A/C won't blow... - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 25 (permalink) Old 08-06-2016, 03:14 PM Thread Starter
Quoted: 0 Post(s)
A/C won't blow...
I recently bought a 2004 Disco 2 and for the first week the A/C blew strong and ice cold, then on some forest roads one day the fan stopped working.
I checked the fuse and it was fine so after fiddling with the controls for a bit I just rolled with the windows down until it came back on. It lasted the rest of the day until it gave out right when I got home. Its been out ever since.
The controls come on and I can adjust everything just fine, I can hear the compressor kick on but the fan wont budge. I tried knocking on it to get it started and whatnot. I bench tested the fan and it kicked on fine. I swapped the fan speed resistor with one from another disco and it still didn't work. Nothing seems to work. I live in Texas where its normal for it to reach 105F midday.. Any help would be greatly appreciated.
parkerclegg is offline
post #2 of 25 (permalink) Old 03-27-2017, 10:23 PM
Brett James Futter's Avatar
Quoted: 0 Post(s)
@parkerclegg. Mate have you set the fan to full blast? It may be a blown resistor, when the fan is set to max it should bypass the resistor and you should get some nice ice cold air again. The resistor is found in the cabin in the foot well of the passengers side (I have a rhd model). It is quite a small box located quite high up toward the center of the panel. It's super easy to change. I had to change one in my truck recently and it's been a treat since. Hope that helps.
Brett James Futter is offline
post #3 of 25 (permalink) Old 03-28-2017, 01:27 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Rule out the power and blower relays, both near the fan, C901(power) and C153(blower) in the pic, also check voltage they both must have live on the light green/white wire in the plug and for the blower to work there must be voltage on the white/red wire of C153 and earth on black/red of C901....if no voltage there it's some wiring or contact issue on the feed path from F31 check connection in C0765 pin 1
ID:	76113   Click image for larger version
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #4 of 25 (permalink) Old 07-20-2017, 01:46 PM
Quoted: 0 Post(s)
You won't believe it..... I'm having the same friggin issue as Parkerklegg.
@sierrafery I did everything you mentioned and am getting 12V in all the places I'm supposed to. I have checked the resistor I have checked the fuses. Are there any relays that could affect the vent blower? I have pulled the blower motor and it tests fine. I have now given the blower motor to an aircraft avionics engineer and asked him to test it for me.
I can't see anything wrong with the system thus far..... any ideas.
Parkerclegg did you ever solve the issue?
post #5 of 25 (permalink) Old 07-20-2017, 02:26 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 106 Post(s)
Check power coming from the fuse panel. They break down and loose power going to certain circuits and the blower is one of those circuits
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #6 of 25 (permalink) Old 07-20-2017, 05:10 PM
sierrafery's Avatar
Quoted: 246 Post(s)
+1^^^, if you've got 12V with connectors unplugged it's irrelevant, when the blower is connected the 12V drops under it's load cos it's bad contact, usually at the fusebox
post #7 of 25 (permalink) Old 08-29-2017, 05:29 PM
Quoted: 0 Post(s)
Thanks guys will have a look at that today.
Much appreciated. I'll let you know what happens.
Cheers
Brett
post #8 of 25 (permalink) Old 08-30-2017, 02:00 AM
sierrafery's Avatar
Quoted: 246 Post(s)
If the blower works well with direct feed get hold of a piggiback fuse, remove fuse F7 interior fusebox, put the piggiback instead and splice into the brown/red wire of C431, it appears in the second pic in post nr 3. If this way the blower will work you need another fusebox eventually if you are lucky it's a bad contact in the plug, C0584 - pin 2(brown/red wire)
post #9 of 25 (permalink) Old 11-16-2017, 12:07 AM
Quoted: 0 Post(s)
Like Magic that fixed it.
I made a Video of the procedure if anyone wants.
Link:
Hope that helps some other poor fellow!
Cheers again for all the help.
post #10 of 25 (permalink) Old 11-16-2017, 12:47 AM
sierrafery's Avatar
Quoted: 246 Post(s)
There is strong live in the cabin too C0028 pin 1(brown wire) no need to bring a wire from the engine bay
post #11 of 25 (permalink) Old 09-11-2018, 02:50 PM
Quoted: 86 Post(s)
Ok, Sierra & Army pulling and reinserting the fuse worked for like a day.
Do I put a pigtail fuse into fuse #7 and splice the pigtail wire into the C0028 pin 1 brown wire
or
splice it into into the brown/red wire of C431 ?
thanks,
sobieski
sobieski is offline
post #12 of 25 (permalink) Old 09-11-2018, 03:57 PM
Quoted: 86 Post(s)
And I should say, as far as electrical goes, I am on baby-step Zero.
I tested the fuse #7 slot and got about 9 volts - what does that tell us?
sobieski is offline
post #13 of 25 (permalink) Old 09-11-2018, 04:21 PM
sierrafery's Avatar
Quoted: 246 Post(s)
or
thanks,
sobieski
Splice into C0028 -1 with a 30A in line fuse holder like in the pic, put a 30A fuse in it and splice with the other end into C431-2(brown red) and let F7 out
post #14 of 25 (permalink) Old 09-11-2018, 04:47 PM
Quoted: 86 Post(s)
Nice.
REALLY appreciate your (and eryone else's) expertise & experience - for you, especially on the electrical.
Is the C0028 to C431-2 definite or do I need to test the relay's before I snip those wires?
Like I said, babystep Zero.
sobieski is offline
post #15 of 25 (permalink) Old 09-11-2018, 11:27 PM
sierrafery's Avatar
Quoted: 246 Post(s)
As long as F7 made tricks i suppose the relays are OK so that bypass should fix things
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Please tell me what this is and if my front differental is going to blow blackpaw80 Discovery Series II 2 07-07-2013 03:48 AM
D2 Slider blow out sale! fivespddisco Land Rover Parts and Accessories 0 06-25-2012 05:36 PM
Detroit Locker Blow out fivespddisco Land Rover Parts and Accessories 6 02-08-2011 07:19 AM
Help Before I blow this thing UP!!!!!!!!!!!! jesuscowboy Range Rover Classic 14 08-24-2010 09:37 AM
Drivers Seat BLOW OUT!! biggdoggs1 Discovery Series I 8 08-05-2010 12:15 PM
You may post new threads
You may post replies
