Discovery II Running Rich - Land Rover Forums : Land Rover and Range Rover Forum
 2Likes
post #1 of 18 (permalink) Old 04-24-2019, 05:59 PM Thread Starter
Green Bean's Avatar
Quoted: 4 Post(s)
Garage
Unhappy Discovery II Running Rich
My Disco 2 has been running rich for the last 8 months or so. It always trips fault codes for both of the front O2 sensors and occasionally throws a "running lean" code
I can get the numbers for the codes if I need to
I've replaced the front two O2 sensors twice, and the rear two once, checked their wiring harnesses (just replaced both head gaskets), replaced the fuel pump, and thoroughly checked my fuses, even replacing a few that tested good but looked bad
It currently gets anywhere from 6 to 10 mpg and it's bleeding me dry
Any help would be much appreciated
Thanks,
Christopher
Green Bean is offline
post #2 of 18 (permalink) Old 04-25-2019, 08:47 AM
Quoted: 59 Post(s)
What are the numbers for the codes you are getting Christopher?
Also, do you smell fuel? How many miles now and when was the last time you rebuilt your injectors?
Green Bean likes this.
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #3 of 18 (permalink) Old 04-25-2019, 08:49 AM
tyl604's Avatar
Quoted: 178 Post(s)
I got 10.88mpg on my last tank ('99 DII) and that tracks usual mileage in town. But 6mpg is out of spec. Would help if you would clear all codes, let them come back, and then report codes.
tyl604 is offline
post #4 of 18 (permalink) Old 04-27-2019, 11:11 AM Thread Starter
Green Bean's Avatar
Quoted: 4 Post(s)
Garage
The codes are: P0171 P0174 P0150 and P0130
They reappear without fail about 2 to 4 miles after clearing
I have not rebuilt the fuel injectors since I have had the car (last 3 years), and they seemed to be original and undisturbed when I replaced my head gaskets about a month and a half ago
It likes to hang out around 8 mpg but fluctuates up and down based on factors unknown to me
Keeping in mind that it is nearly 20 years old now, I keep a Voyager roof rack on it, a 2-inch lift, and larger tires I expect the fuel economy to be a few miles lower than stock, but not this bad
I take all of my mileage calculations over the same 44-mile commute
I reset the odometer each time I gas up to a full tank, and then divide my miles traveled by the number of gallons it takes to refuel
I also have 32-inch tires on my vehicle and have never had my odometer adjusted so I account for their increased size by multiplying the miles my odometer reports
by the ratio between the circumference of my new tires and the stock tire size of 29 inches (~1.103448)
i.e. If my odometer said I drove 40 miles and I had to put 5 1/2 gallons in I would calculate it as: (40* 1.103448) / 5.5 =~ 8
I also double check my distances with google maps
If you think I've overlooked something or see something wrong with the way that I am calculating my distance traveled please let me know
I really appreciate the help, Im at my wit's end,
Christopher
Christopher
post #5 of 18 (permalink) Old 04-27-2019, 12:35 PM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
I would not try to figure out fuel mileage until you can get the codes dealt with.
All codes are lean and O2 related. Likely either bad O2s or vacuum leak???
You mentioned you just did head gaskets, what’s the story on that? O2 sensors previous to that repair? What brand O2 sensors?
