Add me to the list of needing head gaskets! - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 20 (permalink) Old 07-07-2019, 06:16 AM Thread Starter
DiscoGreg's Avatar
Quoted: 9 Post(s)
Garage
Well my time has come it seems. My 2004 Disco 2 with 106,000 miles just gave up its head gaskets. Here are my symptoms:
1) Noticed a slow creep up of temps with AC running on a hot day (80+ degrees outside)
2) Turning AC off seemed to settle the truck temps down
3) Noting this a few times, I decided to:
a. replace water pump
b. replace fan
c. replace fan clutch with heavy duty
d. move to 180 degree thermostat
e. replace various coolant hoses
f. complete flush of rad and coolant system
g. vacuum replacement of dexcool
h. replaced serpentine belt
i. checked several times for any air-pockets, which found none after settling and cooling off overnight
I triple checked all the installation - the hoses are hooked up correctly to the thermostat; serpentine belt on correctly; fan spinning correct way.
Sadly after this overhaul, the over-heating actually seemed to then be worse, coming on even quicker. I obtained a new scan-guage unit to watch temps more accurately and saw them blow through the 200 mark and up into 230....now 240....yikes - 250! I quickly turned off the AC and blasted the defroster on high heat to dissipate the engine temps and that would bring it back to 225ish so I could get it home.
Last note, my condenser fan was seized and had blown the fuse. Not sure how long this was not functioning but Im sure this added to the over-heating issue and AC efficiency...
Last little bit of insult to injury: As I was trying to drill out the rusted screws for the AC Condenser fan, the drill bit slipped and I went right through the condenser itself, exploding that in my general direction. Now let's add a new condenser and that install to the mix!
Any other thoughts as to the overheating issue - sounds like a clear case for head gaskets? Hopefully not a slipped sleeve!
**2004 Discovery 2**
(Amigo free since March 28, 2018)
**1994 Defender 90**
**1997 Defender 90 SW**
DiscoGreg is offline
post #2 of 20 (permalink) Old 07-07-2019, 06:40 AM
very disco
reverendALC's Avatar
Quoted: 7 Post(s)
i'm on my fifth disco, and the one thing that i've learned is that the overheating results in the blown head gasket, usually caused by the block failure. i really truly hate to see people spend hours of their own time or thousands of their own dollars replacing head gaskets just to have them blow again.
2003 Disco 2 SE7 - going to be buried in it
2006 RR Sport HSE - project
1997 Disco SE - SOLD
2003 Disco 2 SE7 - SOLD
1995 Disco SE - SOLD
2001 Disco 2 SE - SOLD
reverendALC is offline
post #3 of 20 (permalink) Old 07-07-2019, 09:20 AM Thread Starter
DiscoGreg's Avatar
Quoted: 9 Post(s)
Garage
Disappointing to hear. Once I get this thing apart, Im told I can simply run a straight edge across the top of the block to visually check for a slipped sleeve. Is that the only block failure you might suspect? What did you do with your old ones that had this situation - replace the block or part it out?
post #4 of 20 (permalink) Old 07-07-2019, 06:19 PM
very disco
Quoted: 7 Post(s)
I parted ways with them at the time, relinquishing command to those with funds available to do what they would. I have no idea which direction they went, but I still see my old gold ‘03 around town from time to time (and it’s not ticking anymore!).
My current ‘03, I sent off for engine remanufacture. Lots of folks will use top hat liners in the OEM block, but the guys who I sent mine off to use a different (not native to discovery) block which doesn’t have the inherent flaws which result in this situation.
Craigslist and offerup are LOUSY with $1500-3500 discovery 2s, which just had the head gaskets replaced but are still overheating. That’s exactly how I bought mine, for a meager $1960.
post #5 of 20 (permalink) Old 07-07-2019, 06:26 PM
very disco
Quoted: 7 Post(s)
I forgot to add, that the blocks can crack behind the sleeves, and you should really rely upon a pressure test. Me not being so equipped, and being quoted $16,000 by performance prep to take the whole thing down and rebuild from scratch, I chose a different route.
