ABS MODULATOR FIX (NO more SVS fault) - Page 3 - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #31 of 137 (permalink) Old 03-10-2010, 03:41 PM
nasa25's Avatar
Quoted: 0 Post(s)
Originally Posted by ownedcasey View Post
This looks like a very well thought out and performed fix that I should be able to do. I've had the 3 amigos for a few months so today I'm gonna try to get rid of the lil SOBs. I really appreciate the step by step instructions with detailed pics. Now I've got to check on why my blinkers aren't working for similar instructions and I'm off to try this out. I'll check back in and let everyone know how it go.
are you even sure that the shuttle valve error is what caused the lights to illuminate in the first place?
nasa25 is offline
post #32 of 137 (permalink) Old 03-10-2010, 05:23 PM
Quoted: 0 Post(s)
We'll know for sure tomorrow. I've got the wiring done from option B and though the process of taking the modulator apart is a difficult one because of the resistance from the brake lines I was able to get it done. A few hints that might help anyone attempting this, get a long 6mm hex wrench that will allow you to put the right amount of torque on the outside hex bolts because they are TIGHT. I had to use a socket wrench with a hex attatchment to get them loosened up. It's possible though folks, even for a mech-nub like me. I've got the wiring ready to go similar to the picture only I'm using 18guage wire and running it out in a solid strand to the ground and YG instead of a detatchable trailer harness. I figure if I have to go thru this again snipping and re-wiring is the least of my problems. Tomorrow it goes back in and we'll see if the 3 amigos saddle up and ride out!
ownedcasey is offline
post #33 of 137 (permalink) Old 03-10-2010, 06:36 PM
nasa25's Avatar
Quoted: 0 Post(s)
Were you getting the amigos on intermittently or did they just come on and stay on?
nasa25 is offline
post #34 of 137 (permalink) Old 03-11-2010, 12:46 PM
Quoted: 0 Post(s)
They came on and stayed on and they're still there :-( Any other suggestions? I guess I'll jsut have to take er into the shop and let them have their way with it unless anyone else might know what of another solution?
post #35 of 137 (permalink) Old 03-11-2010, 01:06 PM
nasa25's Avatar
Quoted: 0 Post(s)
if they were never intermittent then a shuttle valve is 99.9% not your problem.....although rebuilding the modulator would ensure its hassle free operation for a long time to come.
Just get an abs amigo for $200 and read and clear the codes. Then don't do anything until they reappear.
nasa25 is offline
post #36 of 137 (permalink) Old 03-11-2010, 06:27 PM
DiscoDream2's Avatar
Quoted: 1 Post(s)
Yep gotta get the Amigo, ok, it's late and I'm tired so forgive the repeat question. If the issue was fixed, would the codes still need to be cleared (so the lights go away)? That is my thinking anyway..fixing the issue is not enough, I think they still need to be cleared.
DiscoDream2 is offline
post #37 of 137 (permalink) Old 03-11-2010, 08:45 PM
nasa25's Avatar
Quoted: 0 Post(s)
Yeah in most cases the codes will need to be cleared even after the issue is resolved.
nasa25 is offline
post #38 of 137 (permalink) Old 03-13-2010, 01:43 PM Thread Starter
jycsalas's Avatar
Quoted: 1 Post(s)
For the 114 code, (shuttle valve electrical failure) you DO NOT need to clear the codes, they clear themselves. But you need to have a scanner to know that is the issue to begin with.
Other faults require clearing the codes AFTER the repair is made. Otherwise the AMIGOS will remain.
In ownedcasey's situation, he didn't get his codes read and assumed my repair was the answer.
However, I clearly state in the write-up:
Disclaimer:
Use this guide at your own risk!!!!
Before attempting this repair, read the ABS trouble codes stored on the SLABS ECU to verify it is not another issue. A specialized scanner is required to read and clear the code(s). An intermittent fault will clear itself after shutting the engine off and restarting it. It will not however clear the faults from the SLABS ECU memory.
Having codes stored in memory will not cause the three amigos to come on. Only active faults cause them to visit. See Diagnostics for more information about the scanner(s).
