gear shift rod - angle mod help ? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 12-22-2010, 11:22 AM Thread Starter
Mikey-D
mrdoiron's Avatar
Quoted: 0 Post(s)
Posting here on this thread as well as another to try an get some feedback/advice/leads...
I have a LT77 gearbox on a RHD of a hybrid mod, and the shift lever essentially is straight vertical to the knob. Problem is the Reverse on this is up and the left (by 1st), and I almost need to lean to get it into R, and there is not a natural / easy feel even to slide to 1st due to the reach required.
I am searching for any experience / advice on how to resolve buy either :
1. Ideally a custom offering of a shaft angled toward the driver somewhere to resolve ? (again would need to angle toward driver on right in my case) , or
2. Tips on how to heat up/bend the existing shaft without causing another problem, weakening the shaft and creating a potential 'snap point' etc...
Any leads/tips greatly appreciated, mike
...mike
61 Series IIa Hybrid Coiler Defender
69 Series IIa
80 Series III Lightweight SOLD
2005 Disco SOLD
2000 Disco RIP - Tree
1999 Range RIP - End over end 2.5 times !
1998 Disco GONE - Ex-wife
2010 Range R Sport
mrdoiron is offline
post #2 of 2 (permalink) Old 12-23-2010, 05:37 PM Thread Starter
Mikey-D
mrdoiron's Avatar
Quoted: 0 Post(s)
I thought I could move the gearshift lever on it [LT77 'box], by undoing the Lock nut which holds the gearshift lever to the top of the selector mechanism, lifting up the gearshift lever from its mounting splines and repositioning it so that the knob was nearer to the steering wheel.
...My theory anyway.. but the nut at the top is super tight, I can't loosen, at least not with a small hand wrench as it just strips the nut and doesn't loosen for some reason... I hit it with WD40 and I'll wait, but seems way too tight. Any chance that is a reverse thread on these ?
Name:	LT77 gearshift lever1.jpg
ID:	27218   Click image for larger version
Name:	LT77 gearshift lever2.jpg
...mike
69 Series IIa
2005 Disco SOLD
2010 Range R Sport
mrdoiron is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Hybrid
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Rod Mod Advice marydtomyrover Discovery 3 / LR3 1 10-11-2010 10:17 AM
Gear shift stuck 1995 25th Range Rover Classic 5 08-31-2010 02:13 AM
D1 Gear Shift Indicator pushngo Land Rover Parts and Accessories 0 01-12-2010 04:12 PM
Gear Shift OSIYEZA Discovery Series II 3 12-14-2006 10:30 AM
Gear shift prob's Craig Discovery Series I 8 03-14-2006 01:12 PM
You may post new threads
You may post replies