I paid $12k and got a reman engine, rebuilt tranny, diff and rear end. Honestly I’m over 16k into this disco right now, but it was never a value proposition to begin with.
post #6 of 20 (permalink) Old 07-08-2019, 11:18 AM Thread Starter
DiscoGreg's Avatar
Quoted: 9 Post(s)
Garage
Wow - Im just torn about completely giving up on it... Im debating between trading it in on another car or putting the big bucks into it. I can take the off chance that all I need are headgaskets and maybe I will luck out. But if there is a hairline crack or something that needs pressure tested to determine this, I will need to take it somewhere for that help and then its more $$$.
I can detach from the emotion of the truck and my time working on it and enjoying it; but I wonder what I can get out of it... Edmunds says its worth a whopping $1250. Sad. I might consider parting it out. I have a few choice items I think that would be worth more than $1250.
Any other thoughts anyone? Keep and invest the money, or gracefully bow out.
post #7 of 20 (permalink) Old 07-08-2019, 12:10 PM
very disco
Quoted: 7 Post(s)
I have been on again/off again with rovers over this issue. I absolutely love the trucks and decided to find one that I would keep forever, and not try to “pencil it out” but just commit and dive in. I married my disco without a prenup expecting to take a bath.
If your heart says go for it, don’t take the maybe route.
Otherwise I’m sure the forums would be happy to help you pick it apart.
The other option would result in bad karma.
post #8 of 20 (permalink) Old 07-12-2019, 07:19 AM
Quoted: 0 Post(s)
I had to change out my radiator, it was fouled up on my 1st disco
bcameron70 is offline
post #9 of 20 (permalink) Old 07-12-2019, 10:06 AM
G4 Mike
strap302's Avatar
Quoted: 11 Post(s)
Garage
Atlantic British sells a rebuilt long block for about $7000. You maybe can buy a decent car for $7000 but even after you drop the engine in the Disco 2 it won't be worth more than $7000. So if the rest of the Disco is good and you like it you just have to weigh your love of the truck versus what can I replace it with for $7000.
Only thing I might consider is the new Ford Bronco coming in 2020 but what will those cost? $40k? I bet the MSRP will be right there with the Jeep Wranglers. But no self respecting Land Rover guy would drive a Jeep, right? :-)
strap302 is offline
post #10 of 20 (permalink) Old 07-14-2019, 12:15 PM
very disco
Quoted: 7 Post(s)
elite J/LR in california will do a fully reman engine top and bottom for $6K, probably around $7K with freight there and back. i've been very happy with the job they did for me.
post #11 of 20 (permalink) Old 07-14-2019, 02:41 PM
member
SafariDave's Avatar
Quoted: 133 Post(s)
Or do an engine swap.
https://www.alternativeconversion.co...conversion-kit
Dave
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my girl's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
post #12 of 20 (permalink) Old 07-14-2019, 04:50 PM Thread Starter
DiscoGreg's Avatar
Quoted: 9 Post(s)
Garage
Well, Im going to retire my old girl for now. I cant invest the money nor time just yet to do the work. Thanks for the suggestions on the alternatives - Im looking into these now for certain!
Thanks - Here she sits now, but not for long!
post #13 of 20 (permalink) Old 07-14-2019, 05:47 PM
very disco
Quoted: 7 Post(s)
You're going to put that bad boy out to pasture!?!? I can't say i blame you, I've done it on more than one occasion, and am just thankful i'm at a point in my life where I could really get after it.
it's a tragedy, that's a quality example of the breed.
are you going to circle back to it later, or let the vultures come sweeping in?
post #14 of 20 (permalink) Old 07-14-2019, 07:12 PM Thread Starter
DiscoGreg's Avatar
Quoted: 9 Post(s)
Garage
Not totally sure just yet. Its been a fantastic Winter vehicle and I may try to decide after the summer is over. Hopefully a solution that seems correct will present itself in the next few months.
Do we all see the HG issue only on the 4.6's or do they have the same fault in the older 4.0 engines too? I ask because Im looking at older Disco's as a potential replacement.
post #15 of 20 (permalink) Old 07-14-2019, 10:02 PM
very disco
Quoted: 7 Post(s)
I’ve had two 4.0s, and while they weren’t without their own subset of issues (electrical!!!!), the motors were good to me. Parted ways with them at 160k and 180k approximately, and they were going strong with nothing other than PM.
I love the disco1, it has a much more utilitarian feel to it. If I could have those d1 style door handles on my d2 I would do so in a heartbeat. My best memories were having the nice 03 and the old 95 simultaneously so I could beat up the 95 and daily drive the 03.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