~Josh
2003 Discovery S (64k miles)
Mods: Oil Pressure Gauge, ScanGaugeII, CDL, Electric CDL Actuator, RoverRacks Rear ladder, Limb Risers, ToddCo Front Drive Shaft, DI Wiper Arms, G4 Upper Rear Lamp Guards, No Amigos since 11/09
Coming soon:
Install Greg Davis rear bumper, Replace 4 ball joints, Replace belt tensioners and pulleys.
For the future:
.... wait and see....
jycsalas is offline
post #39 of 137 (permalink) Old 03-13-2010, 07:58 PM
LtlSlvr37's Avatar
Quoted: 0 Post(s)
Originally Posted by tpdllc View Post
Just did the fix using the hard wiring and it was pretty easy. The three hex screws are the only problem. Other than that it was easy. It takes about an hour as long as you pre-wire the connectors.
Not sure if this fix will fix your problem but I'm in Syracuse if you can't find anyone closer. Might even be able to do it in Binghamton.
Yeah thats a bit of a drive for me. Im in WC PA not WC NY.
LtlSlvr37 is offline
post #40 of 137 (permalink) Old 03-13-2010, 08:02 PM
LtlSlvr37's Avatar
Quoted: 0 Post(s)
My down hill and traction control are always lit while my ABS randomly appears. The ABS is typically transient showing up maybe once a week but goes away after the car has been turned off.
post #41 of 137 (permalink) Old 03-14-2010, 08:30 AM
nasa25's Avatar
Quoted: 0 Post(s)
that's kind of weird. You need to have the codes read to know what the error is for sure.
Trust me, invest in an amigo.
nasa25 is offline
post #42 of 137 (permalink) Old 04-21-2010, 07:09 AM
Quoted: 0 Post(s)
Abs Modulator Fix
i HAVE DONE IT 6000KM AGO, NO MORE AMIGOS BRILLIANT. i WENT ALL THE WAY TO NO3 FIX AND REMOVED PRINTED CIRCUIT BOARD STICK COMPLETELY.
ALL FUNTIONS OPREATING NORMALLY NO PROBLEMS.
Kalahari Sands is offline
post #43 of 137 (permalink) Old 04-29-2010, 05:27 AM
garywinter's Avatar
Quoted: 0 Post(s)
Hi There
I did the modification some time ago but the 3 lights were still there, I was very disappointed. I took it to a Land Rover Independent specialist and has the faults reset. I did hower not tell the guy that I had done the mod. He was pretty sure that I would need to replace the abs pump. Much to his surprise, gone, no 3 amigos.
I just hope that they stay away now.
Thank you very much for posting this fix?
[/SIGPIC]
99 Discovery 2 XS V8
Terrafirma Coil Springs All Around
Replacement Front Bumber
Dastek Unichip
BFG All-Terrain Tyres
Front Runner Roof Rack
Snorkel
garywinter is offline
post #44 of 137 (permalink) Old 06-03-2010, 05:35 AM
Quoted: 1 Post(s)
Me too - I have the ABS Amigo and my faults are :
114 - shuttle valve electrical failure
OJ's DNA is offline
post #45 of 137 (permalink) Old 06-04-2010, 03:59 PM
Quoted: 0 Post(s)
Tres Amigos Came to Visit
The Tres Amigos light just came on for the first time since I have owned the 2001 Discovery, 118,000 miles. Mind you, it's been 3 weeks since I bought it from a used car dealer! The brakes are good but they are squeaking. Is that where I should start? The dealer told me over the phone that most likely I had to replace the modulator for $3000. Yikes! What are the most logical steps I should take? I see so much very useful information here. Most importantly...is my son safe in the car when the lights are on?
LR2010 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 5 01-17-2015 06:46 PM
need new MAF - P1172, P1175 stolenheron Discovery Series II 21 03-23-2009 10:58 AM
Trouble codes - what should I do? BlackSVT Discovery Series II 7 03-13-2009 09:37 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 06:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 08:16 AM
You may post new threads
You may post replies
