Alarm problems - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 02-02-2017, 11:09 PM Thread Starter
Quoted: 0 Post(s)
Alarm problems
Hi, I have a 2001 Landrover Discovery series 2. Randomly after I lock the car the alarm goes off. I doesn't go off straight away it seem to happen within the next hour or so. It has been happening when I lock it up in the car park at work and sometime later it goes off. It pars to be happening on hot days. Any advice would be appreciated. I tried to find the door switches to check them but I cant locate them. Thankyou in advance.......Tass
Tass is offline
post #2 of 6 (permalink) Old 02-03-2017, 09:23 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Hi, in most cases this symptom is caused by the volumetric sensors... lock it with key in the lock not with fob for test cos this disables the volumetric alarm only and if the alarm will rest this way that's it... they used to suffer from corrosion or just simply fail cos it's a PCB with integrated circuits... also this can happen if it's windy outside and the door seals are not sealing well, or a moth trapped in cos the volumetric alarm is triggered by air movement in the cabin
here's a sample
Name:	volumetric sensor D2.jpg
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 6 (permalink) Old 02-03-2017, 11:59 AM
Quoted: 531 Post(s)
The knowledge base on this board is amazing.
Where is that PCB located and what causes the corrosion?
CT090 is offline
post #4 of 6 (permalink) Old 02-03-2017, 12:07 PM
Drives like an old man
discomania04's Avatar
Quoted: 45 Post(s)
Garage
The picture in the RAVE isn't super clear, but it looks to be above the headliner around the B-pillars.
2004 Disco II, bone stock, now weekends only
discomania04 is offline
post #5 of 6 (permalink) Old 02-04-2017, 12:37 AM
sierrafery's Avatar
Quoted: 246 Post(s)
That's a pic from the front volumetric sensor,'s internals... there is one above the sesat belt too... usually leaking sunroofs or condensation, watch the headlining and you'll see this:
Name:	volumetric sensor.jpg
post #6 of 6 (permalink) Old 04-09-2019, 10:43 AM
Quoted: 0 Post(s)
Post Beware the spiders
I found the problem with my volumetric alarm : A couple of spiders had made their home in there. Cleared them and their web away with a stiff brush and the alarm is working fine again.
Pottss is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Alarm Problems - Please Help Crazy Diamond Discovery Series I 4 11-13-2011 09:31 AM
Alarm problems..disco 2 locksmith7196804 Discovery Series II 1 03-14-2011 03:57 AM
Big Alarm Problems! leroyyy Discovery Series I 1 02-26-2010 06:46 PM
P38 Alarm/Key problems Please HeLp! commando87 Range Rover P38, Mk III and Range Rover Sport 8 10-14-2008 06:43 PM
alarm problems on discoverys sussexwallties Discovery Series I 1 04-09-2006 09:00 AM
You may post new threads
You may post replies
