Post(s)
People do not put in 3 inch lifts to go off-road, it is solely for looks. So ground clearance, etc is not really a factor.
p76rangie is offline
post #4 of 8 (permalink) Old 04-25-2019, 08:46 AM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
3” gets you into driveline angle issues as well as suspension alignment issues.
Not likely something you would want to get into unless you are building a severe off-road machine
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #5 of 8 (permalink) Old 04-26-2019, 02:53 AM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 9 Post(s)
Like others mentioned a 3" lift will lead to other areas (suspension, steering, brakes) that will need to be upgraded costing more money.
But it's your Disco so check out Terrafirma, Old Man Emu, Fox or Bilstein lift kits.
Some people sh*t on Terrafirma but I've had no problems with my +2" setup.
MIKE
- 2001 Discovery 2 SE (NAS LHD) “MYRTLE”, 110K miles, 4.0L V8, NGK Iridium IX plugs, PCV mod, 180* T-stat, Hayden fan clutch/Dorman fan, removed TBH, SAI modded K&N filter, Safari Gard steel guards, Warn XD9000i winch, KO2 265/75R16 on steel rims, EBC rotors/Akebono pads, +2” TF lift & LEDs
- UltraGauge Blue, Foxwell NT510, Nanocom D2 V8 & TD5
JUKE179r is offline
post #6 of 8 (permalink) Old 04-26-2019, 08:29 AM
Quoted: 59 Post(s)
Like Juke, I'm a Terrafirma fan too - as in I'm currently using them and like them!
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #7 of 8 (permalink) Old 04-26-2019, 11:13 AM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
I have had good luck with Terrafirma as well.
3 years on my current setup-no issues
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #8 of 8 (permalink) Old 05-01-2019, 04:19 PM
texanintexas's Avatar
Quoted: 1 Post(s)
My Disco has had a 2" lift on it for over 15 years now. Aside from the adjustment to the speedometer, there's nothing else effected that has shown itself in the last 15 years and the benefits of clearance far outway any desire to keep it original with respect to OEM.
While I completely respect ones wishes to keep a truck in original condition, there are many good reasons to modify the clearance of a truck. I spent many years in MA, Maine and New Hampshire having to get in and out of nearly impassable locations for IT work I did back then, and there is not a chance in hell I would have been successful without the additional clearance, larger tires and a winch.
I would point out as many just did that at 3" if you are going with suspension only and not a combination of body lift and suspension you might run into some steering and driveshaft change/adjustments. (Again a massive amount of opinions on the subject)
Depending on your needs you might want to consider a cheap spring lift at 2" that will cost about $20.00 and your labor and see if you're happy with that before you go making an investment into a 3" lift.
You can go to a salvage yard (Or contact Paul Grant) pull the rear springs out of like year model, install them in place of your front springs, which give you a 2" lift in the front and then buy hockey puck 2" spring lifts for the rear on eBay for around $!0.00 install them and you're all set at 2". ( I went this route, except used solid steel 2" square stock and drilled out the mounting bolt holes. The eBay spacers are inexpensive and a lot less work)
I run 265.75.16 snow tires with that 2" setup and have never had a problem and have been very happy with the overall performance. By that I mean to say there were no adverse effects in any way to the drivability or the enhancements of the vehicle than before I did the lift.
You should also do a thread search (Before you post a question ) and you will find many postings with many opinions on the different options available.
Your posting really is not telling enough as to why the 3" lift size and that will also make a difference in the recommendations you get. So maybe a little more about why a 3" lift would help.
Some search parameters that will help are:
Terra Firma lifts
Lucky8
Body Lift
OME
I was on this one today that might be helpful as well:
https://landroverforums.com/forum/di...ma-lift-32464/
Luck,
Tex
1995 Discovery 1
245k original miles
2" Lift..... 265/75/16 Tires.....Modified headliner....Bumper supported rear gate for water & gas jerry cans/spare tire/chain saw....Inverted/extended roof rack....8000 pound custom installed Harbor Freight winch w/ interior and exterior remote controls....top front mounted twin HID lights....Halogen side and rear lights....Hood mounted spare tire.....Front and rear cameras
texanintexas is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > General Land Rover Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
D2 OME lift kit Rover Disco 2 ATS Land Rover Parts and Accessories 3 05-17-2013 11:48 AM
toddco 2" lift kit and homemade 2" kit ItsNotAJeepThing Land Rover Parts and Accessories 5 04-12-2011 12:00 PM
Lift Kit Question, D2 disco2orlando Discovery Series II 5 03-31-2010 12:27 PM
DAP's D2 lift kit-available yet? racerwad Accessories 5 02-09-2006 06:04 AM
towing, 4lt V8 (1999)v td5 (1999-2004) tonytee Discovery Series II 5 04-03-2005 03:18 PM
You may post new threads
You may post replies
