Blue Devil Head Gasket Sealant problem - Page 5 - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #61 of 68 (permalink) Old 02-12-2012, 04:43 PM
Quoted: 0 Post(s)
My 2002 LR D2 135K has a coolant leak from the head gasket (drivers side). It's bad. What should i do? Repair it (just the left side or both?) or change the engine?.
faguirre is offline
post #62 of 68 (permalink) Old 02-12-2012, 06:26 PM
Administrator
Quoted: 5 Post(s)
You always do both head gaskets at the same time, make sure to get the heads checked. Are you going to be doing the job?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #63 of 68 (permalink) Old 03-05-2012, 09:20 AM
Colin Hughes's Avatar
Quoted: 0 Post(s)
My 1990 RRC had a very small coolant leak. LR tech friend said try Barrs Leaks. It worked. Bought my current 2003 D2 with a blown engine. Looks like it really needed HG's but the owner tried some of this crap and it totally destroyed the engine. The coolant ports in the engine were blocked, the thermostat was full of white qunk. If you need HG's, replace your head gaskets, it will be cheaper in the long run.
Colin Hughes is offline
post #64 of 68 (permalink) Old 03-05-2012, 12:39 PM
Administrator
Quoted: 5 Post(s)
One product that really works, and I am running it currently because of a slight leak at #8 and a radiator leak, is B&G's Coolant Stop Leak. There is nothing in it that will stick to or plug and area of the coolant system, no ceramics, no shavings of any kind like copper, aluminum and it does not glob up.
Need Parts?
Lucky8,
post #65 of 68 (permalink) Old 05-08-2012, 04:11 PM
Quoted: 0 Post(s)
Coolant Tabs
I just wanted to see if you guys and gals have used the Coolant Tabs that are put out by GM. I know that GM has used these for the last 20 years because of coolant loss on the Aluminm block and heads, and because of that sorry Dexcool used. I know for a fact that these tabs work. I crushed the package and added them to the upper hose and after about 10 miles there was NO coolant loss and no coolant smell. Now I know this is not a mechanic in a box but it is a great way to stop or slow down a coolant leak. These pellets run about $5 a card and they are made up of vegetable extract so there is no acid to eat away the gaskets.
2000 Land Rover Discovery II All stock.
2006 Harley Davidson Ultra Classic
rocketvette95 is offline
post #66 of 68 (permalink) Old 05-08-2012, 04:20 PM
Administrator
Quoted: 5 Post(s)
You will have problems, at some point because of the fine veins in the Rovers Radiators which will plug up with all that ground up crap in the GM tablets.
Need Parts?
Lucky8,
post #67 of 68 (permalink) Old 07-10-2013, 11:10 AM
WLADiscoII99's Avatar
Quoted: 215 Post(s)
These products work by making the liquid thicker to "plug" the hole. What do you think it does to the rest of your system?
WLADiscoII99 is offline
post #68 of 68 (permalink) Old 05-31-2018, 11:14 PM
Quoted: 215 Post(s)
I had a tow truck driver recommend this product to me recently ..
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Head Gasket - Water Pump, Front Cover Gasket? TNRRClassic Range Rover P38, Mk III and Range Rover Sport 2 08-09-2010 05:03 AM
Please Help -- Head Gasket and Liner Problem BayAreaDiscovering84 Discovery Series I 2 07-24-2009 03:05 PM
4.2 L oil pan/timing cover - what gasket sealant to use? deadboy1977 Range Rover Classic 9 08-12-2008 01:13 PM
Exhaust Leak = Head Gasket + Warped Head ealex Discovery Series II 1 05-23-2007 12:29 PM
K Series head gasket problem dearot Freelander / LR2 14 10-07-2005 02:20 AM
You may post new threads
You may post replies
