D2 wont start. Crank Shaft Position sensor? - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
post #1 of 21 (permalink) Old 05-15-2012, 07:09 PM Thread Starter
Location: SF Bay Area/Fremont, Ca -> Central Valley/Tracy, Ca
Quoted: 0 Post(s)
My 2002 D2 intermittently refuses to start. It seems to usually happen after having driven for a bit in the day...I hear the starter cranking strong but it just does not start up.
i have tried on a couple of these occasions holding it cranking for like 45 seconds to no avail....
It seems to do fine in the mornings or after she gets about an hour break from driving about town but mid-day (usually in the middle of shuttling kids from school to various after school sports) she craps out on me.
This truck has 168K miles and I have read here in other posts that the "crank shaft position sensor" is a suspect part that might lead to this....do my symptoms sound like they fit this issue?
Are there other typical parts that fail around this mileage that would cause a starting problem?
Is this a dealership only part or are there reliable sources that are less expensive?
shawn and kat
2002 Disco SD
pretty much all stock.
sbadams17 is offline
post #2 of 21 (permalink) Old 05-16-2012, 01:37 AM
saharatj98's Avatar
Quoted: 5 Post(s)
If it's typically doing this when warm, spray cold water on your coil packs and try it. If it cranks and won't start warm, but does after cooling down the coils than that's your problem. CPS can also do goofy things. Unfortunately, checking for tach bounce while cranking does not work on these since the pick-up is in the alternator. I can't remember, but I think the check engine light will go off while cranking if the cps is bad. It's not a bad job to change out and probably a good thing to change out anyway at your mileage. I just replaced the one in my 96, took maybe 15 minutes. It's just above the oil pan on the driver's side (LHD) facing rearward into the bell housing under a cover. Two 7mm screws. It is possible to remove it with a 1/4 drive ratchet and short extension and just clear the exhuast downpipe.
1996 Disco XD 1996 Trek #4 and Camel Trophy Team USA Selections 1997
2003 Disco SE7 expedition prepped
1998 Disco LSE 7 50th Anniversary Baluga Black
1987 Defender 110 300tdi/R380
1969 Series 2A 109
Pacific Coast Rover Club
Redmond, Washington
saharatj98 is offline
post #3 of 21 (permalink) Old 05-25-2012, 05:13 PM Thread Starter
Quoted: 0 Post(s)
it looks like the coil pack is pretty well burried in the back of the engine compartment. Is there any risk or haard to getting that all wet back there? If that is the issue, how much labor is involved in swapping out the coil pack?
I took it to the local independent LR shop where they read the codes: P1884, P1590, and P0102.
They said that P0102 was "airflow signal voltage low" and recommended that I replace the airflow sensor. They did that and threw in a new air filter as well.
I drove home from the shop (which was about a 40 minute drive) and when I got home the truck was nice and warm and again would not start. When I called the shop this time the mechanic is now saying that there is most likely a fuel pump/fuel pressure issue.
shawn and kat
2002 Disco SD
post #4 of 21 (permalink) Old 05-25-2012, 06:23 PM
Quoted: 0 Post(s)
Sounds like cps to me you will need 7&8 mm sockets . Don't think it would be coils you have two . Can't believe it would be both . If you do replace them don't forget the plenum gasket & you would be crazy not to change your plug wires . Check the forum thats who to get the deals from.
Blamo is offline
post #5 of 21 (permalink) Old 05-25-2012, 06:23 PM
Quoted: 11 Post(s)
Not on a DII.
We don't even know if it has spark or fuel.
Cue the Waylon and Willie!
Got spark? Got fuel?
Don't go back to a shop that sells you parts and then surmises what's wrong, go to one where they know WTF they are doing and can explain their troubleshooting/diag to you.
I'd rather spend ten minutes on the phone teaching someone to diagnose their truck than sell a part they don't need.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
PTSchram is offline
post #6 of 21 (permalink) Old 05-25-2012, 07:04 PM
Computer Nerd
jafir's Avatar
Quoted: 1 Post(s)
Coils on these have a reputation for being pretty reliable. Crank Position Sensor on the other hand has a reputation for being anything but.
Yeah. What he said!
