ABS MODULATOR FIX (NO more SVS fault) - Page 9 - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #121 of 137 (permalink) Old 07-22-2014, 12:50 PM
LANJ66
lanj66's Avatar
Quoted: 1 Post(s)
Garage
Hey guys FYI....
*** the ORANGE plug, located in between the expansion tank and the fuse box, must be nice clean and dry, if is wet will get corrosion, and three amigos will come to stay, showing rear hubs sensors codes and more, so keep this plug greased with dielectric grease to keep water out of it ..
BEEN THERE DONE THAT
RANGE ROVER CLASSIC 1976/ALL THE TOYS
DISCO 2003, ARB/HELLA 4000/K&N AIR FL/ BF 285/65R18, OIL PRESS GAUGE Terrafirma Lift Kit @2''.
2008 LR2. (Wife)
lanj66 is offline
post #122 of 137 (permalink) Old 09-12-2014, 08:23 AM
Quoted: 1 Post(s)
The link for the repair is down. Does anyone have a copy saved somewhere?
'00 D2- D1 wiper conversion, 22" LED light bar, 265/75/16 BFG AT's
(sold)'94 FZJ80 with lockers & other stuff
AlexJ is offline
post #123 of 137 (permalink) Old 10-03-2014, 07:50 AM
Quoted: 0 Post(s)
Hi folks. Just bought my first Disco II and I am really excited about it, she's a beaut Clark! I researched it ahead of time and when I went to see it, she had the 3A's. Not a big deal, as I am pretty handy with the mechanical upkeep of vehicles. I was wondering though, the url link is dead so does anybody have a copy or different address for the super write up that everybody used to fix it? It sure would be handy to not have to comb the internet for another. Thanks in advance. ~Ryan
BeastyBlack is offline
post #124 of 137 (permalink) Old 10-10-2014, 12:29 PM
Quoted: 0 Post(s)
here is a link to the webpage with the info needed for the fix.
most of the pictures are stil there. here is the archived link...
ABS Mod - LAND ROVER CLUB V.I.
Hope this helps some of you out.
01 Discovery 2 SE7 4.0, 178k miles. 160k when I bought her.
Bosch 14v 150a Alternator, Bosch platinum plus 4 w/ Kingsborne 8mm IGN 790, New Coil Packs, Replaced IAC Valve, Purge Valve, o2 Sensors, Rotella T 15w x 40 w/ Lucas Oil Stabilizer, Purolator Oil Filter #L40316. Abs Mod Fix Option B, Front wheel abs sensors, Brake Stop Switch. Rotary Coupler...
Coming Soon - lift, tires, inline thermostat mod, electric fans, head gaskets / engine rebuild.
MetalMarine is offline
post #125 of 137 (permalink) Old 04-28-2015, 04:52 PM
Quoted: 2 Post(s)
Link above me is down. I would really like a guide to the OPTION B, abs amigo says 114 shuttle valve, was gonna give this fix a shot. Any help really appreciated.
found the shuttle valve link but not the abs link working
http://landroverclubvi.weebly.com/abs-svs-seals.html
ok im a knucklehead...
http://landroverclubvi.weebly.com/abs-mod.html works
psichotic is offline
post #126 of 137 (permalink) Old 12-12-2015, 09:36 PM
psychoideas's Avatar
Quoted: 0 Post(s)
Great information!
I have an abs light and the brake light on all the time. My friend tried to read the fault codes with his scan tool but it says that it is unable to connect to my ECU. It works fine on his three Discovery 2s.
someone suggested that this failure to connect is related to an earth fault but there are too many to check and i dont know where they all are.
As it turns out the single wire connected to the abs unit is the one that drives the light on the dash so I just unplugged it.
I have no ABS or HD but i dont have an annoying dash light either.
psychoideas is offline
post #127 of 137 (permalink) Old 05-16-2017, 12:21 PM
Drives like an old man
discomania04's Avatar
Quoted: 44 Post(s)
Garage
Reviving this old thread because a question arose. Mentioned above is the orange connector in between the expansion tank and fuse box. On my vehicle, there is nothing connected to this plug. What would normally go there? Likely some option I don't have, like air suspension, ACE or heated windshield, I'm guessing.
2004 Disco II, bone stock, now weekends only
discomania04 is offline
post #128 of 137 (permalink) Old 05-16-2017, 07:28 PM
sierrafery's Avatar
Quoted: 246 Post(s)
As the man who mentioned the "orange plug" said that neglecting it can cause 3 amigos with rear sensor codes i presume he meant GREY plug C0392/0378 cos that's the only one on the rear sensor's circuit and it's NEAR the ORANGE plug C0377/0391 which is involved in the SLS and ACE management as you well presumed, the orange C0377 plug has nothing to do with ABS, i know that from my own experience too cos the grey plug used to suffer from oil ingress by calpilary action through the wires from the injector loom on Td5s and the oil acts as insulator in the pins causing rear sensor fault codes... i cropped just few relevant parts from the diagrams but if you check them all you'll see that @ian66 who brought that up was not spot on
ID:	76849   Click image for larger version
Name:	ABS circuit C0378.jpg
ID:	76857   Click image for larger version
Name:	ACE circuit C0377.jpg
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #129 of 137 (permalink) Old 05-17-2017, 06:57 AM
Quoted: 44 Post(s)
Garage
Thanks, Fery. I appreciate the diagrams.
post #130 of 137 (permalink) Old 12-25-2017, 08:13 AM
Mangoeater2's Avatar
Quoted: 1 Post(s)
Hi Your link is now invalid. It sends you to a site that is trying to install various programs (probably including Trojans). Is it possible to get your write up about the ABS fix put up as a Sticky?
Mangoeater2 is offline
post #131 of 137 (permalink) Old 01-06-2018, 04:38 PM
Quoted: 2 Post(s)
Does anyone have this info archived? The link installed a Mac virus. I have the 3 amigos intermittently, and when they are on the ABS doesn't work and neither do the blinkers (and maybe other things I'm not aware of!). Sounds like option B would be for me?
halmic is offline
post #132 of 137 (permalink) Old 01-06-2018, 07:29 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Go back to post 125, no virus in those links
redtruck12 likes this.
post #133 of 137 (permalink) Old 01-17-2019, 02:52 AM
Quoted: 86 Post(s)
The very original post with the link to the original write up ( so i can take it from the top, so to speak ) goes to like a toyota ad.
Can anyone point me to the original, conprehensive ABS 3 amigo write up?
Thx.
sobieski is offline
post #134 of 137 (permalink) Old 01-17-2019, 05:45 AM
Quoted: 58 Post(s)
Thx.
I couldn't find it either Mike but I was able to locate the PDFs on the below link. I was going to post the PDFs but they were too big by quite a bit.
https://landroverforums.com/forum/di...abs-fix-71905/
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is online now
post #135 of 137 (permalink) Old 01-18-2019, 09:56 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Here is the hystorical link from post 1 https://landroverclubvi.weebly.com/abs-mod.html though it's no need to do the whole job cos it's doable with the modulator in situ but the informations from the link are very elaborated
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 5 01-17-2015 06:46 PM
need new MAF - P1172, P1175 stolenheron Discovery Series II 21 03-23-2009 10:58 AM
Trouble codes - what should I do? BlackSVT Discovery Series II 7 03-13-2009 09:37 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 06:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 08:16 AM
You may post new threads
You may post replies
