01 Discovery 2 engine noise. Lifters vs slipped sleeve? - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #1 of 25 (permalink) Old 02-25-2019, 08:49 AM Thread Starter
Quoted: 4 Post(s)
https://youtu.be/D-4VXlmqNrc
https://youtu.be/IkgEMccNruI
Posting for a buddy.
His 01 is making this noise. Click links above to see short videos. Hopefully one of y’all more familiar with this engine than myself can help.
Backstory: Started 6 months ago.
Happens when engine gets to running temp, not at cold start.
Any way to determine what the noise is coming from without ripping the engine apart?
Follow up is if it is a slipped sleeve what would be your course of action? Sinking thousands into a repair simply isn’t an option.
Thanks in advance for any input.
Def110 is offline
post #2 of 25 (permalink) Old 02-25-2019, 09:50 AM
member
SafariDave's Avatar
Quoted: 133 Post(s)
His 01 is making this noise. Click links above to see short videos. Hopefully one of yall more familiar with this engine than myself can help.
Follow up is if it is a slipped sleeve what would be your course of action? Sinking thousands into a repair simply isnt an option.
Is it overheating?
Is it leaking coolant?
Is it Loosing coolant internally?
Is it misfiring?
Has it loss power?
Dave
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my girl's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
post #3 of 25 (permalink) Old 02-25-2019, 09:58 AM Thread Starter
Quoted: 4 Post(s)
No overheating issues.
No leaks oil or coolant.
No coolant loss internally from what I can tell. It has been run for 6 months with this knock and has not needed any coolant.
There was a misfire issue a while back, but I believe it to be attributed to a romp in the water. Hasn't misfired since.
I don't see a significant power loss. It's never been a fast car but it does seem a little slower when accelerating than some others I have been in. Couldn't say if that is attributed to this.
Def110 is offline
post #4 of 25 (permalink) Old 02-25-2019, 10:23 AM
member
SafariDave's Avatar
Quoted: 133 Post(s)
How many miles on the engine?
It could be a slipped liner that has not ruptured the head gasket, or it could be low oil pressure. (make sure its not due to low oil pressure) or it could be lower bearings knocking. If its not affecting anything I would not bother. Many have been driving with tick and tap noises coming from the engine which do not effect the truck. Mine sometimes has a tapping sound, But it runs fine. Try Rotella 15W40 oil see if that helps with the noise.
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #5 of 25 (permalink) Old 02-25-2019, 10:28 AM Thread Starter
Quoted: 4 Post(s)
120k. Original engine. Heads were just done about a year and a half ago by a Rover shop.
If it is a slipped cylinder liner I'm guessing if it is not fixed it will eventually cause a catastrophic engine failure? As far as I know that isn't something that you can keep ignoring forever.
Def110 is offline
post #6 of 25 (permalink) Old 02-25-2019, 10:34 AM
member
SafariDave's Avatar
Quoted: 133 Post(s)
You can get it diagnose by an LR Indy shop. There is a lot of info on slipped liners in this forum. You can use the search function.
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #7 of 25 (permalink) Old 02-25-2019, 10:39 AM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
I would add - what temperature does it run at?
If over 200 degrees (f) then I would deal with that first and switch to a 180 deg thermost, as well as a good flush and new green / regular coolant.
The oil isn’t a bad idea in warm climate.
Where in the world are you from?
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #8 of 25 (permalink) Old 02-25-2019, 12:39 PM Thread Starter
Quoted: 4 Post(s)
Not sure what temp it runs at, haven't tested. On the gauge it sits right in the middle even when heading up mountain roads.
The car is my friends in Salt Lake City that I am visiting.
Can't run a warm weather oil now. I have changed oil before twice a year from warm climate to cold climate oil changes.
Def110 is offline
post #9 of 25 (permalink) Old 02-25-2019, 12:46 PM
tyl604's Avatar
Quoted: 180 Post(s)
Your temp gauge will never move until it is too late. By design it stays in the middle until your truck is overheated and then it moves; often that is too late to prevent a blown head gasket. It does not click, click, click up toward hot; it goes in one movement. You would be wise to go out today and get a third party temp gauge and watch the temps. Generally folks get one that plugs into the OBDII socket.
tyl604 is offline
post #10 of 25 (permalink) Old 02-25-2019, 01:15 PM
Quoted: 59 Post(s)
I went with this type. I got a ScanGaugeII.
I have this same tick right now but won't know what it is until I tear it down next month - I've gotta do my head gaskets and timing/oil pump then and my bet is it's my lifters not getting enough oil/pressure from my pump. If you haven't resolved your issue by then, I'll report back. S
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #11 of 25 (permalink) Old 02-25-2019, 02:08 PM
member
SafariDave's Avatar
Quoted: 133 Post(s)
Just read another D2 forum from New Zealand. I copied and pasted this info below:
I'm using Shell Helix HX3 which is a 20/50 - Oil pressure much better as well - runs at about 2.5 Bar when
warm.
From that article it seems that it could well be piston slap. They cured that by expanding the skirt of the piston.
"On that motor which had exactly the same hot rap we found the piston skirts had collapsed in about ten thousandths of an inch. That was enough to make them rock when they got hot, and they rapped good and loud.
On that engine we expanded the piston skirts and refitted the pistons. No more rap. But did that repair need to be done? Loose piston skirts would not lead to a failure. Ill bet that motor would have run 25,000 miles with that rap, maybe a lot longer. In any case, new pistons are the fix. Liners are not involved at all, unless the block were to crack when the head bolts were cinched down one more time"
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #12 of 25 (permalink) Old 02-25-2019, 02:23 PM Thread Starter
Quoted: 4 Post(s)
Thanks for the info here guys, Looks like it's probably too much to tell. Sounds like he got quoted an obscene about to replace the engine or top hat gasket the engine.
Sounds like most shops won't pin a head if that is the issue.
I guess my only other question is if it is a slipped cylinder sleeve, how long can it be driven like that? He's already gone 6 months on there with no side effects other than an annoying knock at idle.
Def110 is offline
post #13 of 25 (permalink) Old 02-25-2019, 02:28 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 109 Post(s)
Have you double checked for exhaust leaks? They can be mistaken for motor tapping, also another thing to double check is the flex plate.
SafariDave likes this.
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #14 of 25 (permalink) Old 02-25-2019, 02:42 PM
member
SafariDave's Avatar
Quoted: 133 Post(s)
This sound only happens once car is warm and at idle.
Once warmed wouldn't the exhaust leak not be heard any longer?
The Flex plate sounds kind of like a loud rattle right?
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #15 of 25 (permalink) Old 02-25-2019, 03:13 PM
ArmyRover's Avatar
Quoted: 109 Post(s)
I have had exhaust leaks that got worse as it warmed up but generally I saw a snapped bolt with that.
One flex plate I heard that was bad I swore had rod knock it was so solid. Another was almost lifter tick like.
1972 MGB
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Blown Head Gasket/ possible slipped Sleeve- new engine or ? KoruExpeditions Discovery Series II 3 06-24-2018 07:56 AM
Complete Parts and Machining List for a Slipped Sleeve Repair austindiscoverybill Discovery Series II 0 05-07-2015 07:52 AM
Finally back with the Disco! is it really a slipped cylinder sleeve? Belafontainw Discovery Series II 7 05-30-2012 05:36 AM
HELP - Slipped Sleeve? molendast Discovery Series II 1 10-12-2011 05:30 AM
Question about new lifters and engine knock Bosbefok Discovery Series II 7 06-10-2011 02:05 PM
You may post new threads
You may post replies
