Blue Devil Head Gasket Sealant problem - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #16 of 68 (permalink) Old 03-28-2010, 04:14 AM
p76rangie's Avatar
Quoted: 385 Post(s)
Originally Posted by imag View Post
So I guess that tomorrow I will start flushing and flushing.....
Are you sure the whole system is like the header tank. You might find the rest not as bad.
p76rangie is offline
post #17 of 68 (permalink) Old 03-28-2010, 05:38 AM
lipadj46's Avatar
Quoted: 0 Post(s)
It's funny the same stuff they use to kill CARS engines is a miracle head gasket cure.
2002 DII 114,000 miles
lipadj46 is offline
post #18 of 68 (permalink) Old 03-28-2010, 06:28 AM
Quoted: 11 Post(s)
Clearly, it is not a miracle head gasket cure.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
PTSchram is offline
post #19 of 68 (permalink) Old 03-28-2010, 08:58 AM Thread Starter
imag's Avatar
Quoted: 0 Post(s)
So, I flushed it out this morning, gallons and gallons, this way and that way. The header tank was definitely the worst. Cleaned the header tank and thermostat really well. I think that a lot of gel was on the thermostat, not opening it to open up much, thus the overheating.
I ran the car a few miles, now - everything seems good. Just got the "swooshing" sound in the interior, so the heating has likely got air pockets.
2001 Discovery SE7, 130K miles - RIP
imag is offline
post #20 of 68 (permalink) Old 03-28-2010, 02:39 PM
p76rangie's Avatar
Quoted: 385 Post(s)
It appears to be like most things, if you do not read the instructions you run the risk of stuffing things up.
post #21 of 68 (permalink) Old 03-28-2010, 02:46 PM
lipadj46's Avatar
Quoted: 0 Post(s)
liquid glass is nothing I'd want in my engine.
lipadj46 is offline
post #22 of 68 (permalink) Old 03-28-2010, 03:25 PM
member
SafariDave's Avatar
Quoted: 141 Post(s)
I've researched the web to find that various car companies use liquid seal products as a preventive mesure for coolant leaks, GM is a big example they use Barr leaks.
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my wife's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
post #23 of 68 (permalink) Old 03-29-2010, 05:35 AM
Beach Bum
Quoted: 0 Post(s)
My external leak is slowing dramatically after I drained, bled and added 1/4 bottle of pour and go. Looks like the "shit that doesn't work" is going to buy me some time. Here is a good read, funny how Bar's has been in business since 1947 making something that doesn't work.
Bar's Leaks History
brian4d is offline
post #24 of 68 (permalink) Old 03-29-2010, 05:54 AM
DiscoDream2's Avatar
Quoted: 1 Post(s)
Buy time, correct, fix the issue, NO. Nobody said it wasn't going to work. You could throw a hand full of saw dust in there and eventually it will stop the leaking too.
My previous experience with stop leak stuff was as a temp measure to get you down the road far enough to get it fixed. As a crazy teen, I burnt up a couple motors due to heat. The second time was a stop leak product gone bad. Clogged up the thermostat and overheated the engine. Since then, no way..
The anxiety of knowing that some day the temp gauge is going to spike without notice, a hot water mixture of some sort will be try to escape out the overflow and your block will get twice as hot as it should... and BAM your worse off than before.
I am glad it is no longer leaking, I would't use it.
DiscoDream2 is offline
post #25 of 68 (permalink) Old 03-29-2010, 05:57 AM
member
SafariDave's Avatar
Quoted: 141 Post(s)
Sounds good! Which brand did you use Brian?
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #26 of 68 (permalink) Old 03-29-2010, 06:17 AM
Beach Bum
Quoted: 0 Post(s)
The issue with me is that it was just small enough of a leak to piss me off. On top of that a gasket that's only 16K old. Dave, I used the pour n go. I'm not sure if I'm out of the woods yet. I'm not seeing anything on the garage floor anymore and I can't identify the leak on the engine block. It may I have stopped completely but it's too early to tell.
brian4d is offline
post #27 of 68 (permalink) Old 03-29-2010, 06:21 AM
Beach Bum
Quoted: 0 Post(s)
Word games. Let's put it in perspective here. These head gaskets might last 40-80-100K new from the factory. My new set lasted only 16K. There are cars on the road with 200-300K on the originals. So IMO if it sealer will fix the problem for any duration it is a permanent fix giving the very early failure rate of these head gaskets.
Doug Higby likes this.
brian4d is offline
post #28 of 68 (permalink) Old 03-29-2010, 06:30 AM
member
SafariDave's Avatar
Quoted: 141 Post(s)
Pour and go, but what brand? BlueDevil? Bar's Leak?
I think once it seals it will last. I think it' a good alternative if the seals work for small leaks like ours.
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #29 of 68 (permalink) Old 03-29-2010, 07:15 AM
Beach Bum
Quoted: 0 Post(s)
BD, I'll let you know if it holds.
brian4d is offline
post #30 of 68 (permalink) Old 03-29-2010, 07:50 AM
member
SafariDave's Avatar
Quoted: 141 Post(s)
Thanks Brian. I think the other issue using the product is the way our cooling system is set up, pouring it in the expansion tank does not get it to flow fast as it needs to to the block. There has to be away of pouring it so it goes to the block before it passes throught the radiator or heater core.
Present Land Rovers
(my NYC LR3)
Past Land Rovers
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Head Gasket - Water Pump, Front Cover Gasket? TNRRClassic Range Rover P38, Mk III and Range Rover Sport 2 08-09-2010 05:03 AM
Please Help -- Head Gasket and Liner Problem BayAreaDiscovering84 Discovery Series I 2 07-24-2009 03:05 PM
4.2 L oil pan/timing cover - what gasket sealant to use? deadboy1977 Range Rover Classic 9 08-12-2008 01:13 PM
Exhaust Leak = Head Gasket + Warped Head ealex Discovery Series II 1 05-23-2007 12:29 PM
K Series head gasket problem dearot Freelander / LR2 14 10-07-2005 02:20 AM
You may post new threads
You may post replies
