2004 disco se7 misfire on cylinder 6 - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 06-03-2019, 05:09 AM Thread Starter
Quoted: 2 Post(s)
I've been starting to have a misfire on my 6th cylinder and just a couple months ago changed the head gaskets. I took out the spark plug and saw there was oil on it. Is there a common issue it comes from or is there many reasons oil is leaking in?
Bjorn2662 is offline
post #2 of 6 (permalink) Old 06-03-2019, 06:11 AM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
Are you sure it’s oil??
Plug could be fouled for a number of reasons
When you had the heads off did you have them serviced?
check for warpage?
valves cleaned?
valve guides checked?
valve seals replaced?
Or just “head gaskets”?
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #3 of 6 (permalink) Old 06-03-2019, 06:39 AM Thread Starter
Quoted: 2 Post(s)
It smelled, looked, and felt like oil but not 100% sure. I didnt have the heads serviced, just replaced all the gaskets to the parts removed to get to the heads.
post #4 of 6 (permalink) Old 06-03-2019, 12:31 PM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
Do you have a picture of the bad plug?
Was it burnt oil or wet?
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #5 of 6 (permalink) Old 06-04-2019, 06:53 AM
Quoted: 59 Post(s)
You should ALWAYS have the heads checked. They are aluminum and so is everything that touches them, so warpage can be a factor with a overheat. You very well may not have had a proper headgasket installation if this is the case. Nothing else really matters as far as diagnosing is concerned because you need to get those heads back off and have them sent to a shop and tested.
Rinse & Repeat HG Job... Sorry.
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #6 of 6 (permalink) Old 06-04-2019, 09:25 AM
tyl604's Avatar
Quoted: 178 Post(s)
Agree; just assumed that you had the heads checked for warping. I had rebuilt heads installed on mine when I replaced the head gaskets. As I remember it was about $150 more per head.
tyl604 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
