Cracked block - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
Closed Thread
post #1 of 24 (permalink) Old 08-08-2017, 11:19 AM Thread Starter
Quoted: 2 Post(s)
Cracked block
Hi guys,
2003 disco 2 with a steam cleaned #5 cylinder. Thought it was a head gasket but no visible failure or clear path to coolant so I suspect that the cylinder wall is cracked. I'd be most appreciative for advice etc.
Thanks
Alan Harmon is offline
post #2 of 24 (permalink) Old 08-08-2017, 12:10 PM
Quoted: 531 Post(s)
Well first off you'll want to make certain that you do have a slip liner. It's most likely not a cracked liner. What happens is the aluminum behind the liner will crack and steam will seep up between the liner and the block and either past the head gasket or down into your crankcase. So first off what does your engine oil look like? Second you'll want to get your head checked. Pull the valves on that cylinder and see if the back sides of the valve heads are washed. That's not a definitive way to tell but it certainly will give you an idea. What did the head gasket on that cylinder look like? If it was pushing steam past it should leave some marking. You'll want to have the heads checked anyway. Then after that we can get into the various liners that are available. There are two basic kinds. A standard press in and then one that has an o-ring on the bottom that's only available from One Source. This isn't a cheap fix but we can get into more of that later.
CT090 is offline
post #3 of 24 (permalink) Old 08-08-2017, 12:39 PM Thread Starter
Quoted: 2 Post(s)
Ok there's a noticeable lip on that cylinder so that leads me to believe that the liner slipped, but as you say get everything checked.
post #4 of 24 (permalink) Old 08-08-2017, 12:54 PM Thread Starter
Quoted: 2 Post(s)
Also the head gasket looked good, and the back of the valves head a similar amount of carbon build up as the rest with no noticeable difference.
post #5 of 24 (permalink) Old 08-08-2017, 12:55 PM Thread Starter
Quoted: 2 Post(s)
*had
post #6 of 24 (permalink) Old 08-08-2017, 06:01 PM
redtruck12's Avatar
Quoted: 283 Post(s)
Garage
Description sound very similar to mine except mine was #4
Complete rebuild , Darton flanged liners .....good as new but $5000 missing from the bank account
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #7 of 24 (permalink) Old 08-09-2017, 05:00 AM
Quoted: 531 Post(s)
By lip, do you mean that the liner has moved?
What happens when you get what is commonly referred to as a "slipped liner" is that they move inside the block. The leakage occurs when the aluminum bore that the liner is set in develops a crack at some point down the bore, which allows coolant to either enter the crankcase or more likely up and out through the head/block interface.
There are two ways of repairing it. One is what is commonly referred to as a Top Hat sleeve, which is a sleeve with a shoulder on the top that fits into a notch that is machined into the block. For reference, the Rover uses a tapered sleeve. This requires that you fab up blocking plates for the cooling passages, heat the block and then pressure test to look for cracks. Once found, they would need to be stop-drilled and then welded. Your other option is to use the Turner Engineering sleeve, which has an o-ring at the bottom. There is no need to pressure test or weld. If you're unfamiliar with sleeving, there are two typical types, wet and dry. Most heavy truck engines use a wet liner as they need to be replaceable. Most single-bore repairs are done with dry cylinders as the blocks were designed for the structural integrity of full-length material in the original casting, commonly cast iron. With the Rover, you are simply replacing a liner with another and I suppose you could call it a wet/dry liner. Being a design utilizing some of the attributes of a full wet liner, it has the capability of being a "dam" for the water jacket leak. The Turner is also a Top Hat design. The upside of the Turner is that if you get another crack, it won't matter.
Your third option is finding a good replacement block. The good news is that you can re-use the pistons as they virtually never wear. If you move forward with the sleeve approach, make sure your cam bearings are where they should be. They have a habit of moving. I would not invest in a block that has cam bearings that had previously loosened.
You can buy a complete block already sleeved from Turner, but they're not cheap. They will sell you the sleeves, but, as with most things, the end product is only going to be as good as the person doing it. Eight sleeves takes a very competent machinist that isn't in any sort of hurry. That alone just eliminated three quarters of them. A good one is going to charge you a grand for the work.
CT090 is offline
post #8 of 24 (permalink) Old 08-09-2017, 05:05 AM
Quoted: 531 Post(s)
P.S. If you decide to do this job, there are several errors in the RAVE engine section, specifically on bearing sizes and an omission about replacing the TTY rod bolts.
CT090 is offline
post #9 of 24 (permalink) Old 08-09-2017, 05:35 AM Thread Starter
Quoted: 2 Post(s)
Wow, thanks for all the responses. Yes, by lip, I mean that I believe that the liner has moved. All other liners a flush with the block deck. I'm currently trying to find a machine shop to both test and possibly install liners. I don't suppose any of you guys are familiar with any good ones in the milwaukee, wi area?
post #10 of 24 (permalink) Old 08-09-2017, 06:41 AM
Quoted: 531 Post(s)
There's really no test. Other than removing the liner and pressure testing. In fact, the moved liner IS the test.
I would visit Turner Engineering's website. Once you do the currency conversion you're going to find out that even with shipping you're talking about a couple hundred in savings. Finding a shop that has previously done this job in your local area is incredibly unlikely. Do you want to save a couple hundred and have someone that, even if they're really good, would be doing it the first time? Plus, this is mid-season for motorsports. All the good guys are two months plus out on doing a job like this. They're buried right now, trying to get guys back on the track or the water. If you're not a regular and have a relationship, you're invisible until early December. Frankly, I'd be suspect of anyone that could get this in for you right now.
