Cooling system flush - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 05-04-2019, 06:11 PM Thread Starter
G4 Mike
strap302's Avatar
Quoted: 12 Post(s)
Garage
So after extensive research on the interweb, reading forums, YouTube videos and the RAVE Land Rover manual, I decided to take the plunge and change my coolant this last Friday despite the nightmares of air pockets, gurgling heater cores and non-OEM thermostats. I have a 2004 Discovery G4 with 48,000 miles on it. Not sure if the coolant had been changed as it had the orange stuff in it.
I did start by installing a Scangauge2 so I would have a temperature baseline which was 204 F. I also purchased a genuine Land Rover PEL500110 soft spring 180 F thermostat (Amazon) and a lower radiator hose (AutoZone). I chose Peak Long Life coolant as it says it will mix with anything and I've had good luck with it in all my other cars.
I pulled the hoses off the thermostat and let it drain and then pulled the lower radiator hose. I had a real aversion to trying to pull the block drain plugs as steel plugs that's been in aluminum for 15 years didn't give me a warm and fuzzy feeling. Instead I rotated the top radiator hose that goes into the thermostat 180 degrees so it was a good 10 inches above the engine. I filled the holding tank and then poured water in the upper hose until the radiator and the bundle of snakes hose ran clean water. That took about 5 gallons of distilled water.
I installed the new lower hose and thermostat and added the full strength coolant, carefully following the RAVE refill instructions. Since it holds approximately 4 gallons according to the owners manual I figured I could add up to 2 gallons of coolant for a 50/50 mixture. After 2 cycles I've got about 1.75 gallons of coolant in and floating the -40 F ball in the antifreeze tester.
Now I'm at 188 F base line and haven't seen over 194 F. Hope this is helpful or at least entertaining.
strap302 is offline
post #2 of 3 (permalink) Old 05-04-2019, 06:56 PM
redtruck12's Avatar
Quoted: 284 Post(s)
Garage
Sounds like a success story and definitely good news for your G4
Job well done 👍
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #3 of 3 (permalink) Old 05-05-2019, 05:56 AM
Quoted: 90 Post(s)
And with only 48,000 miles - you are in rover heaven (yes, i do believe in such a place).
sobieski is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Brake Fluid Amount Needed for Complete System Flush bodyzoo Discovery 3 / LR3 5 04-14-2011 09:36 AM
How exactly do I flush the PS system ForeverNight Discovery Series II 2 09-10-2010 09:15 AM
Bleeding brake system full flush jcraig1441 Discovery Series II 22 07-12-2010 03:58 PM
2003 Discovery coolant system flush help LaRoDIs51 Discovery Series II 0 09-01-2009 05:56 AM
Cooling System Pressure Test geoellis Range Rover Classic 1 03-31-2005 10:25 AM
You may post new threads
You may post replies
