'12 RR Sport - ECU Reset - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 08-12-2019, 11:59 AM Thread Starter
Quoted: 0 Post(s)
I had a phantom code for transmisson fault but when scanned with multiple OBDIIs nothing would come up (this fault came up after lowering from off-road height). Everything starts, drives, and runs fine - no issues. Transmission fault would not go away so I decided to perform a hard reset with the battery cables, which cleared my phantom transmission code. Only problem is, now I have a battery warning light with code B11DB 'Unknown Issue' that will not go away (suggested fix is to tighten battery cables -- trust me they're tight as hell).
2 Questions
1 - Can a hard reset be preformed without this battery warning light activating (ie try hard reset again with a rabbits foot)
2 - I'm too cheap to pay for a dealer clearing of the code - will it eventually go away when it realizes the battery is fine?
Chip Barringer is offline
post #2 of 3 (permalink) Old 08-13-2019, 10:03 AM Thread Starter
Quoted: 0 Post(s)
Possible culprit
Scoured the internet for similar issues and came across the below. Essentially, I think I may have reattached the BMS slightly off center. I'll give it a go later on a report back results!
Too new to the boards to post a link to the thread mentioned but google "Strange ending to a long and expensive Battery Monitoring System error." It's from rangerovers.net
post #3 of 3 (permalink) Old 08-14-2019, 07:36 AM Thread Starter
Quoted: 0 Post(s)
No luck. I did trace the BMS off the positive terminal and found two seemingly unconnected ends. Can anyone help me to understand what these are and if they should be connected to anything?
ID:	87545   Click image for larger version
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
