BFG K02's 245 70 16's or 245 75 16's? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 16 (permalink) Old 01-25-2019, 07:06 PM Thread Starter
member
SafariDave's Avatar
Quoted: 131 Post(s)
Need some All Terrain tires for the Caribbean. The Island gets strong rain storms, so they need to be good in hard rain, wet roads also muddy spots, sand and rocks. Thinking of BFG K02's. Wondering how good they are in the rain, mud and sand?
What's the best size 245 70 16's or 245 75 16's? How much room for flex with the 75 with no lift.
Right now I have 245 70 16's all season.
Thanks,
Dave
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my girl's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
post #2 of 16 (permalink) Old 01-26-2019, 06:28 AM
redtruck12's Avatar
Quoted: 280 Post(s)
Garage
It’s been a while since I had stock size tires😉but as I recall stock was 255/65r16??
Both of your choices are 245mil bead to bead (smaller) than stock.
The 70 series being 5% more sidewall / 5% less footprint and the 75 being 10% more sidewall 10% less footprint so substantially narrower in appearance. Both should clear but will handle at speed different than stock. That on top of being a very square shoulder design.
I think I would lean towards the wider of the 2 (245/70) over the narrower (245/75)
Are you really going to put it to a full flex???
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #3 of 16 (permalink) Old 01-26-2019, 06:56 AM Thread Starter
member
SafariDave's Avatar
Quoted: 131 Post(s)
I rather go narrower and taller to lower the air on tires to drive on sand. There are a lot of sharp rock areas also that you need to cross to get to hidden beaches.
I know that the stock size is 255 65 16 for the D2. But I rather go just a bit narrower and 1" taller. The truck came with 245 70 16's, which is 1/2" taller or so than the stock tire. Thats why I was thinking 245 75 16 and lowering the pressure when driving on sand. BFG KO2's do come in the 245 70 16's.
What size tires do you run?
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #4 of 16 (permalink) Old 01-26-2019, 09:50 AM
redtruck12's Avatar
Quoted: 280 Post(s)
Garage
I hate math 🤥
But....
245/70 = 73.5mm road contact width with 171.5mm sidewall (85.75 each)
245/75 = 61.25 road contact width
183.75 mm sidewall (91.875 each)
Stock 255/65 = 89.25mm road contact width,
165.75 mm sidewall (82.75 each)
So....
In actuality doing the math 245/75 is only 1/4inch taller than the245/70 and less than 1/2 inch narrower.
That said the rolling diameter is also different (I’m not going to get into Pi calculations)
The tallest sidewall is of course the 75 series tire but even that is only9.125mm ( .359” )taller than stock.
I can see the taller sidewall but why do you want narrower?
I wonder if taller but similar width or even a bit wider may work better for you.
The 245/75 is 28mm (1.1”) narrower and really only a bit more than 1/3” taller!
Still only about an inch (28.6mm) rolling diameter over stock size
Got to love those numbers eh!
Remember an inch taller is a lot and more than 3” rolling diameter
If it’s an inch taller you really want then you will need to go much bigger than a 245/75r16
Someone stop me😆
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #5 of 16 (permalink) Old 01-26-2019, 11:15 AM
Quoted: 58 Post(s)
I went 245/75 R16 AT. I get no rub and I like the look a lot better.
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #6 of 16 (permalink) Old 01-26-2019, 11:16 AM Thread Starter
member
SafariDave's Avatar
Quoted: 131 Post(s)
I hate math 🤥
But....
So....
That said the rolling diameter is also different (Im not going to get into Pi calculations)
The tallest sidewall is of course the 75 series tire but even that is only9.125mm ( .359 )taller than stock.
The 245/75 is 28mm (1.1) narrower and really only a bit more than 1/3 taller!
Remember an inch taller is a lot and more than 3 rolling diameter
If its an inch taller you really want then you will need to go much bigger than a 245/75r16
Someone stop me😆
So you are saying 255 70 16? instead of the 245 75 16.