When looking for machine shops, there are three kinds. First is the general automotive machinist. These guys are usually in or affiliated with an auto parts distributor. They're doing work for the general repair shops, doing valve jobs, etc. At the risk of stereotyping, this isn't your guy- at least not on a job like this. Second is the HD shop. These guys are doing work for the truck and machinery market. They can typically accommodate small engine work. They're used to doing precision work, but may shy away from this one- and they're going to be expensive and probably have a long wait. The third is a racing engine builder or performance machine shop. These guys range from being total hacks to engine building prodigies. The majority of good one's are booked for many many months out. Most engine builders are pretty busy with their own projects so doing outside machining is definitely back-burner for them. There used to be a bunch of these guys out there but the hot rod industry has contracted in this area significantly in the past few decades.
As far as people in your area, ATECO in Ingleside IL is a reputable place and I know them. Performance in Middleton is a competent shop.
CT090 is offline
post #11 of 24 (permalink) Old 08-10-2017, 04:38 AM
p76rangie's Avatar
Quoted: 385 Post(s)
Is yours a 4.0 or a 4.6. If it is only a 4.0, go find a 4.6 block and put that in instead.
If you are buying a secondhand engine, try and make sure you get one from a vehicle that was written off in an accident rather than one that was just parted out. You know the reason why the car is being parted if it was in an accident, the others could have been taken off the road due to engine issues.
If it was just a slipped liner, I would put tophat liners in. As you appear to also have a crack in the block, I would find another motor.
p76rangie is offline
post #12 of 24 (permalink) Old 08-10-2017, 04:59 AM
Quoted: 531 Post(s)
Alan,
As you research this issue, you will find that "liner noise" is a common malady with these engines. I had a kid come past my shop yesterday to pick up some parts and his was making the noise. The noise is indicative of one or more of the liners moving in the block. It isn't necessarily a sign of impending failure, but I wouldn't want to rebuild a used engine that I never heard running and come to find out it had that noise.
Don't concern yourself with engine size. You '03 already has a 4.6 in it. They all did.
As far as cracks in the block, the reason that Turner uses the O-ring liner is that the aluminum block material around the liner is quite thin. If you put a replacement liner in the bore, the boring process will make it even thinner and thus more susceptible to cracking. Without the o-ring at the bottom, you can go to all this trouble and still get coolant leaks into your crankcase at a later time. As I mentioned before, the o-ring approach isn't some half-assed patch, but very mature technology.
Originally Posted by p76rangie View Post
I would put topcoat liners in.
You can check, but I don't think these are a thing.
CT090 is offline
post #13 of 24 (permalink) Old 08-10-2017, 07:06 AM
p76rangie's Avatar
Quoted: 385 Post(s)
If the person fitting the liners is going to bore the block, take it somewhere else. There should be no boring involved and there is not enough material there to do it. Rover does not even make oversize pistons as the liners and block are as thin as they can be and you cannot bore either.
The only machining required to fit tophat liners is at the very top of the bore to put in a small recess to to the top of the liner to fit.
So if you have a cracked block, it is virtually impossible to fix the crack, they put in the new liners and hope that it does not eventually get worse and start to leak past the new liners.
Most slipped liners do not involve a cracked block as well and that is why the tophat liners are a good fix, but if it is cracked, I would replace the block.
post #14 of 24 (permalink) Old 08-10-2017, 07:25 AM
Quoted: 531 Post(s)
Again, incorrect, misleading information.
You can see here a full description by a person with actual hands-on experience, including videos he shot of the process. http://www.landroversonly.com/forums...-inside-68210/
Fortunately, Turner Engineering supplies a spec sheet with full instructions on how the sleeves are to be installed, for your machinist to follow.
You could go on a grand block-collecting expedition and punch the old liners out of blocks until you found one that tested good. But there is absolutely nothing wrong with welding a block that you know otherwise to be good. We just sent a $28,000 gear out to have it welded to replace a broken tooth. Now, you wouldn't want a trailer hitch shop to weld it, but if the engine mounts on the F-1 engines of the Saturn V booster were perfectly suitable by being welded, a proficient welder can fix the crack in your engine block. A good engine builder/machinist has someone he deals with regularly that welds blocks and cylinder heads for him. Aluminum is probably the easiest, most successfully repaired metal of them all.
CT090 is offline
post #15 of 24 (permalink) Old 08-10-2017, 07:31 AM
p76rangie's Avatar
Quoted: 385 Post(s)
The thickness of the block behind the liner can be as thin as 83 thousands of an inch and the best a block will have is 118 thou. So if you only machined it 8 thou, you would be removing 10% of the block. But as usual CT is an expert at everything. He posts expert advice in every section of this forum on every model.
Closed Thread
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
cracked heads/block? alecsstefan Discovery Series II 0 12-09-2016 02:23 AM
Cracked Engine Block or slipped liner??? DiscoveryII Discovery Series II 33 01-19-2014 06:35 AM
Help with cracked block diagnosis Tommy9999 Discovery Series II 33 04-22-2011 11:52 AM
Cracked block check rturbett Range Rover Classic 3 05-09-2008 01:00 PM
V8 Cracked Block sharky Range Rover Classic 2 10-24-2004 08:31 AM
You may post new threads
You may post replies
