Engine Disabled - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 21 (permalink) Old 08-05-2010, 06:48 AM Thread Starter
Quoted: 0 Post(s)
Angry Engine Disabled
I have a Land Rover, Range Rover 1997. I left my car at the airport parking for two weeks, and now, when I come back, I cannot get the car started. The battery was dead, so i charged the battery, but when I try to get in the car with the key and start it, the display screen says "Engine disabled PRESS REMOTE" . I guess I need to synchronise the remote with the car, but how do I do that. I tried changing the battries in the remote, and sticking the remote key in the door lock and lock the car while pressing the lock button, and unlock the car while holding the unlock button, but still that doesnot help. Any advise?
shabbir is offline
post #2 of 21 (permalink) Old 08-06-2010, 01:07 PM
Quoted: 1 Post(s)
Talking Won't start?
Your drivers door latch MAY need replaced. ibis1
ibis1 is offline
post #3 of 21 (permalink) Old 08-09-2010, 05:20 AM Thread Starter
Quoted: 0 Post(s)
I had to tow my Range Rover to the Dealer the day before yesterday, and the Dealer says that the whole BECM needs to be replaced. I wonder why??? because the car was just fine when I left it at the airport, and now just to synchronize the key with the car, the dealer says that the whole BECM needs to be replaced!!! This just doesn't make any sense to me! Moreover, I checked it online, and a used BECM is for about $500 with three year warranty, however, the dealer says that he cannot install that part in the car, and the BeCM has to be a new one and he's charging me $2600 for it!!! Any one any advice??? Please!!!!
shabbir is offline
post #4 of 21 (permalink) Old 08-09-2010, 05:40 AM
Quoted: 11 Post(s)
You cannot install a used BeCM unless it has been electronically unlocke as AFAIK, there are FOUR people on the planet who can do this.
Tell them to copy the security code from the BeCM into the space in the Engine ECU settings page.
If they are incapable of doing this, send me the BeCM, the ECU and the instrument panel and I can do it for you for $500 plus shipping. There is significant labor in doing it right without having the vehicle present.
If that's not an attractive option, find a local independent with a Rovacom. I'm not confident the Autologic can do it as I get many sent to me where the Autologic was incapable of restoring the vehicle to operational status.
It's probably not the door latch (although that's very common) in this case, it may well have been the radios in use around the airport that interfered with the BeCM's sleep mode which can cause alarm/BeCM problems.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
PTSchram is offline
post #5 of 21 (permalink) Old 08-09-2010, 11:10 AM Thread Starter
Quoted: 0 Post(s)
I dont have any mechanic here who would do that, Moreover, the Land Rover Dealer says that he would not be able to copy the security code from the BeCM into the space in the Engine ECU settings page. Infact they dont co-operate at all. All they say is that My BeCM is bad and I need a new one only then they can progress... I guess I have no other option left but to shell out $2600 for that BeCM!!!
shabbir is offline
post #6 of 21 (permalink) Old 08-10-2010, 05:57 AM
Quoted: 11 Post(s)
Your other option is to ship the truck to me and have me fix it for less. $2600 is almost $1000 more than I charge to do the same depending upon exchange rate and part availability.
260-804-0458
PTSchram is offline
post #7 of 21 (permalink) Old 08-10-2010, 09:46 AM Thread Starter
Quoted: 0 Post(s)
Where would I have to ship the truck? I stay in Sanford, NC.
shabbir is offline
post #8 of 21 (permalink) Old 08-10-2010, 01:22 PM
stereosteves's Avatar
Quoted: 0 Post(s)
i can fix that in 2 maybe 1 sec but im in utah how about this you fly me out thir and i will fix your rover then you fly me to a sf 49ers game you pay for it all and i will fix your rover right ware it sits that shoud be well under $2000.00 Stereo Steve
stereosteves is offline
post #9 of 21 (permalink) Old 08-13-2010, 07:51 AM Thread Starter
Quoted: 0 Post(s)
Ohhh Great!!! Now my Dealer says that, the windows are not working and the passenger side door is locked out due to a bad BeCM and he cannot open it to install a new BeCM. and now the lock needs to be broken and a new lock needs to be installed, another $600 for it!!! I swear, I wont even want my worst enemy to buy such a peice of junk!!! It still surprises me how, just a remote being out of sync can cause such a big issue for a Land Rover. Isn't there any re-call for this kind of thing!!! I am Doomed. I dont know what to do???
shabbir is offline
post #10 of 21 (permalink) Old 08-13-2010, 12:19 PM
Quoted: 0 Post(s)
bull shit .... i can get your rover started and then whe can go from thir dont have it toed home from the diller i will get it started right thir ones running whe can check out the windewos and the pass door ...... i have a 1995 lr rr and it sat for 5 years be for i came along now it runns fine thir is a fuse box under the hood that can shit the bed and couse you trouble and its like $150 and eazy to install im here if you wont the help all you got to do is fly me out then and then to a sf 49ers game you pay and ill get you rover going
post #11 of 21 (permalink) Old 08-13-2010, 01:47 PM
Quoted: 11 Post(s)
Steve is clearly much better at this than I. I'm bowing out.
260-804-0458
PTSchram is offline
post #12 of 21 (permalink) Old 08-13-2010, 01:59 PM
Quoted: 0 Post(s)
i picked up a 1995 land rover rang rover p38 and the guy that sold it to me just had it siting for 5 years it would not start would not turn over at all so i payed the guy i did not know if would start after fixing the becm to ecm issu but got the right tools to fix it and it fired right up i had to fix some outher stuff on like that fuse box under the hood after doing that the windeos seem to roll up and down faster then be for im here just let me know
post #13 of 21 (permalink) Old 08-14-2010, 12:00 AM
Quoted: 0 Post(s)
dont ship your rover just ship me out there then to a game ill even fly stand by i just wont to go to a 49er game ok just fly me out thit then back home then buy me 2 tickets to the sf 49ers at sandiego game i just picked up 2 tickets and thay like $480 for 2 and a flite is like i wont to say $200 round trip so thats like$680 and your back in biz oka thank about it
post #14 of 21 (permalink) Old 08-16-2010, 08:33 AM Thread Starter
Quoted: 0 Post(s)
Give me your Name and the airport that you will be flying out of. I'll book a return ticket for you and I'll pay you in cash rightaway once the car gets started!!!
shabbir is offline
post #15 of 21 (permalink) Old 08-16-2010, 12:39 PM Thread Starter
Quoted: 0 Post(s)
Will you really be able to start it or will I have to pay the dreadful dealer afterall??? I am soooo confused!!! Coz I dont believe the dealer a bit!!! How can my car just wont syncronize with the key after the battery is dead and Why would it take them to replace the whole BeCM and programme it anywez, when they can programme my existing BeCM.... it just doesn't make any sense!!! I am Trapped!!!
So, do you have all the tools required to programme it if needed???
shabbir is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Engine Disabled shabbir Range Rover Classic 1 08-04-2010 12:20 PM
P38 engine disabled lock out code mistery, please please see if you can help me andytaylors Range Rover P38, Mk III and Range Rover Sport 1 05-22-2010 10:00 AM
Engine is disabled cocalc Range Rover P38, Mk III and Range Rover Sport 2 01-11-2010 04:12 PM
98 RR - Engine Disabled Rick Range Rover P38, Mk III and Range Rover Sport 13 10-22-2004 12:33 PM
You may post new threads
You may post replies
