96 D1 V8 to 300 Tdi - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 03-18-2012, 09:11 PM Thread Starter
Quoted: 0 Post(s)
96 D1 V8 to 300 Tdi
I started this conversion about 3 weeks Ago 96 D1 manual V8 to 300 Tdi. I am half done. cleaning up all the mess the V8 made is the biggest job. wiring is fairly simple, its a diesel. As i go through this process i will post pics and steps, as there seems to be a void of this info besides the general talk,, do this do that. How was my question and im sure im not the only one.
ID:	31121   Click image for larger version
sherm27t is offline
post #2 of 7 (permalink) Old 03-18-2012, 10:10 PM
roverandom's Avatar
Quoted: 4 Post(s)
Cool, keep us updated please.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline
post #3 of 7 (permalink) Old 03-19-2012, 03:52 AM
Quoted: 0 Post(s)
Great, I just bought a 300 TDI and installing it into a 94 Classic.
I have not started the project yet, I'm still waiting on some stuff.
Have you done the engine mounts on the frame yet?
Kevin
Kevin
04 XJ8
94 RRC
2002 E320
72 Series 3 (sold)
70 Series 2A (sold)
Morgan + 8 (Sold)
95 RRC wife's (sold)
92 RRC sold 12/12
90 Jetta with 308K (sold 5/11)
kevin-ct is offline
post #4 of 7 (permalink) Old 03-23-2012, 06:50 PM Thread Starter
Quoted: 0 Post(s)
Not yet, but when i do i will get good pictures
sherm27t is offline
post #5 of 7 (permalink) Old 04-27-2012, 04:49 PM
Quoted: 0 Post(s)
I can see you are swapping manual to manual so its the easy way out. I swapped into the newest D1 I could find, a 99SD.
For others that are maybe swapping into an auto vehicle, make sure you get the 300tdi engine mounts in the right position based on putting the transfer case back exactly where it was with V8/ZF.
Also, if you get the RHD pedal cluster with the engine you can modify the original automatic cluster quite easily as finding a three pedal LHD cluster is quite difficult.
You seem to be where I was in May of 2010.
You can also rework the V8 a/c hoses and fit the V8 compressor on a special mount adaptor. I drive the compressor with the same belt that drives the water pump, ps pump, alternator etc but there is a trick to it.
My Lucas alternator died but I found a 100amp one from an early Saturn and swapped the pulleys. Even the tach reads right.
Good luck, Steve
piper109 is offline
post #6 of 7 (permalink) Old 05-11-2012, 04:54 PM
Quoted: 0 Post(s)
Any updates on this?
Ex_MOD_110 is offline
post #7 of 7 (permalink) Old 06-05-2013, 06:28 AM
Quoted: 1 Post(s)
Good luck, Steve
Please go into detail on this? Im about to drop this 300 tdi into my Disco and Will need to figure out somthing to mount my compressor. Is there a ready made bracket or is this just somthing I will need to fab up? Also what is the trick with the belt? Thanks, Nick
nfbeckman is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Hybrid
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
200 tdi or 300 tdi which one would you choose. grbec22 Defender 11 11-04-2010 01:15 PM
300 tdi. grbec22 Land Rover Parts and Vehicles Wanted 0 10-05-2010 05:34 AM
TDI 200 or TDI 300 migalos Defender 4 06-11-2010 01:51 AM
low mileage 300 tdi or reconditioned 300 tdi? What are people's thoughts? grbec22 Defender 2 05-27-2010 08:42 AM
300 Tdi roverso Defender 2 12-16-2008 01:10 AM
You may post new threads
You may post replies
