Engine System Fault - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 04-30-2010, 08:00 AM Thread Starter
Quoted: 0 Post(s)
Engine System Fault
So recently whenever whenever im on the highway and travelling at speeds of 140km/hr or more i get a message on the dash saying ' Engine System Fault'. After that the car does not even accelerate properly. Even if i floor it it will take ages for it to go from 100 to 120. The engine check light does not come one either. If i stop, turn the ignition off and then turn it back on the problem goes away. I took it to the dealer but they said that they do not know what is going on since the car is not storing any 'error codes'. Does anyone know what the problem might be? Any help will be appreciated. Thanks
zoomzoom is offline
post #2 of 10 (permalink) Old 05-01-2010, 08:53 PM Thread Starter
Quoted: 0 Post(s)
anyone?
zoomzoom is offline
post #3 of 10 (permalink) Old 05-02-2010, 05:46 PM
Quoted: 0 Post(s)
where are you and what is the year and model of your RR
Mrmerlin is offline
post #4 of 10 (permalink) Old 05-03-2010, 10:08 AM Thread Starter
Quoted: 0 Post(s)
i live in toronto, canada and its a 2006 rr sport supercharged
zoomzoom is offline
post #5 of 10 (permalink) Old 05-16-2010, 10:00 AM
Quoted: 0 Post(s)
i am having that same problem every so often and only on the freeways of excess speeds of 60mpg...
fujimoto91 is offline
post #6 of 10 (permalink) Old 05-16-2010, 06:32 PM
carlosz's Avatar
Quoted: 0 Post(s)
first of all have you set the speed limit control? if so turn it off. (read owners manual)
secondly find a more competent dealer than the one you are visiting... your model seems to suffer from software updates it may just need a tune download...
the "no codes found response" is not a very profesional or knoledgeable response.
last of you are speaking kilometers per hour any tech who takes it for a drive should be able to duplicate,...riiiight!. but if you are speaking 100 to 120 mph not very many techs will be willing to diagnose on a road test.
carlosz is offline
post #7 of 10 (permalink) Old 05-16-2010, 07:02 PM
Quoted: 0 Post(s)
the electric water pump might have failed or have the pins on the connector backwards causing it to go into limp mode. I think there is a bulletin for it but I am not 100%.
1999 Disco2
KyleT is offline
post #8 of 10 (permalink) Old 11-12-2013, 01:31 PM
Quoted: 0 Post(s)
The dealers do not know what's wrong. I found out, just by trying, that it should be an error coming from the anti particulate filter. Instead of providing the message of regenerating the filter, the engine system fault message comes up. You have to perform the following procedure: drive for 20 minutes with the speed of 60-80 mph, at rpm 2500-4000. It works.
Best
gf
gabriele fragasso is offline
post #9 of 10 (permalink) Old 05-06-2018, 03:04 PM
Quoted: 0 Post(s)
hello
i also have the same problem with the same car , can you give me a solution please ?
saber is offline
post #10 of 10 (permalink) Old 03-25-2019, 05:54 PM
DillJLoc's Avatar
Quoted: 2 Post(s)
Did anyone figure this out?
DillJLoc is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
HDC Fault & Transmission Fault Ppwcanada Discovery 3 / LR3 27 07-28-2018 06:57 PM
Help - 06 has Suspension Fault error after 30 seconds of starting engine Dan_da_LR3_H2_man Discovery 3 / LR3 12 09-24-2011 03:15 PM
Fault warning - Engine Diminished Performance Warning [email protected] Range Rover P38, Mk III and Range Rover Sport 0 11-24-2009 08:41 PM
Hdc Fault System??? Please carlitonsky Discovery 3 / LR3 1 03-22-2009 08:10 AM
LR to use e-Terrain system electric rear engine appstatedisco Hybrid 4 04-14-2006 06:05 PM
You may post new threads
You may post replies
