Disco 2 Just Purchased, Crank No Start - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #1 of 30 (permalink) Old 03-17-2019, 11:14 AM Thread Starter
Quoted: 2 Post(s)
I am an independent mechanic and thought it would be a good idea to purchase this 2002 Discovery 2 from the auction. It has 82,000 miles.
Engine cranks but doesn't start. I have replaced the Crank Sensor, checked for fuel at the injector rail, checked for spark, and even tested compression on both banks.
I've read a whole lot of forum posts to try and resolve this, but now I'm reaching out to the pros (Looking at you DiscoMike).
Snap on scanner shows no codes. Installed new battery and kept the voltage at 13.5.
I went to the junkyard and purchased a cluster, BCM, ECM, and Interior Fuse Box. I swapped the cluster and modules out and cleared any codes and tried to fire it up, nothing. It cranks, and there is still spark and fuel, but it just won't happen. I swapped the interior fuse box after and still got nothing.
What am I missing on this thing? I put a jumper in the inertia switch connector too just to rule it out.
alexdicea is offline
post #2 of 30 (permalink) Old 03-18-2019, 06:41 AM
sierrafery's Avatar
Quoted: 246 Post(s)
If you swap either the BCU or the ECM you have to make the ECM learn the security code and i doubt that a generic scanner can do that cos it's not in the OBDII protocol but each module has to be programmed directly. Missing that the engine will crank but not fire. Maybe first time the passive immobiliser was tripped and that was the reason of non starting and that's the result of not unlocking the vehicle with a programmed fob... IMO you'll not be able to fix this without using a dedicated diagnostic tool which can make the ECM learn the security code
you need atester with these functions(copied from Nanocom EVO guide)
BOSCH MOTRONIC M5.2.1 - Diagnostic Capabilities (UTILITY)
· Discovery Security Learn: This function forces theMotronic ECU to learn the incoming
code from the BCU in a Discovery Series II as its correct mobilization code.
· Reset adaptive values: The adaptive values should be reset if any of the following
components have been renewed or rectified: fuel injector, lambda sensor, fuel pump,
fuel rail,MAFS, inlet manifold, after fixing an air leak or if a new ECU was fitted.
masantschi and JarmFam4 like this.
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 30 (permalink) Old 03-19-2019, 07:50 AM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 8 Post(s)
You mentioned you replaced the crank position sensor. Make sure the wires to it are fully seated and connected.
When I replaced my CPS the Disco it continued to only cranked over and not started. I thought I had a brand new bad CPS but found the connections weren't fully seated together in the plug.
MIKE
- 2001 Discovery 2 SE (NAS LHD) “MYRTLE”, 110K miles, 4.0L V8, NGK Iridium IX plugs, PCV mod, 180* T-stat, Hayden fan clutch/Dorman fan, removed TBH, modded SAI filter, Safari Gard steel guards, Warn XD9000i winch, KO2 265/75R16 on steel rims, EBC rotors/Akebono pads, +2” TF lift & LEDs
- UltraGauge Blue, Foxwell NT510, Nanocom D2 V8 & TD5
JUKE179r is offline
post #4 of 30 (permalink) Old 03-19-2019, 02:00 PM Thread Starter
Quoted: 2 Post(s)
I have a snap on scanner, I did learn the EKA code into both modules, but there wasnt an option to reset adaptations. I will have to look when I get back to it tomorrow. I swapped the crank sensor out for ANOTHER crank sensor just to be sure I didn't receive a defective one. This was also a thought of mine. Keep you posted on the adaptations. You would think that the immobilizer in the Motronic would cause a no crank instead of no spark.
post #5 of 30 (permalink) Old 03-19-2019, 03:33 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Originally Posted by alexdicea View Post
I have a snap on scanner, I did learn the EKA code into both modules,...