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #7 of 16 (permalink) Old 01-26-2019, 11:47 AM Thread Starter
member
SafariDave's Avatar
Quoted: 131 Post(s)
Michael any pics? Thats the size I was thinking of in the BFG KO2's
Thanks,
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #8 of 16 (permalink) Old 01-26-2019, 12:03 PM
redtruck12's Avatar
Quoted: 280 Post(s)
Garage
You can play with the basic numbers on sites like
https://tiresize.com/comparison/
Maybe consider lt 255/75r16 if you want an inch
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #9 of 16 (permalink) Old 01-26-2019, 12:13 PM
Quoted: 58 Post(s)
Thanks,
Dave
Yeah - in my album. The bumper album - pic with the cracked bumper is the old tires. The end result is the newer ones.
If I had it to do over again, I would have done these - knowing what I know now. I didn't do them before because it looked to be I would have some minor rubbing. Then I did my springs & shocks and then the bumper etc and now I have plenty of room. Talk about a kick between the legs...
Michael
'01 LR Disco II SE7
post #10 of 16 (permalink) Old 01-26-2019, 06:44 PM Thread Starter
member
SafariDave's Avatar
Quoted: 131 Post(s)
Saw the pics, the lift looks good, and I see what you mean. you did not really need the a lift with that tire size. I also like the gold color of the D2. It looks great when you remove the black plastic fenders on the gold color gives it a more rugged utilitarian look. Like the one on this picture with the bull bar. Its a great look. Looks like he has 265 75 16 BFG K02's. A bit too big for my needs.
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #11 of 16 (permalink) Old 01-27-2019, 11:51 AM
Quoted: 58 Post(s)
Dave
It's got me thinking...
Michael
'01 LR Disco II SE7
post #12 of 16 (permalink) Old 01-27-2019, 06:14 PM
redtruck12's Avatar
Quoted: 280 Post(s)
Garage
So if you 255/75r16
Would be your choice ??
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #13 of 16 (permalink) Old 01-28-2019, 01:18 AM
p76rangie's Avatar
Quoted: 384 Post(s)
Just remember that the 245 is not the width of the tread. It is the width of the widest part of the sidewall. The actual width of the tread can vary considerably between different brand/model of tyre. I have had 255 tyres where the tread was narrower than a 235 tyre. The tyres that have tread running down the sidewalls (like the BFG K02) usually have the widest tread on the ground.
For sand driving you want as wide a tyre as possible with an aggressive tread.
p76rangie is online now
post #14 of 16 (permalink) Old 01-28-2019, 04:21 AM Thread Starter
member
SafariDave's Avatar
Quoted: 131 Post(s)
So if you 255/75r16
I think 255 75 16 might be too big for stock hight?
Still thinking 255 70 18. I don't really want such a big tire.
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #15 of 16 (permalink) Old 01-28-2019, 04:37 AM Thread Starter
member
SafariDave's Avatar
Quoted: 131 Post(s)
The reason I want an AT and not an MT tire is because I will be mainly on road, then off road to get to hidden beaches through sand, sharp rocky areas and some green lawn areas. But the island gets hit by quick punding rain storms that flood areas, So I want to make sure I don't hydroplane while driving on poorly kept roads from the storm. That's why I thought of the K02's since I don't want a lift. I want at least a 1" hight tire so I can deflate the tire to drive on sand. So still thinking of 245 75 16 or 255 70 16. 255 75 16 might be to big to fit without a lift. Is the D2 16" rim too big for a 245 should I stay on a 255? Keep thinking that taller is better than wider for deflating reasons. When you deflate a taller tire you have more foot print.
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Who has bfg K02's in 265 65 18 on LR3 or LR4? SafariDave Discovery 3 / LR3 6 05-12-2016 02:20 PM
Need Pictures of 245/70/16, 255/70/16 and 245/75/16 on Stock-Height Disco II Emperor_MA Discovery Series II 1 12-27-2012 05:13 AM
WTB: 265/75/16 or 245/75/16 in MD jdhuegel1 Land Rover Parts and Vehicles Wanted 3 07-07-2010 07:35 AM
FS: (5) BFG AT 245/75/16 tires (4 used, 1 new) HaroldC Land Rover Parts and Accessories 1 11-29-2007 01:19 PM
245/75/16 KM or 245/75/16 KO ? estbnqr Wheels and Tires 10 01-06-2006 07:10 AM
You may post new threads
You may post replies