____________________________
Jafir
2006 LR3 HSE
1987 Ex-MOD 90, 2.5NA
Previous Rovers:
2006 LR3 SE
2003 Discovery S
1999 Discovery II, SE7?
1996 Discovery SE7
jafir is offline
post #7 of 21 (permalink) Old 05-26-2012, 09:03 AM Thread Starter
Quoted: 0 Post(s)
Am I getting spark and fuel? I think so.
When the truck was cold this morning, it fired up beautifully. I am not sure if this can change as it warms up though. That is when it tends to not start.
The sensor seemed cheap enough and the time investment didn't sound major so I just picked up the sensor. I am looking under my truck on the driver's side and I think I should see the cover for it with two nuts somewhere near the catalytic converter... like this:
http://www.landroversonly.com/forums...r-help-ckp.jpg
but I don't see it.
Is this video applicable?
D2 CPS install - YouTube
BTW, my DII is an '02 SE automatic.... I am not sure that makes any difference.
shawn and kat
2002 Disco SD
post #8 of 21 (permalink) Old 05-26-2012, 09:27 AM
Quoted: 11 Post(s)
Look at the left side of the oil pan, now looks back to the horizontal portion of the oil pan parallel to the axles, now look up. That's it right there.
260-804-0458
PTSchram is offline
post #9 of 21 (permalink) Old 05-26-2012, 10:10 AM Thread Starter
Quoted: 0 Post(s)
Ahhh, I am clearly pretty mechanically retarded.... I was looking in the wrong direction from the exhaust down pipe.
So once I found it, I got the cap and sensor off and put the new one in place but I am having difficulty unplugging the cable of the old sensor. Is it simply supposed to pull straight out or is there a trick to it?
shawn and kat
2002 Disco SD
post #10 of 21 (permalink) Old 05-26-2012, 10:27 AM
Quoted: 11 Post(s)
Well? I spoke with you 15 minutes ago. No status update yet???
260-804-0458
PTSchram is offline
post #11 of 21 (permalink) Old 05-26-2012, 11:22 AM
Computer Nerd
jafir's Avatar
Quoted: 1 Post(s)
He's probable stuck under the car with his arm pinned up against exhaust pipe.
Stender Dave likes this.
Jafir
2006 LR3 HSE
Previous Rovers:
2006 LR3 SE
2003 Discovery S
1996 Discovery SE7
jafir is offline
post #12 of 21 (permalink) Old 05-26-2012, 11:50 AM Thread Starter
Quoted: 0 Post(s)
Thanks PT! now that I got my arm unwedged from the exhaust, it's is miraculously up and running again. I think it will be an hour or so before we will see if this fixes the starting issue when it is warm.
Sent from my SCH-I800 using AutoGuide.Com Free App
shawn and kat
2002 Disco SD
post #13 of 21 (permalink) Old 05-26-2012, 12:09 PM
Quoted: 11 Post(s)
I take it my coat hanger idea didn't work too well for you then, eh?
260-804-0458
PTSchram is offline
post #14 of 21 (permalink) Old 05-26-2012, 12:24 PM Thread Starter
Quoted: 0 Post(s)
Yeah, I'm just kidding about getting stuck in the exhaust. It worked great. If I ever have to do it again I'll be able to knock it out like a pro.
I had read it could be done with the exhaust in place but dropping the exhaust makes a big difference in the frustration level of the job too.
shawn and kat
2002 Disco SD
post #15 of 21 (permalink) Old 05-26-2012, 12:38 PM
2003discoII's Avatar
Quoted: 1 Post(s)
and now i know where that cover i found laying under my disco one day is from
2003 disco. exhaust mod,265/65r18
2003discoII is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Crank shaft sensor replaced engine won't start? Irish4x4 Discovery Series II 6 10-16-2011 11:47 PM
Crank Shaft Position Sensor upfifties Discovery Series II 4 08-13-2011 07:16 PM
land rover discovery 2 new crank shaft position sensor still wont work PUFFE664 Discovery Series II 3 03-30-2010 01:15 PM
Crank Angle Sensor same as Crankshaft Position Sensor ? DiscoIIDenver Discovery Series II 2 12-27-2008 06:17 PM
crank position sensor wimp Discovery Series II 2 12-01-2008 05:39 PM
You may post new threads
You may post replies