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is online now
post #6 of 18 (permalink) Old 04-27-2019, 01:14 PM Thread Starter
Green Bean's Avatar
Quoted: 4 Post(s)
Garage
My car threw the four codes I listed (along with codes for the two rear O2s) just as it began running rich about 8 months ago, and after throwing many parts at it I replaced the four O2s with
the first set I got about 5 months ago
The rear two took and those codes have never resurfaced, however the front two thew codes several days after
This was before I had fixed my multiple oil leaks, and I found my front two O2 connectors to be soaked in oil
I cleaned these thoroughly with break-clean and contact cleaner and wished the problem away, but they continued to throw codes
This led me to replace the front two sensors again (with the cheap sensors) about a month ago worrying that the oil had somehow destroyed the first set
I can't tell you what brand the first O2 sensors were because my dad got them for me as a gift, but they were most likely very cheap
The second set I got was also the cheapest I could find, I bought them because I wanted to get some that would at least work for a while
(even if they were poor quality) so that I could eliminate them as a problem without making a significant investment
I reasoned that I could upgrade them when they stopped working if that was the case
If I need to buy more expensive sensors from Atlantic British or elsewhere let me know, money is tight but I'll do whatever I need to do to solve this problem
I have suspected a vacuum leak but have no experience dealing with them and do not know how to go about detecting one
I replaced the head gaskets because I had my front cover gasket blow while on was on the commute that I mentioned before and quickly redlined my engine,
after replacing the front cover gasket I misdiagnosed a blown head gasket so I went through with that repair
In the process, I found multiple sources of my everpresent oil leak: rear seal over pushrod area, oil pan gasket disintegrating, valve cover gaskets leaking
This running rich problem was present long before this repair and I made sure to closely examine the wiring harness and anything else I could think of, yet found no damage
Also, to respond to masantschi: Yes I can smell fuel when I run the car and my exhaust pipe is black
Christopher
post #7 of 18 (permalink) Old 04-27-2019, 02:22 PM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
There’s many posts and threads about cheap O2 sensors and the grief they can cause.
02 sensors can easily become contaminated by engine problems, coolant, oil, cleaning chemicals, even improper sealants and adhesives can contaminate them.
When in the timeline did you overheat the engine and do head gaskets etc. ???
If you have been driving it with these issues and codes for 8months? Catalyst damage is likely 😐
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #8 of 18 (permalink) Old 04-28-2019, 09:47 AM Thread Starter
Green Bean's Avatar
Quoted: 4 Post(s)
Garage
I have been worried about the damage this problem might cause, but I'd be
happy to get off with replacing the Cats if that's what you mean by Catalyst damage
I have driven it just over 10,000 miles in this condition blindly throwing many parts at it along the way,
so I'm very happy to have a chance to hear from people who are familiar with this problem
I have attached a timeline of the relevant repairs
Thanks again for all the help and speedy responses
Name:	Repair Timeline Rich.jpg
Christopher
post #9 of 18 (permalink) Old 04-28-2019, 11:33 AM
tyl604's Avatar
Quoted: 178 Post(s)
Might be a waste of money to go out and buy cats before you actually pinpoint the problem.
tyl604 is offline
post #10 of 18 (permalink) Old 04-28-2019, 11:40 AM Thread Starter
Green Bean's Avatar
Quoted: 4 Post(s)
Garage
I agree, I definitely need to fix this problem before I go about making any accessory repairs
Christopher
post #11 of 18 (permalink) Old 04-30-2019, 09:12 AM
Quoted: 59 Post(s)
I'd stop driving that truck till you get this figured out - you clog up those cats and OEM O2 sensor cost will be the last of your concerns.
As has been pointed out, we cannot use the cheap O2 Sensors. You need to get those replaced. The OE high cost have a warranty so if you have an issue within 12 mos or so, they'll replace them w/o issue. The reason your [rear] codes went away after you replaced the rear is because all that black stuff is clogging up your cats right now and it's not really getting to them, but rest assured, in your current condition, they'll start throwing again as soon as that carbon starts to fully work its way through and coat them - i.e. without fixing the underlying issue, it'll come back.
I think these two are your culprits, but I can be wrong...
P0130 - O2 Specific though it can be caused by Faulty Fuel injectors or inappropriate fuel pressure
P0150 - Fuel Rail/System Pressure is too high.
That said, I would perform a fuel pressure test. You need to hook up a fuel PSI tester to your line when it's cold and check your pressure (write it down). Then, you need to do the same with the key in the on position (fuel pump comes on) and then again after you turn the truck over and start it up. Report back your numbers, unless you know how to diagnose the injectors/filter/regulator or pump from there.
