I swear Honey the Defender 110 followed me home :D - Page 4 - Land Rover Forums : Land Rover and Range Rover Forum
post #46 of 50 (permalink) Old 12-31-2013, 09:36 AM Thread Starter
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 106 Post(s)
Finished up the basis for my tablet mount, need to do a bit of finishing work to make it look a bit more presentable but it's functional for now.
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #47 of 50 (permalink) Old 12-31-2013, 01:31 PM Thread Starter
ArmyRover's Avatar
Quoted: 106 Post(s)
I went back out in the snow and sound deadend my driver and passenger door. Put the door panel back on and then installed a new switch plate cover so my dome light switch doesn't dangle from the wires anymore. You can also see the fog light switch that I mounted where the choke cable used to go.
1972 MGB
post #48 of 50 (permalink) Old 01-11-2014, 04:55 PM Thread Starter
ArmyRover's Avatar
Quoted: 106 Post(s)
Ok so the updates as of late have been slow since it got to cold in Chicago to go outside let alone work out there.
The second day of the cold snap I had a intake manifold gasket fail and I had to fix that. PTSchram described it as to much crank case pressure. I think it flooded gas into the oil and fumes ignited
So while I was at it I replaced a few coolant hoses, thermostat and gasket as well.
Turned out the battery was shorting internally as well so a new interstate battery went in today as well. Luckily the old one was still under warranty so it was free to replace
Finally I put my rear spacers on and did a oil change. I'll take some better pics of the after with the spacers on tomorrow in the daylight.
1972 MGB
post #49 of 50 (permalink) Old 02-23-2014, 09:46 AM Thread Starter
ArmyRover's Avatar
Quoted: 106 Post(s)
Got the over head TerraFirma console and a stereo installed and wired.
Well when it rains it pours. Along with the water pump it looks like the front diff is in the process of eating itself. Over the last 2 days I had noticed a vibe and a rumbling coming from the front of the 110. So of course I figured it was U-joints got under there and looked and they are solid. I noticed there was a lot of slop on the front diff when turning the shaft by hand. So I pulled the drain plug and out poured a really metallic version of diff lube. So I'm going to be pulling a spare front diff out of the old RRC parts truck and swapping it in.
Need to get the water pump ordered. I was also debating a new fan and clutch but I think instead I'm going to install a thermostat controlled electric fan along with a manual over ride.
1972 MGB
post #50 of 50 (permalink) Old 10-12-2017, 05:09 AM
Quoted: 0 Post(s)
That is good to know! I am sure you made the right choice here!
Also, for some reason, I am unable to see any of the pictures you have shared here! Please do share a link to them as I would love to see your mean machine!
jakebarrell is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > General Land Rover Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
My Defender 110 wrap Gride110 Defender 1 10-29-2010 09:03 AM
Defender 110 Duncan Defender 13 03-02-2008 12:09 PM
You may post new threads
You may post replies
