front driver's window - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 09-28-2018, 11:40 AM Thread Starter
Quoted: 88 Post(s)
Customer (uh, I mean the wife) states window not working.
No sound, no clunk, no buzz.
I am hoping it's the motor or regulator but, that driver's door also has "feature" where the window will not operate with the door open.
Where is the "switch" that tells the the window that the door is open?
In other words, the truck may think the door is open (thus disabling the window) when the door is actually shut.
Could that be a thing? OR am I looking for something that ain't likely there to find?
PS I haven't even looked at it yet, but thought I'd tee this up to get you all's thoughts.
Thanks.
sobieski is offline
post #2 of 10 (permalink) Old 09-28-2018, 12:22 PM
tyl604's Avatar
Quoted: 178 Post(s)
Do all of the other windows work?
tyl604 is offline
post #3 of 10 (permalink) Old 09-28-2018, 12:48 PM Thread Starter
Quoted: 88 Post(s)
Yes. The rest all do work fine.
sobieski is offline
post #4 of 10 (permalink) Old 09-28-2018, 07:13 PM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
Have never heard of a “switch” to not allow the window to operate with the door open and none of my discos have done anything like that. My window will go up and down with the door open🤓
Have never had an issue with window wiring on any of mine
BUT
Have seen lots of other vehicles over the years with damaged/ broken wires in the conduit running into the door ( by the door hinges.
Do any of the other windows not work with the door open????
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #5 of 10 (permalink) Old 09-29-2018, 08:07 AM Thread Starter
Quoted: 88 Post(s)
2004 DII - my understanding is that if the front driver's door is open, then the front driver's window is disabled.
All other windows operated regardless of front driver's door.
Either my truck has a front driver's window glitch that is 100% consistent, I'm crazy (likely anyway), or... but I defer to the "good book":
sobieski is offline
post #6 of 10 (permalink) Old 09-29-2018, 08:18 AM Thread Starter
Quoted: 88 Post(s)
PS when I got home and checked it out, the window worked fine.
I think the Mrs. just wants more quality time with me.
Which is Very understandable - after all, I'm me.
sobieski is offline
post #7 of 10 (permalink) Old 09-30-2018, 05:53 PM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
Now that you point it out I do vaguely recall reading about the modes.
I don’t recall how to change between them and I guess none of mine have been set that way.
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #8 of 10 (permalink) Old 09-30-2018, 09:02 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Yes but that 44 seconds cacelation described in the attachment is effective only after the ignition was off(they forgot to say that there), this setting's purpose is to let the windows/sunroofs to operate 44 seconds with ignition off too in case you left the vehicle and realised within 44 secs that you forgot to close the window or sunroof and be able to close it without turning the ignition on.... as long as the ignition is on the door's status is irrelevant for windows operation, they should work anyway. Also if you didnt alter the setting in the BCU yourself with dedicated tester to that "driver cancel" mode the factory setting is on "all cancel".
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is online now
post #9 of 10 (permalink) Old 10-01-2018, 01:47 PM Thread Starter
Quoted: 88 Post(s)
I believe all of that.
I’m just reporting that my driver front window does not work ( never has ) if that door is open. Which I thought was “normal” but...
sobieski is offline
post #10 of 10 (permalink) Old 10-01-2018, 10:07 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Then most probably it's what @redtruck12 said with the wiring
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Front Driver side window I'm Land Rover Green General Land Rover Discussion 1 08-22-2011 02:53 PM
Wanted: 2001 Discovery 2 front bumper and driver's side window motor mount sharri Land Rover Parts and Vehicles Wanted 4 03-26-2011 03:56 PM
FS Discovery II Window Regulator NEW (front driver) faturbo Land Rover Parts and Accessories 1 11-05-2009 10:26 AM
driver side front window REFERJOHN Discovery Series II 6 10-15-2007 05:31 AM
Help!! Manually roll up front driver side window ajmaravilla Discovery Series II 1 07-11-2005 04:30 PM
You may post new threads
You may post replies
