alternator failures - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 05-15-2019, 06:04 PM Thread Starter
Quoted: 1 Post(s)
alternator failures
my 2006 sport is eating alternators at a rate of 1 per month. the shop decided it was caused by a faulty ECU. ECU replaced and reprogrammed. 2 days and 71 miles, yep dead. so the body count is 5 alternators, two batteries and one ECU.
need a solution.
please!!!
cmrwash is offline
post #2 of 5 (permalink) Old 05-16-2019, 03:18 AM
sierrafery's Avatar
Quoted: 246 Post(s)
How's the voltage output of it when it works, did somebody measure that? ...cos if the main output lead is chaffed somewhere and leaks to earth that woud certainly kill it
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 5 (permalink) Old 05-16-2019, 08:51 AM Thread Starter
Quoted: 1 Post(s)
wiring was checked, and it fine. when working it's charging correctly but some times the ecu is telling the alternator to overcharge at upto 22 volts. this kills the battery and alternator. is there anything between the ecu and alternator?
cmrwash is offline
post #4 of 5 (permalink) Old 05-16-2019, 10:45 AM
sierrafery's Avatar
Quoted: 246 Post(s)
The ECU is hardwired to the generator and i doubt that it's tellig it to charge to 22
The voltage on the battery must be checked at that point cos it seems that the batt sensing system in the alternator considers that there's not enough charging or something like that... can be a bad contact in the battery junction box, i suspect that the problem is somewhere in that blue circle so measurements are needed to see if the voltage which enters into the junction box is the same with which comes out of it and goes to "BATT SENSE" port ... this thing needs serious troubleshooting so find a skilled auto electrician who understands what's going on.
Name:	RRS charging.jpg
post #5 of 5 (permalink) Old 05-17-2019, 08:26 AM
Quoted: 0 Post(s)
X2 on this advice. You need to get someone who knows what they are doing to determine what is happening here. There is definitely some kind of wiring/grounding problem, alternators are pretty robust and do not self destruct easily.
enb54 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
'03 oil pump failures overblown? 94svt50 Discovery Series II 8 02-11-2011 04:57 PM
Repeat head gasket failures? DiscoKline Discovery Series II 9 12-17-2010 08:36 AM
Discovery 2 Propshaft Failures David Hallworth Discovery Series II 55 02-13-2009 10:25 AM
So what are the causes / reasons for the HG failures? turbodave Discovery Series II 2 12-04-2008 06:06 AM
Fuel Pump failures on Sport Jim Adams Range Rover P38, Mk III and Range Rover Sport 8 02-12-2006 06:00 PM
You may post new threads
You may post replies