The security code is not the EKA code, it has nothing to do with it... the EKA code is stored in the BCU and has to do with the key entry sequence while what i said is an engine ECU(BOSCH MOTRONIC M5.2.1) setting ... it's clearely described in my previous post if you read what the "Discovery security learn" means
JarmFam4 likes this.
post #6 of 30 (permalink) Old 03-19-2019, 03:44 PM Thread Starter
Quoted: 2 Post(s)
I understand now. Looks like my other scanner will do that function. I will try it tomorrow and check back in. Thanks again fury
2002 Disco 2 4.0
post #7 of 30 (permalink) Old 03-19-2019, 03:49 PM
sierrafery's Avatar
Quoted: 246 Post(s)
The no crank is caused by the BCU immobiliser if the alarm was triggered for some reason on the locked vehicle, then the starting circuit is disabled too, the engine immobiliser due to the wrong/unreceived security code on the unlocked vehicle is crank but no fire cos the starter is not linked to the motronic ECU.
post #8 of 30 (permalink) Old 03-21-2019, 01:57 PM Thread Starter
Quoted: 2 Post(s)
Looks like my autel won't do the programming. There was live data but no special functions in my menu. Oh well....
I dove in and ordered a Hawkeye Pro from across the pond, looks like it should be here early next week. Just have to wait and see now.
2002 Disco 2 4.0
post #9 of 30 (permalink) Old 03-21-2019, 06:12 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Too bad for you cos hawkeye can't make the motronic ECU learn the security code.... you should have bought Nanocom Evo cos it seems it's the only ''smart'' one...or eventually Foxwell which is half the price of Hawkeye and smarter
post #10 of 30 (permalink) Old 03-25-2019, 02:56 PM Thread Starter
Quoted: 2 Post(s)
A few days too late and a dollar too short. I wish I would've read your post before. I received my Hawkeye and was so eager to try it this morning. As you said, the Hawkeye does NOT do this security programming. I am looking for a distributor for the Nanocom that is US based so I can get this rolling. I only see the official distributor and it will set me further back. If anyone has an evo they would be willing to lend me, I will pay them the full price of the tool through paypal or however they'd like for someone to overnight it to me as a deposit until I return it to them. If I can't find anything local I'm just going to dive in and buy a whole unit.
2002 Disco 2 4.0
post #11 of 30 (permalink) Old 03-25-2019, 03:49 PM
Quoted: 0 Post(s)
iLand scan tool
Do you know anything about the iLand Scan tool from Roverparts.com? I just ordered that tool and then came across this thread. I am new to the Rover world.
2002 LR Disco 2 SE
JarmFam4 is offline
post #12 of 30 (permalink) Old 03-26-2019, 03:58 PM Thread Starter
Quoted: 2 Post(s)
Looks promising with a lot of features. I would look in to that for a DIYer, but I went with the Nanocom because it was recommended and the vehicle tokens are cheaper. About 65 bucks to add a different model land rover to the tool, vs 199 to add another vehicle to the iLand. The functions are here if you're looking for something in particular. https://www.roverparts.com/Instructi...By-Vehicle.pdf
2002 Disco 2 4.0
post #13 of 30 (permalink) Old 03-26-2019, 09:16 PM
sierrafery's Avatar
Quoted: 246 Post(s)
AFAIK the iLand tool is the North American version of the one which in Europe is called Lynx EVO(made by the same manufacturer with same software) and all the users i know are unpleased with it, they say that the menus are human unfriendly, the soft is full of bugs and can kill your nervs also the tech support is useless.
post #14 of 30 (permalink) Old 04-01-2019, 05:25 PM Thread Starter
Quoted: 2 Post(s)
Nanocom showed up today. Just got it registered and updated. Let's see how it works tomorrow!
2002 Disco 2 4.0
post #15 of 30 (permalink) Old 04-02-2019, 04:20 AM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 8 Post(s)
Good luck!
MIKE
JUKE179r is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
no crank no start new battery jskeene Discovery 3 / LR3 0 01-17-2015 07:29 PM
won't start, no clicking, no crank 503schultz Discovery Series I 2 03-07-2011 09:20 PM
won't start, no clicking, no crank 503schultz Discovery Series I 0 03-06-2011 09:13 PM
95 LWB no crank no start LebaneseShowoff Range Rover Classic 16 10-18-2010 03:38 AM
NO start No Crank Boular Discovery Series I 3 01-14-2010 03:08 PM
You may post new threads
You may post replies
