12V Hot only when engine running - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
post #16 of 26 (permalink) Old 07-24-2018, 06:11 PM
sierrafery's Avatar
Quoted: 246 Post(s)
With all due respect why would you disconnect that wire from the alternator?
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #17 of 26 (permalink) Old 07-24-2018, 07:43 PM
Redrover NC's Avatar
Quoted: 15 Post(s)
To isolate the terminal so it gets power from the alternator only, not from Fuse 27 via the alternator warning light.
'99 DII, STI wires, Champion 7070s, '04 CDL & SLABS, Garvin WILDERNESS rack, painted headliner, air springs victim, headgaskets at 109,000, plus victim of XYZ (twice) and many other ridiculous DII failures. Option B AMIGO FREE since February 2011.
Runs like a top; now if I could just afford the gas! December 2014 update - Wait, I can afford the gas! Drill baby, drill!!!
Redrover NC is offline
post #18 of 26 (permalink) Old 07-25-2018, 12:38 AM
p76rangie's Avatar
Quoted: 384 Post(s)
I still want to know why he can’t use ignition power. Why can it only be powered when the engine is running. This debate is all a bit pointless as far as I can tell.
p76rangie is offline
post #19 of 26 (permalink) Old 07-25-2018, 04:31 AM
sierrafery's Avatar
Quoted: 246 Post(s)
I dont consider it a debate but a friendly polemic where everybody can learn something
hey @Redrover NC please think twice about the bolded part and eventually you answer the last question from post #10 https://www.landroversonly.com/forum...09-post10.html
post #20 of 26 (permalink) Old 07-25-2018, 05:04 AM
p76rangie's Avatar
Quoted: 384 Post(s)
I am not sure what anyone is learning. You state that the wire does nothing except operate the warning light. You then do not like someone suggesting disconnecting it and using the point on the alternator to power whatever this mystery thing is that can only run with the engine running. By your explanation the only difference that disconnecting it will make is that the warning light will no longer light up
post #21 of 26 (permalink) Old 07-25-2018, 06:15 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Yes that's what i'm saying and that why disconnecting it and loose the warning while it will act the same connected with the warning on and it's just about splice in it with one side of a relay's coil and the other to ground which means that the relay will close only when the alternator will start running, the OP explained on other forum why he wants a feed only with engine running and he even found a better option with the oil pressure switch which for my shame didnt cross my mind: https://www.4x4community.co.za/forum...engine-running
post #22 of 26 (permalink) Old 07-25-2018, 09:37 PM
p76rangie's Avatar
Quoted: 384 Post(s)
As I thought, the ignition power circuit would do exactly what he wants. There was absolutely no need to go looking for something that is only active with engine running. Going and buying a voltage sensitive relay, that are relatively cheap, would be even better
post #23 of 26 (permalink) Old 07-26-2018, 09:11 AM Thread Starter
Quoted: 4 Post(s)
VSRs arenít easy to come by in my neck of the woods. Thereís really only one on the market and it wonít work without a dual battery.
Sent from my iPhone using Tapatalk
The Hoff is online now
post #24 of 26 (permalink) Old 07-26-2018, 03:38 PM
p76rangie's Avatar
Quoted: 384 Post(s)
That is what Amazon is for https://www.amazon.com/Voltage-Sensi...ensitive+relay
post #25 of 26 (permalink) Old 07-26-2018, 04:01 PM
tyl604's Avatar
Quoted: 177 Post(s)
Designed for dual battery...
tyl604 is offline
post #26 of 26 (permalink) Old 07-27-2018, 04:21 PM
Quoted: 2 Post(s)
You can get power directly from the alternator to a 11-15 volt input, 12 volt output regulator to feed your relay. this way you do not mess with the car's other pieces of equipment.
Ed4x4 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
looking for 12V wire that is on only when engine is running lowest bidder Discovery Series II 0 02-23-2014 02:01 PM
Running Hot, Running Hot, Running Hot Ian Larsen Range Rover Classic 10 07-02-2009 06:32 PM
Hot Hot Hot stefaninsanjuan Discovery Series I 7 02-13-2009 06:31 AM
12v outlet problem MuseumKnitter Discovery Series II 5 11-20-2005 04:22 AM
new 12v power supply GentrysRover Discovery Series I 2 03-03-2005 07:46 PM
You may post new threads
You may post replies
