Front driver window - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
post #16 of 24 (permalink) Old 04-03-2019, 03:52 PM
sierrafery's Avatar
Quoted: 246 Post(s)
There is no ground in that circuit, the motor gets feed from BCU which is reverting polarity for up/down, check for voltage in the motor's connector and if no voltage there then you are 100% it's not the motor and you can rewire it, if you get voltage it's the motor
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #17 of 24 (permalink) Old 04-03-2019, 04:46 PM
redtruck12's Avatar
Quoted: 280 Post(s)
Garage
2 wire motor. Yes it’s control is by the bcm but every circuit requires a path to ground.
Bcm deciding whether wire “A”is power and wire “B” is ground (window up) or wire “A” is ground and wire “B” is power (window down)
Reverse polarity motor correct?
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #18 of 24 (permalink) Old 04-03-2019, 06:21 PM Thread Starter
Quoted: 86 Post(s)
All good discussion points.
Anyway.... the motor in the door works fine w direct power to it.
Thoughts on finding/fixing my “break” between c0459 and the motor?
sobieski is offline
post #19 of 24 (permalink) Old 04-03-2019, 10:32 PM
sierrafery's Avatar
Quoted: 246 Post(s)
As long as you can't see any obvious chaffed wiring by following the loom better rewire that circuit completely unless it's a bad contact in the motor's plug.
that's correct but my statement with ''no ground" was for accuracy as reply to your previous post:
Again if it’s power deal with that, if it’s ground deal with that.
as he can't deal with ground nor with power on that circuit cos AFAIK the term ''ground'' is about a solid connection to body/battery neg lead which in all the circuits/diagrams is black wire.
post #20 of 24 (permalink) Old 04-04-2019, 03:56 AM Thread Starter
Quoted: 86 Post(s)
I’ll test the wiring at the motor plug and work my way “back” toward c0459.
Will report back.
Thx.
sobieski is offline
post #21 of 24 (permalink) Old 04-13-2019, 02:20 PM Thread Starter
Quoted: 86 Post(s)
Broken wire deep inside the wire loom rubber tube between door and footwell.
AND plastic roller on regulator was jenked.
Both fixed.
Appreciate you all, for sure.
Ps. Sierra called this one at the very beginning - thanks Fery.
sobieski is offline
post #22 of 24 (permalink) Old 04-13-2019, 05:17 PM
redtruck12's Avatar
Quoted: 280 Post(s)
Garage
Originally Posted by sierrafery View Post
Can be chaffed wiring where the loom passes between the body and door
Post #3
The King of Electronics
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #23 of 24 (permalink) Old 04-13-2019, 06:32 PM Thread Starter
Quoted: 86 Post(s)
For sure. I second that.
sobieski is offline
post #24 of 24 (permalink) Old 04-14-2019, 12:07 AM
sierrafery's Avatar
Quoted: 246 Post(s)
I feel honoured and i'm glad it's sorted
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Driver seat and driver window not working scottmrau Range Rover P38, Mk III and Range Rover Sport 0 03-15-2019 03:43 PM
Wanted: 2001 Discovery 2 front bumper and driver's side window motor mount sharri Land Rover Parts and Vehicles Wanted 4 03-26-2011 03:56 PM
FS Discovery II Window Regulator NEW (front driver) faturbo Land Rover Parts and Accessories 1 11-05-2009 10:26 AM
driver side front window REFERJOHN Discovery Series II 6 10-15-2007 05:31 AM
Help!! Manually roll up front driver side window ajmaravilla Discovery Series II 1 07-11-2005 04:30 PM
You may post new threads
You may post replies
