Crazy Idea for 2004 discovery lift - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 04-01-2015, 11:02 AM Thread Starter
Sand fan!!
Quoted: 3 Post(s)
Hi Folks,
what you think if i put the rear spring coils in the front to have about 2-3 inch lift. for the rear I'm going to use air spring with 2 inches spacer.
the information I got form internet, that I need 200-225 lb/in for the front lift. while the rear spring is 270-290 stock ... is that true ?
Is it a good idea to do so?
mshawari1 is offline
post #2 of 4 (permalink) Old 04-02-2015, 03:00 AM Thread Starter
Sand fan!!
Quoted: 3 Post(s)
Ok,
I guess it will be too high lift.
what if I cut one coil to be 7.7 coils ?
post #3 of 4 (permalink) Old 04-02-2015, 04:43 AM
'03 Disco SE
Bosnian Discovery's Avatar
Quoted: 12 Post(s)
I believe all you would achieve is a heavily reverse-raked stance, meaning your front end would sit much higher than the rear end.
Don't cut the coils - during full axle articulation you can have the spring dislodge from it's mounts and risk damaging the ABS wires or brake lines.
Keep in mind that you're limited to how much lift you can achieve on the stock components without negatively impacting ride & handling. It's something like 2" or less. Your limiting factor will be the radius arms. Basically, as you put in bigger springs, the axle will move away from the frame along the swing of the radius arms and will begin to angle inward toward the center of the body. This means that the "caster" angle of your front axle will be thrown off which will lead to problems with ride quality and an inability for your steering wheel to self-center. It also stresses shocks & shock towers.
You can buy caster-corrected radius arms, but they're something like $600/pair.
I did a mild 2" medium-duty Terrafirma lift and during my alignment I was told that my caster was already 3 degrees off.
Bosnian Discovery is offline
post #4 of 4 (permalink) Old 04-02-2015, 01:08 PM Thread Starter
Sand fan!!
Quoted: 3 Post(s)
Thanks for the input ... I think I will give up on that idea and just use a 1" spacers
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
2004 Discovery overall height with 2" lift? RiceJ53 Discovery Series II 8 12-10-2013 01:13 PM
2004 Discovery II w/ lift and warranty bguetter Land Rover Vehicles 7 01-04-2011 05:36 PM
2004 Discovery S / RTE lift and armor RealDeal Land Rover Vehicles 0 10-03-2010 11:51 AM
Good Idea or Retarded Idea? RealRitzcracker General Land Rover Discussion 360 07-28-2009 08:08 AM
crazy idea disco12 General Land Rover Discussion 7 11-08-2007 09:32 AM
You may post new threads
You may post replies
