41 faults from 15 modules... where to begin? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 07-19-2019, 06:49 PM Thread Starter
very disco
reverendALC's Avatar
Quoted: 23 Post(s)
i just got my nanocom EVO today. wonderful surprise when i was expecting it monday... though i must say, i don't see much that it does that's not in the foxwell for 1/3 of the price. two tools is fine tho.
back story:
2006 NAS RRS 4.4 petrol
purchased it relatively cheap with suspension fault, and going in and out of crash/emergency mode
i've noticed that there appears to have been a significant amount of water beneath the rockers in both driver and passenger door sills. i noticed that on the pass. side when fixing my front windows, so i opened the driver side as well.
what it's doing (exactly):
when starting the truck, the air compressor would run for a second or two, then cut off with amber suspension fault.
when going into emergency mode, i get this:
and all interior electronics shut down except the instrument cluster, and the hazards turn on
the truck will continue to run and drive if it goes into crash mode, but will not crank once shut off
when in emergency mode, i also get HDC, EPB, and other various faults
what i've done:
replaced the battery with a top shelf battery (even though old one tested out fine)
replaced the brake lamp switch
replaced the brake lamps
physically removed (but not disconnected) the instrument cluster. fussing with this will result in exiting emergency mode, though i'm not sure how/why.
when in emergency mode, i've fussed with the wiring looms running in both door sills, no change.
performed vehicle reset with nanocom EVO, does nothing for me.
here are the 41 codes pulled, retrieved from the car AFTER all codes cleared, and after emergency mode has come on:
41 faults from 15 modules... where to begin?-img_8273.jpeg41 faults from 15 modules... where to begin?-img_8272.jpeg41 faults from 15 modules... where to begin?-img_8271.jpeg41 faults from 15 modules... where to begin?-img_8270.jpeg41 faults from 15 modules... where to begin?-img_8269.jpeg41 faults from 15 modules... where to begin?-img_8276.jpeg41 faults from 15 modules... where to begin?-img_8275.jpeg
41 faults from 15 modules... where to begin?-img_8274.jpeg41 faults from 15 modules... where to begin?-img_8285.jpeg41 faults from 15 modules... where to begin?-img_8284.jpeg41 faults from 15 modules... where to begin?-img_8283.jpeg41 faults from 15 modules... where to begin?-img_8282.jpeg41 faults from 15 modules... where to begin?-img_8281.jpeg41 faults from 15 modules... where to begin?-img_8280.jpeg
41 faults from 15 modules... where to begin?-img_8279.jpeg41 faults from 15 modules... where to begin?-img_8278.jpeg41 faults from 15 modules... where to begin?-img_8277.jpeg41 faults from 15 modules... where to begin?-img_8294.jpeg41 faults from 15 modules... where to begin?-img_8293.jpeg41 faults from 15 modules... where to begin?-img_8292.jpeg41 faults from 15 modules... where to begin?-img_8291.jpeg
41 faults from 15 modules... where to begin?-img_8290.jpeg41 faults from 15 modules... where to begin?-img_8289.jpeg41 faults from 15 modules... where to begin?-img_8288.jpeg41 faults from 15 modules... where to begin?-img_8287.jpeg41 faults from 15 modules... where to begin?-img_8286.jpeg41 faults from 15 modules... where to begin?-img_8297.jpeg41 faults from 15 modules... where to begin?-img_8296.jpeg
2003 Disco 2 SE7 - going to be buried in it
2006 RR Sport HSE - project
1997 Disco SE - SOLD
2003 Disco 2 SE7 - SOLD
1995 Disco SE - SOLD
2001 Disco 2 SE - SOLD
Foxwell NT510, Nanocom EVO
reverendALC is online now
post #2 of 6 (permalink) Old 07-19-2019, 06:56 PM Thread Starter
very disco
Quoted: 23 Post(s)
more codes...
continued:
41 faults from 15 modules... where to begin?-img_8299.jpeg41 faults from 15 modules... where to begin?-img_8298.jpeg41 faults from 15 modules... where to begin?-img_8297.jpeg41 faults from 15 modules... where to begin?-img_8296.jpeg41 faults from 15 modules... where to begin?-img_8309.jpeg41 faults from 15 modules... where to begin?-img_8308.jpeg
41 faults from 15 modules... where to begin?-img_8307.jpeg41 faults from 15 modules... where to begin?-img_8306.jpeg41 faults from 15 modules... where to begin?-img_8305.jpeg41 faults from 15 modules... where to begin?-img_8304.jpeg41 faults from 15 modules... where to begin?-img_8303.jpeg41 faults from 15 modules... where to begin?-img_8302.jpeg
41 faults from 15 modules... where to begin?-img_8301.jpeg41 faults from 15 modules... where to begin?-img_8300.jpeg
post #3 of 6 (permalink) Old 07-19-2019, 06:59 PM Thread Starter
very disco
Quoted: 23 Post(s)
i'm not sure if the EAS computer is on the fritz, or if it's got AMK software with a hitachi pump... the hitachi that was on there looked really good when i got it, not like it had been down there for 13 years. maybe somebody updated to AMK and had software flash, and then the previous guy who tried to fix this slapped a hitachi back on? grasping at straws here...
but i'm getting failures when querying the air valves:
41 faults from 15 modules... where to begin?-img_8310.jpeg41 faults from 15 modules... where to begin?-img_8311.jpeg
i also seem to regularly be unable to clear faults from the front lighting module and the body control module:
41 faults from 15 modules... where to begin?-img_8313.jpeg41 faults from 15 modules... where to begin?-img_8314.jpeg
i don't think it's a vehicle height sensor issue, as they are all reporting similarly, and they were accurately reflecting when i had the vehicle jacked up on the left side:
post #4 of 6 (permalink) Old 07-19-2019, 10:43 PM
sierrafery's Avatar
Quoted: 246 Post(s)
I'm affraid you'll have to visit a main dealer for vehicle software upgrade to rule that out before you start chasing a bad contact on the CAN path co that can be a nightmare
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #5 of 6 (permalink) Old 07-20-2019, 06:05 AM Thread Starter
very disco
Quoted: 23 Post(s)
i'll burn this truck to the ground before i visit the dealer!
i have begun downloading what i believe to be the correct software from genesis for my ECUs, but...
nanocom EVO reports my Instrument Pack as:
HARDWARE NUMBER: YAH500172
SOFTWARE NUMBER: NNV502246
ASSEMBLY PART NO: YAC500473PVJ
genesis doesn't have a corresponding ASSY# for my VIN, the nearest is YAC500465PVJ
if i go by HW# YAH500172, the corresponding ASSY# is IPK_COOL-LVL15_061106, and the corresponding SW# are NNS502941, NB500330, and NNV506120.
genesis doesn't have a corresponding SW# for my VIN either...
Also, the BCM files on genesis don't correspond to what's in this truck.
post #6 of 6 (permalink) Old 07-24-2019, 02:53 PM Thread Starter
very disco
Quoted: 23 Post(s)
i have software updated every ECU on the truck that genesis has a file for. no change.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
