04 CDL Shifter Installation Video - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
post #16 of 31 (permalink) Old 10-18-2009, 08:47 PM
Quoted: 0 Post(s)
I am about to go to a nice path in Lower AZ I have driven offroad many times and rocks too but an automatic is different for me my transfer shifter is stiff wont budge what is or should I do I am a mechanic but afraid of that part of the vehicle Cost?
Bless the Military, Border Patrol, and Lawenforcment and family's that support them. They protect us while we sleep and express our freedoms as US citizens.
We are free because we have the second amendment once this is gone we will have none, make and impact get involved with you towns political views.
323jamie is offline
post #17 of 31 (permalink) Old 02-21-2010, 06:03 AM
FFMO's Avatar
Quoted: 0 Post(s)
nice>>> but dose installing the CDL effect Anything else? like TC or there is some thing Unusual effect the cars Movement?
FFMO is offline
post #18 of 31 (permalink) Old 02-23-2010, 03:27 PM
FFMO's Avatar
Quoted: 0 Post(s)
hi mike. i have 2003 discoII>>>dose the cdL ur refering to fits my car?? is it true that i have to change my t-case??pls replly
thanks
FFMO is offline
post #19 of 31 (permalink) Old 02-23-2010, 05:27 PM
DiscoDream2's Avatar
Quoted: 1 Post(s)
thanks
Your Disco did not have the CDL parts offered that year. You would have to change the transfer case to have the CDL option.
DiscoDream2 is offline
post #20 of 31 (permalink) Old 02-24-2010, 03:49 AM
FFMO's Avatar
Quoted: 0 Post(s)
OK>>>>dose the CDL operates Electronically in low range in my discoII 2003??how?
Because I can not believe that one day land rover will cancel this option!!
land rover of course will Provide an alternative in this case!!??what is it?? and how dose it operates??
FFMO is offline
post #21 of 31 (permalink) Old 02-27-2010, 03:54 AM
FFMO's Avatar
Quoted: 0 Post(s)
In fact my 2003 disco have this Stickler Shows that CDL is Available (as the attachment shows!!!) but the shifter dosen't go to the left?? I tested the mode button to Activate CDL?after the S sign appeared it's Seems that CDL is working!! but im not Sure yet!!!!.
I Also heard from the dealer that it's Optional on 2003 discos to have CDL not all of them missing the CDL.
Can anyone confirm this Idea??
disco mike i know Ur the man for the job?? can u replly??
FFMO is offline
post #22 of 31 (permalink) Old 03-07-2010, 03:49 AM
FFMO's Avatar
Quoted: 0 Post(s)
hello any body home??
the best 4X4Xfar
FFMO is offline
post #23 of 31 (permalink) Old 04-13-2010, 07:06 AM
Quoted: 0 Post(s)
dude crawl under it and feel at the the front of the t case just above the front drive shaft output and to the drivers side if there is a bolt or a "nipple" (sitcking straight up) there, it is possable that you have one. how ever i highly doubt that you do. very few came with them and the sticker means jack. i to have a 03 with the sticker but no cdl till i fixed that. yes you will have to replace the whole t case or the parts out of one. (recomend the whole thing) this is totaly worth it in the end!!! look at this and it should explain. http://www.landroversonly.com/forums...uctions-32719/
disco2digger is offline
post #24 of 31 (permalink) Old 05-18-2010, 05:16 PM
FFMO's Avatar
Quoted: 0 Post(s)
Originally Posted by Disco Mike View Post
Hi mike ..its me agan Sorry for bothering you but dose that means that I need the disco04 shifter only for my disco03?? or I need to buy other parts as well??
the best 4X4Xfar
FFMO is offline
post #25 of 31 (permalink) Old 05-22-2010, 05:03 PM
Jake.B.
Quoted: 0 Post(s)
I have a question. I can't get my current lever to move at all. . . is there an electric switch or something that automatically engages that enables the lever to shift? If I do this mod, will I have the same issue??
ThaFusa is offline
post #26 of 31 (permalink) Old 04-26-2011, 07:24 PM
chuzz's Avatar
Quoted: 0 Post(s)
Garage
I just got my T-case for my 2003 today. D2 2000 donor. Any recommendation on wich shifter to use?
chuzz is offline
post #27 of 31 (permalink) Old 05-07-2011, 01:05 PM
g7jtk's Avatar
Quoted: 0 Post(s)
It is now on my list of things to do.
g7jtk is offline
post #28 of 31 (permalink) Old 06-07-2011, 07:11 PM
mbruneaux's Avatar
Quoted: 5 Post(s)
2002 like '03 and '04
I thought I read somewhere that the 2002 doesn't have the mechanicals and that the TC has to be upgraded? And if all I need is a cable then I've read that the D1 cables work and also the 2004?
Canterbury, CT
1989 Chrysler Conquest TSi (Project Race Car)
2001 Pontiac Grand Prix GTP (Daily Driver)
2002 Discovery II SE7 (Wife's progeny wagon and tow vehicle)
Second place is S*** place , eh. - Stéphane Peterhansel
mbruneaux is offline
post #29 of 31 (permalink) Old 07-05-2011, 05:41 PM
Black Rhino
Jameskemi's Avatar
Quoted: 0 Post(s)
CDL check my nipple
I have an April '01 DII, would this picture indicate CDL 'able ?
'01 disco ii,
67k; Akebono pad and palenga rotors,
70k: head gaskets, thermostat, belt, 1 SAI replacement, GBR front drive shaft
Long steel brake lines
87K Adios Amigo: ~option B and soldered ABS back to the plug!
Jameskemi is offline
post #30 of 31 (permalink) Old 07-05-2011, 05:57 PM
mbruneaux's Avatar
Quoted: 5 Post(s)
It looks like all you need is the shifter/cable bracket, your internals are good to go. We're not so lucky I just crawled under and didn't feel anything but a nice ring in the case where I guess the shift linkage would go..
Canterbury, CT
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