P0171 & P0174 together usually indicate you have a vacuum leak in the intake system. Since you just got the HG done, it's possible there was a step missed or something didn't get tightened down to spec or maybe a gasket is pinched or something? It's also possible that due to your fuel issue above, this could be a bi-product, since all these codes are coming back as fuel/air. Personally, I'd fix the above first and then perform the following if these are still present...
Begin by looking for a vacuum leak. With the engine running, spray some carb-cleaner around your intake plenum and heads, etc. to see if you get a reaction from your motor (you'll know it if/when it happens). If you hear your motor bog a little then you will need to focus in that area to find the leak. If that comes back clean, you need to perform a smoke test on your intake manifold. You have 3 options here - (a) Have a shop run the test for you, (b) you can rent a tester and perform the test yourself, (c) buy a cigar and get some plastic/rubber-bands so you cap off your intake and perform the test this way (I did c on mine).
Just my .02... hope it helps some
Michael
'01 LR Disco II SE7
post #12 of 18 (permalink) Old 04-30-2019, 12:31 PM Thread Starter
Green Bean's Avatar
Quoted: 4 Post(s)
Garage
Thank you so much for this advice, I'll order some good sensors as soon as I can and park the car until I fix the problem
1. Do I hook up the PSI tester near the fuel pump or the fuel rail or somewhere else?
2. I'll get back to you with my results once I've done the fuel pressure test
3. No, there is next to no chance that I pinched anything from the wiring harness during the HG repair, and I marked every bolt head with silver sharpie to ensure I torqued each one appropriately
I also had someone with me throughout the entire repair to double check everything that I did
Again, I'm very grateful for the advice, It has been difficult for me to find anyone who has dealt with a problem like this
Christopher
post #13 of 18 (permalink) Old 04-30-2019, 02:02 PM
Quoted: 59 Post(s)
3. No, there is next to no chance that I pinched anything from the wiring harness during the HG repair, and I marked every bolt head with silver sharpie to ensure I torqued each one appropriately I also had someone with me throughout the entire repair to double check everything that I did
1 - You hook up the PSI tester to the fuel rail. It's a {explicit} to get to because it's up against the firewall, behind the plenum, almost dead center of the LH Intake Side.
3 - I didn't mention the wiring harness being pinched - I was talking about gaskets etc. I'd still work on the fuel issue first, personally. It could clear up all your problems once fixed, and you get some Bosch O2 Sensors.
Name:	Fuel Rail PSI Test Point.jpg
Michael
'01 LR Disco II SE7
Last edited by masantschi; 04-30-2019 at 04:57 PM. Reason: Edited my foul language. LOL
post #14 of 18 (permalink) Old 04-30-2019, 04:11 PM
p76rangie's Avatar
Quoted: 384 Post(s)
If you are buying cheap O2 sensors, how are you connecting them to the car. You should not solder any wires as it will cause false readings.
p76rangie is offline
post #15 of 18 (permalink) Old 05-01-2019, 04:23 PM
Redrover NC's Avatar
Quoted: 15 Post(s)
DII owners have reported problems with Bosch sensors too, including out of the box, including me. Several owners have reported better results with Walker sensors.
'99 DII, STI wires, Champion 7070s, '04 CDL & SLABS, Garvin WILDERNESS rack, painted headliner, air springs victim, headgaskets at 109,000, plus victim of XYZ (twice) and many other ridiculous DII failures. Option B AMIGO FREE since February 2011.
Runs like a top; now if I could just afford the gas! December 2014 update - Wait, I can afford the gas! Drill baby, drill!!!
Redrover NC is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Discovery running rich? fouling #6 plug? nels2173 Discovery Series II 37 03-19-2013 10:09 AM
Running rich da97 Range Rover P38, Mk III and Range Rover Sport 0 12-21-2007 10:50 PM
Running rich ? LRDisco94 Discovery Series I 3 05-09-2006 06:34 AM
96 running rich and no 02 sensors dacrts Discovery Series I 12 04-30-2006 12:32 AM
running rich DickFox Series Land Rovers 2 03-29-2005 02:56 PM
You may post new threads
You may post replies
