Front End Squeal/Squeaking - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 02-26-2015, 06:26 PM Thread Starter
Quoted: 0 Post(s)
When I turn the steering wheel during some slow turns (<20 mph), I get this odd squeaking noise. Almost like metal grinding.
Occurs at the front end, obviously.
Any ideas?
CDAllenInc is offline
post #2 of 4 (permalink) Old 02-27-2015, 03:39 PM
redtruck12's Avatar
Quoted: 283 Post(s)
Garage
Yes. Lots thanks for asking. L.o.l.
Have you checked the front end? Front driveshaft? Front brakes? Fluid levels? Etc. etc.
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #3 of 4 (permalink) Old 03-02-2015, 10:25 AM
'03 Disco SE
Bosnian Discovery's Avatar
Quoted: 12 Post(s)
Can you reproduce it by turning the steering wheel when standing still or does it only make the noise while moving?
Does it only happen when you turn left, right, or either way?
Is it associated with any sort of vibration?
Probably not the driveshaft or brakes as they shouldn't articulate when you turn.
Could be ball joints.
Could be tie rod/drag link.
Could be CV axle.
Could be steering pump.
Could be steering gear box.
Do a visual inspection of all those components. If your ball joints/tie rod/CV boots are torn, any one of those components could be failing and in need of replacement.
Bosnian Discovery is offline
post #4 of 4 (permalink) Old 03-05-2015, 08:18 AM Thread Starter
Quoted: 0 Post(s)
It's probably one of my suspension components like Bosnian mentioned. It occurs when I move the steering wheel. Not sure if it is limited to the truck's movement or not.
Thanks.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Getting a front end alignment jake22si Discovery Series I 5 02-18-2012 01:53 PM
Help with Front end.... usa troy Discovery Series II 2 04-07-2011 11:02 AM
Front end squeal Viggen Discovery Series I 1 09-14-2010 01:41 PM
Squeal / Sqeak in front of D2 engine jfry75 Discovery Series II 1 01-25-2010 04:22 AM
squeaking front wheel.HELP PLEASE wayneus1 Discovery Series II 10 01-16-2008 08:18 PM
You may post new threads
You may post replies
