Flashing "M" & "S" Lights. - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 12 (permalink) Old 07-25-2009, 12:14 AM Thread Starter
Quoted: 0 Post(s)
Having searched this forum and others it seems that people have solved the problem in one of three ways. Replacing the battery, the Gear Selector Switch, or Crank Shaft Sensor. Nobody, to my knowledge, has had to replace more than one of these. The starter motor and fuel pump have also been mentioned but I've not heard of anyone replacing these.
Has anyone any further information that my be of help? Has anyone the part numbers for the GSS and/or the CSS? Can anyone recommend the best place to acquire them? The vehicle details are: Discovery, Aug 2002, TD5 Auto.
Other info:
I've had my TD5 since January this year and got rid of the "Three Amigos" via a local garage but shortly after the "M" & "S" lights appeared. Since then they have been off and on at ever more frequent intervals. The local garage couldn't decide on what to do. I got the battery checked by specialist auto battery firm and the passed it with flying colours. I then took it to an independent Landy garage who advertise a "SOPHISTICATED COMPUTER" and charged me £20 to tell be it could be "anything electrical" but thought it may be the starter motor. Went to the main dealer who agreed with the diagnosis (anything!) so I didnít bother paying for a further diagnosis there!
toecee is offline
post #2 of 12 (permalink) Old 07-25-2009, 05:41 AM
Administrator
Quoted: 5 Post(s)
The most common issue causing this is a dirty or loose battery cable or a tired battery under 13.6 volts.
Do you have a check engine light on, is it driving in limp mode, 3rd gear?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 12 (permalink) Old 07-25-2009, 05:44 AM
Quoted: 0 Post(s)
Other info:
The first step is the batt but you have covered that. with D2 if you have under 12v on start up they will fault the auto(m&s). If your fault isnt at start up then i would be looking at replacing the XYZ switch. it is on the side of the gear box where the selector comes out. Start there and it should end there. Good luck
scott2001disco2td5 is offline
post #4 of 12 (permalink) Old 07-25-2009, 06:36 AM
Administrator
Quoted: 5 Post(s)
If your voltage is any where in the 12 volt range, you are too low, the standard is 13.6 to 14.4 volts
Need Parts?
Lucky8,
post #5 of 12 (permalink) Old 11-30-2009, 12:58 PM
Quoted: 0 Post(s)
Thank you for your help. I am new to this Forum because I just purchased a used 2002 Discovery II. We had the flashing m and s (and D) problem and after taking the advice given on this site, ie replace battery, I am happy to report that the flashing lights have stopped. Unfortunately we drove in 3rd gear all the way home from our ski trip because no shop was open on a Sunday.
lmkarin is offline
post #6 of 12 (permalink) Old 01-28-2014, 08:52 AM
Quoted: 0 Post(s)
"toecee" that is correct, I had the same problem and where is what happened. I was driving about 25 mi/hr and my car stopped suddenly. i heard a clunk and the "M" & "S" and "D" letter was flashing and it would not turn on again. later I came back and the car started with no problems. having no codes, from that I got eight codes here they are (P0307,P0374,P1300,P0308,P0304,P1884,P0335,P0102), I freaked out, I have never had these many codes. I on my way to check the battery, it died on me again. I paid 45dlls for a diagnostic at the corner garage and they said it would be 800dlls to replace the ignition coils that where overheating and turning off the car when the engine got hot. I would let my car sit in my driveway and it would turn off after may be 10 minutes at which point only gave me two codes (P0374 and P01884). I checked the battery terminals which were corroded and loose, fixed that cleaned my Mass air flow sensor, tested battery and alternator, all good, after reading this site, I changed the Crank shaft sensor and the problem got fixed. when the sensor came out, it was nasty, I went for a drive no lights and the fan kicked in for the first time and it was a great feeling. what was best that it was relatively simple to fix and I did not have to pay that crack head mechanic 800 dlls, he thought it was the ignition coils which I actually replaced my self and I could guarantee it was not.
"""""Thank Your Land Rovers Only for existing and all of you out there that dare to adventure beyond"""""
RCBENI53 is offline
post #7 of 12 (permalink) Old 01-28-2014, 11:02 AM
Quoted: 11 Post(s)
Look for water ingress to the cable connectors adjacent to the transmission.
PTSchram is offline
post #8 of 12 (permalink) Old 01-29-2014, 07:05 AM
OneRyan's Avatar
Quoted: 8 Post(s)
faulty crank sensor gave me similar issues too
not a terrible fix if you have small hands.. really helps to drop the exhaust
2002 SE7 CDL installed, rear ashcroft locker, 2" OME, custom bumpers, sliders, and safari snorkel on 285's
1990 RR County
-Columbus Oh
OneRyan is offline
post #9 of 12 (permalink) Old 11-01-2014, 03:58 PM
Quoted: 0 Post(s)
Have 99 dico 2....m&s lights comes on and then car shuts off also battery light would come on as well when I first turn it on but it goes away when you step on the gas. So I replaced battery but battery light still comes on when you first turn it on and goes away and she still shuts off but m&s lights don't come on
nricky618 is offline
post #10 of 12 (permalink) Old 09-10-2017, 07:56 PM
audigger's Avatar
Quoted: 0 Post(s)
So true.....If I let my 2002 sit for any length at all and the voltage gets low this will happen. Charge battery for couple hours and goo to go for me...
audigger is offline
post #11 of 12 (permalink) Old 05-03-2019, 04:53 AM
Quoted: 0 Post(s)
M,S and again and battery gets drained
I did this as well, but about a month later it happened all over again. something is draining the battery
Tonycorn68 is offline
post #12 of 12 (permalink) Old 05-03-2019, 05:26 AM
Redrover NC's Avatar
Quoted: 15 Post(s)
Was the truck converted from air springs to coils in the rear? Doing that without disabling the air springs in the BCU can result in a phantom battery drain.
'99 DII, STI wires, Champion 7070s, '04 CDL & SLABS, Garvin WILDERNESS rack, painted headliner, air springs victim, headgaskets at 109,000, plus victim of XYZ (twice) and many other ridiculous DII failures. Option B AMIGO FREE since February 2011.
Runs like a top; now if I could just afford the gas! December 2014 update - Wait, I can afford the gas! Drill baby, drill!!!
Redrover NC is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Manual and sport mode lights flashing DiscoSE03 Discovery Series II 9 03-28-2014 05:29 PM
warning lights, m and s flashing and engine papayyad Discovery Series II 5 07-20-2009 09:15 AM
sport/manual lights and drive indicator flashing worldrover Discovery Series II 7 03-24-2009 07:11 AM
Flashing lights, PLEASE HELP IWANTADISCO Discovery Series II 9 03-30-2008 01:37 PM
Flashing Radio Back Lights skrams Discovery Series II 1 03-06-2007 11:32 AM
You may post new threads
You may post replies
