Land Rover Forums : Land Rover and Range Rover Forum
Land Rover Forums : Land Rover and Range Rover Forum (https://www.landroversonly.com/forums/)
-   Discovery Series II (https://www.landroversonly.com/forums/f40/)
-   -   Cdl Kit Install Instructions (https://www.landroversonly.com/forums/f40/cdl-kit-install-instructions-32719/)
jycsalas 06-19-2009 10:52 AM
Hello All,
You no longer have to email me for this. Enjoy!
Rover Tech - Land Rover Club V.I.
Madison 06-19-2009 11:57 AM
Thanks! I think I'll be needing this soon.
(Can we still email you for it anyway? :) )
Jupiter Rover 06-19-2009 01:34 PM
Of course!!
lol
jycsalas 06-19-2009 02:07 PM
Originally Posted by Jupiter Rover (Post 278312)
Of course!!
lol
Of course and as an additional bonus I will include my write-up on installing muffler bearings and a flux capacitor. ;)
Topherhales 06-23-2009 09:08 PM
What about blinkerfliud ha mines low
jycsalas 06-24-2009 06:09 AM
I haven't done a write-up for that. That job is way over my head!
Topherhales 06-24-2009 01:30 PM
That was an old joke with my high school friends along with rebuilding your dip stick, hard work, cost a lot, we did not work at a shop or anything, just thought it was funny when friends asked what was wrong with there car! Especially girls! Cdl lock I need tho bad!
Topherhales 06-24-2009 08:25 PM
I'll be doing my cdl lock as soon as the misses ok's it but really I've been surprised how well it does open I've had opposite wheels off the ground onsome steep stuff, which my buddies built pathfinder and a couple others had to totally just back off and gun it! A few timesto get up! Rovers make everything look so smooth! Trac control does what it says I guess, still wanna up grade tho, course!
jycsalas 06-25-2009 06:45 AM
I think that after rebuilding the front drive shaft, then bringing your rig up to maintenance, the CDL is the most important and FIRST true mod a DII owner should do. My traction control worked great in many situations but having CDL now helps out much better and TC comes on very rarely. I'm glad I did it and IMHO Land Rover was WAY wrong to omit CDL thinking that their TC system would be just as great....its good, but it will never replace CDL.
Good Luck, and if you have any questions, post them on the thread so we can help out others.
josh
Topherhales 06-25-2009 11:54 AM
ya how suprised was I when the day after I bought it I put it low to show my wife what happenes when locked and turn a circle and nothing no hop, no scrubbing! I thought I had just bought a glorified subaru! ya - then checked into and seems like a cake job, thanks for the info, all be checking the post when Its time to get busy on it. around how much does it cost, I think I have seen a couple different way to do it, Disco linkage solinoid.... oh and you mentioned the front shaft, was that down-rated with out the CDL's or do they just have issues?
jycsalas 06-26-2009 06:28 AM
Do a search for front drive shaft. Basically 2 of the 3 ujoints are not servicable and when they go out your front drive shaft breaks (where its connected at the t-case) and takes out your transmission. No joke...get that taken care of asap!
MARS D2 99 V8 07-06-2009 08:37 PM
Front Propeller Shaft
U joint at transfer case almost shredded on wife, her ride. 65K 99 D2 V8 Auto. This truck has been always on paved roads only. My ? took the Front Propeller Shaft off. Thing will not budge an inch forward or reverse with only Rear Propeller Shaft, think we tried all gears etc. Why would the two wheel rear not engage?
Thanks if you can offer insight.
jycsalas 07-07-2009 05:30 AM
Hi there!
Since this question does not relate to installing CDL on a DII, I have answered it in it's own thread.
MARS D2 99 V8 ** Front propeller shaft**
Thanks
Budget Monty 07-14-2009 12:42 AM
I have been reading this write-up:
www.discovery2.co.uk/Factory Diff Lock
I have verified that my 2001 D2 is a 01/01 build, and I crawled underneath, and found the diff lock nipple on the trans. I keep hearing "You just use the factory diff lock cable/shifter", with out any further explaination. Does this mean that I can just use the stock shifter cable/shifter from a D1, or do I have to find the '04 diff lock cable/shifter?
I'd rather not rip apart my daily driver untill I have all the correct parts on hand. I work at a custom car shop, and have no problem doing the work, just want to get started with all the right parts.
I am an avid off-roader, but don't really plan on doing any serious wheeling with this rig, but still, to know that the diff lock option is on the truck, and not hooked up is just killing me.
jycsalas 07-15-2009 07:38 AM
A few options with CDL LEVER/Actuators for DII
You can get a stock 04 Shifter
http://www.landyzone.co.uk/lz/attach...lock_small.jpg
2004 Discovery II Transfer Case Shifter
You can get a DI shifter
http://ep.yimg.com/ca/I/yhst-3906644...4_2058_9694934
Land Rover Discovery LT 230 Diff Lock Shifter
Please see this thread for more info on a DI to DII swap
http://www.landroversonly.com/forums/f40/cdl-32441/
You can get this kit from lucky8llc that seems to be a well made adaptation to work like a stock 04 Shifter
http://www.lucky8llc.com/ImageUpload...185Image01.JPG
http://www.lucky8llc.com/ImageUpload...185Image02.JPG
Lucky 8 Products
and finally the electric solenoid actuator
http://lh5.ggpht.com/_MIHIeqx3Uaw/Se...I/cdlclose.jpg
Series II Diff Lock
Disco Mike and I have this as well as some others. It basically is a switch controlled window motor anchored and secured to a custom base that fits over the nipple.
I don't think any one is better than the other. If you are traveling through the middle of Africa for months and don't have a spare relay or window motor than maybe the AMV solenoid will be another thing to think about during the trip. Only issue I have heard has been a relay going bad.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
