Charge light on - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 03-20-2019, 07:10 AM Thread Starter
Quoted: 2 Post(s)
Charge light on
Disco 2 2001
So my charge light is on. I checked the voltage at the battery 12.5 v
So took out the alternator and had it load tested its putting out 14.5v with lots of amps ,altinator repair shop says its good.
My inside light has also be staying on so pulled the bulb out.
Cables look clean.
Battery is strong.
What am i missing?
karlcc is offline
post #2 of 7 (permalink) Old 03-20-2019, 08:03 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Originally Posted by karlcc View Post
Disco 2 2001
Cables look clean.
Battery is strong.
What am i missing?
You missed to say if that 12.5 voltage on the battery was with engine running or not cos that's the only relevant thing, so if it was with engine running we'll speak again , if you didnt measure voltage with engine running but removed the alternator just like that i can't say much
as about the interior light, did you watch it and stood on more than 10 minutes or it just didnt fade out as usual then you removed the bulb?.... i presume that you checked the switch to not be accidentally swithed to ON cos if it was something with the circuit all the interior lights should have been on cos they are in parallel on the same feed
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 7 (permalink) Old 03-20-2019, 03:25 PM Thread Starter
Quoted: 2 Post(s)
So yes i found that i was only getting 12.5 at the battery with the engine running at idle.
The battery is at 12.5v with the engine off.
What is the purpose of the small wire to the altinator?
karlcc is offline
post #4 of 7 (permalink) Old 03-20-2019, 07:10 PM
redtruck12's Avatar
Quoted: 284 Post(s)
Garage
Sounds like a bad alternator.
Small wire energizes the alternator to make it charge (output on the large wire /cable
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #5 of 7 (permalink) Old 03-20-2019, 09:37 PM
sierrafery's Avatar
Quoted: 246 Post(s)
The thin wire(brown/yellow) is the earth path for the warning lamp, the lamp has feed on the other side and when the alternator is not charging the lamp is on and when the voltage on that thin wire is rising the lamp goes out as it gets feed from both sides... the alternator is three-phase is with self excitation.
so check continuity on fusible link FL1 in engine bay fusebox which is on the alternator's output to not be shot cos that would not let the charging to reach the battery also unplug that thin wire and give it 12v with a wire(ignition on II) and if the warning goes out then IMO you need another alternator cos even if your's has power output on the bench it might not energise that thin wire.
here's the full description and the relevant part of the diagram is attached
Name:	D2 V8 charging diagram.jpg
post #6 of 7 (permalink) Old 03-28-2019, 09:12 AM
Living it...
MikeShaw's Avatar
Quoted: 1 Post(s)
Garage
Hi guys -
I had a similar problem in my Series IIA, and in my case, besides installing a new alternator, I figured out that the alternator warning light in the metal dash was grounded - to the dash - so lit up all the time.
Here's how I figured it out. I unplugged the warning light wire from my alternator. With ignition on, my light was still lit. So I realized it had nothing at all to do with the alternator. The bulb had to be somehow grounded to light up.
Installed a better insulated bulb housing, and now works perfectly - light goes out after start up with a reassuring flicker beforehand.
Maybe a different problem than yours, but you may want to make sure the bulb is not grounded itself, making the alternator wire feed to it useless on account of the bulb already being grounded regardless of the alternator 12v feed wire.
Have a great day!
Because life's too short not to drive one.
MikeShaw is offline
post #7 of 7 (permalink) Old 03-29-2019, 08:46 AM
sierrafery's Avatar
Quoted: 246 Post(s)
You have a good point but the D2's warning lamps are SMD LEDs soldered into the PCB so quite unlikely, eventually it can be a short to earth on the wire between the IP and alternator which is possible... though it seems that the OP just butted in to ask for help then keep ignoring us... i think i'll quit answering to newbees who dont have the decency to reply with a result of the fix what ever it was.... schmucks
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Disconnected battery to charge now Hazzard light flash & and can't turned off. Bille Range Rover Classic 0 07-07-2011 10:39 PM
Who Should be in charge ? TsiArt The Lounge 2 11-18-2005 06:53 AM
Battery won't hold charge michfitting Discovery Series II 6 11-07-2005 06:37 AM
battery/no charge light on without ignition Gareth Rhys Jones Defender 1 10-21-2005 07:14 PM
charge warning light oddstuff Discovery Series I 1 03-06-2005 08:52 AM
You may post new threads
You may post replies
