Blue Devil Head Gasket Sealant problem - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #1 of 68 (permalink) Old 03-27-2010, 08:56 AM Thread Starter
imag's Avatar
Quoted: 0 Post(s)
I think that I am screwed.
I had a slight coolant leak on my Disco (2001, 114K miles) which seemed to be at the back of the engine, which I thought I can cure with "Blue Devil's Head Gasket Sealant". I followed the instructions on the bottle: empty enough coolant for BlueDevil contents to fit; start engine from cold; heating set to max; pour BlueDevil contents SLOOOOOWLY (took about a minute), close coolant cap, let idle to 50 minutes.
Well, after 30 minutes the temperature (by ScanGauge) had reached a never seen before (on this car) temp of 247 deg... and climbing. Electric fan was running at that stage. I eventually chickened out and switched the engine off. An hour later I opened the coolant reservoir and noticed that the liquid is now gel.
I tried to call the BlueDevil "hotline, but their office hours are Mon-Fri, not Saturday.
Does anybody have any good ideas of what I should do next, as I don't think I should be driving with gel cooling.
BTW - my cooling liquid was pretty well maintained with the orange stuff (GM DexCool).
Help is much appreciated.
2001 Discovery SE7, 130K miles - RIP
imag is offline
post #2 of 68 (permalink) Old 03-27-2010, 09:06 AM
member
SafariDave's Avatar
Quoted: 141 Post(s)
Did you use the white lable or yellow lable?
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my wife's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
post #3 of 68 (permalink) Old 03-27-2010, 09:17 AM
Administrator
Quoted: 5 Post(s)
Did you have any over problems before you added the Blue Devil? Did you have the hood down when the engine was idling, if not that can cause the problem cause you won't draw enough air thru the radiator to keep the engine cool.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #4 of 68 (permalink) Old 03-27-2010, 10:29 AM Thread Starter
imag's Avatar
Quoted: 0 Post(s)
I used the Yellow label stuff.
I had the hood up.
Any ideas what to do now?
imag is offline
post #5 of 68 (permalink) Old 03-27-2010, 10:38 AM
Quoted: 0 Post(s)
i never looked at the Blue Devil stuff but doesn't sodium silicate crystalize into liquid glass on contact with coolant
I think it works by removing all coolant and just use it with water. Then it will crystalize when it leaks into the hotter combustion chamber and thereby form a seal of liquid glass. that supposedly plugs the head gasket defect. it sounds like it crystalized in your radiator and other coolant passages though.
i would guess you need a new radiator and you need to take the heads off and try to scrape all the gel out.
tuno is offline
post #6 of 68 (permalink) Old 03-27-2010, 10:42 AM
member
SafariDave's Avatar
Quoted: 141 Post(s)
Did you follow the instructions for the YELLOW lable you are supposed to flush out old coolant and take out the thermostat. ONLY for the WHITE lable is pour and go leaving thermostat on.
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #7 of 68 (permalink) Old 03-27-2010, 10:51 AM
member
SafariDave's Avatar
Quoted: 141 Post(s)
I think the main reasons why a lot of these liquid seal don't work is because people don't follow instructions or their headgaskets, rads, cores and cooling systems are in real bad shape by the point they use it.
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #8 of 68 (permalink) Old 03-27-2010, 11:14 AM Thread Starter
imag's Avatar
Quoted: 0 Post(s)
The instructions on the bottle itself do not state anything about removing the thermostat.
The FAQ for the product on the web does state to remove the thermostat.
That kinda sucks for me.
They also say the following in the FAQ:
"I tried the product and my radiator has a white crystalline deposit or jell, what is this?
These are telltale signs of a radiator that is in need of service. When fluids are not changed often enough under severe operating conditions or in areas with hard water, scale deposits form in the passages of the core. Sometimes the old fluids will jell or crystallize and can be seen in the system. To remove these deposits flush cooling system using a flushing agent or a flushing machine."
So, I guess that I have to flush the cooling system completely. Great.
Where is the bets place to start?
imag is offline
post #9 of 68 (permalink) Old 03-27-2010, 11:20 AM
member
SafariDave's Avatar
Quoted: 141 Post(s)
Prestone makes a flushing product.
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #10 of 68 (permalink) Old 03-27-2010, 01:31 PM
Quoted: 11 Post(s)
What did you expect when you took such a dangerous shortcut with your truck?
If your head gaskets are leaking, VooDoo juice ain't gonna save you.
Now, the job is three times as big, and likely four times as expensive.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
PTSchram is offline
post #11 of 68 (permalink) Old 03-27-2010, 01:33 PM
Quoted: 11 Post(s)
It first forms a really cool gel-like goo. Eventually, it will soldify, but not until it drives the water out.
260-804-0458
PTSchram is offline
post #12 of 68 (permalink) Old 03-27-2010, 01:52 PM
Quoted: 0 Post(s)
Ain't that a bitch! Mechanic in a can strikes again! You probably could have gotten away doing the head gaskets yourself for about $500 including the bill from the machine shop. Every time I have seen someone use stuff like that it ends badly. Unfortunately at this point you still need the head gaskets done, and probably most of the cooling system replaced. I have yet to see any product that will get that stuff out of the system without doing even more damage.
osiristheclown is offline
post #13 of 68 (permalink) Old 03-27-2010, 02:47 PM Thread Starter
imag's Avatar
Quoted: 0 Post(s)
So I guess that tomorrow I will start flushing and flushing.....
imag is offline
post #14 of 68 (permalink) Old 03-27-2010, 03:24 PM
member
SafariDave's Avatar
Quoted: 141 Post(s)
Flush each part separete. disconect the hoses to the rad, to the heater core and hose with soft pressure each area. put hose to the hoses that go to the heater core and flush it both ways this should help, then also into the block.
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #15 of 68 (permalink) Old 03-27-2010, 04:36 PM Thread Starter
imag's Avatar
Quoted: 0 Post(s)
Thanks SafariDave.
imag is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Head Gasket - Water Pump, Front Cover Gasket? TNRRClassic Range Rover P38, Mk III and Range Rover Sport 2 08-09-2010 05:03 AM
Please Help -- Head Gasket and Liner Problem BayAreaDiscovering84 Discovery Series I 2 07-24-2009 03:05 PM
4.2 L oil pan/timing cover - what gasket sealant to use? deadboy1977 Range Rover Classic 9 08-12-2008 01:13 PM
Exhaust Leak = Head Gasket + Warped Head ealex Discovery Series II 1 05-23-2007 12:29 PM
K Series head gasket problem dearot Freelander / LR2 14 10-07-2005 02:20 AM
You may post new threads
You may post replies
