Head Gaskets & Valve Grinding - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 11 (permalink) Old 09-29-2009, 05:05 AM Thread Starter
Quoted: 0 Post(s)
I have put it off long enough and with winter coming it leak a little more. I received quotes for replacing the head gasket on my 04 Disco which has 71k miles on it. The Land Rover dealership quoted me $2200 to replace the head gasket but a reputable independent Land Rover shop quoted me 3k, the extra $800.00 was to service the valves/lifter etc. I have had the vehicle since 40k and changed the oil every 5k with synthetic and used the Land Rover fuel system conditioner, is there any reason why I should pay more to also get the valves done??? I do plan on keeping this vehicle for well over 100k.
Thanks
2004 DII SE
- 255/55/18 Toyo Open Country A/T
- OME Steering Stabilizer
Drahthaar is offline
post #2 of 11 (permalink) Old 09-29-2009, 05:36 AM
Exploring suburbia for over a decade.
MileHighRover's Avatar
Quoted: 0 Post(s)
Thanks
The valve job is money well spent, just how much to spend is the question.
I shopped around, got a mechanic referal from a LR owner and got the job done for @ $1700, plus everything else I had done. I would look harder for a better price.
MileHighRover is offline
post #3 of 11 (permalink) Old 09-29-2009, 05:44 AM
Administrator
Quoted: 5 Post(s)
First of all, the average head gasket replace on our engine with SAI should run $1550 including parts and fluid except for plug wires, which should be done and possibily resurfacing the heads. Our engines don't need a valve job, if you have been running high octane gas, till you hit 180,000 miles plus.
That being said, go shop around .
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #4 of 11 (permalink) Old 09-29-2009, 06:39 AM Thread Starter
Quoted: 0 Post(s)
Thanks Disco Mike. I had my plug wires replaced at the 60k service and have used high octane gas since I bought it so it sounds like doing the valves would be a waste of money at this point. Anyone know a good service shop in the Minneapolis area.
Thanks again.
2004 DII SE
post #5 of 11 (permalink) Old 09-29-2009, 07:29 AM
Quoted: 0 Post(s)
Thanks again.
DM is right, I wouldn't second guess that.., it would take actually inspecting the heads, valves etc... PAtotoe POtatoe...To the point tho..that quote is waaay to high and the Indy may have been referencing the work necessary to the heads after a HG replacement, that should only run @ $165ish??
Who knows what the previous owner did or didn't do to it...I would only want open heart surgery once...
post #6 of 11 (permalink) Old 09-29-2009, 08:30 AM
WLADiscoII99's Avatar
Quoted: 210 Post(s)
My valves are perfectly clean. Is it ok to use low octane (regular) gas every other fill up to save money on gas?
WLADiscoII99 is offline
post #7 of 11 (permalink) Old 09-29-2009, 08:49 AM
nasa25's Avatar
Quoted: 0 Post(s)
short answer....NO
nasa25 is offline
post #8 of 11 (permalink) Old 09-29-2009, 09:43 AM
rmuller's Avatar
Quoted: 2 Post(s)
Originally Posted by nasa25 View Post
short answer....NO
x2. I was going to write the same thing, but I couldn't manage to get it into a short answer
Run premium. Don't be cheap, you'll end up paying for it 10x over in the long run.
Ryan ::
2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone)
rmuller is offline
post #9 of 11 (permalink) Old 09-29-2009, 09:56 AM
nasa25's Avatar
Quoted: 0 Post(s)
I believe the term penny wise and pound foolish applies here as Rob has stated above.
nasa25 is offline
post #10 of 11 (permalink) Old 09-29-2009, 11:13 AM
Administrator
Quoted: 5 Post(s)
"NEVER", no exceptions unless that is all the station has.
Need Parts?
Lucky8,
post #11 of 11 (permalink) Old 09-29-2009, 02:05 PM
Back in a Series LR after 25 years :-)
slouzon's Avatar
Quoted: 0 Post(s)
I just did mine.
I wasn't leaking coolant, it was oil.
$240 for the complete gasket kit with new head bolts (the good head gaskets).
$238 for a valve job and head resurfacing, I'm not going through all this work to risk valve problems down the road.
$80 to have the injectors cleaned and tested.
$558 total for parts and machine work and about 15 hours of work with the help of my 13 year old son.
We were taking our time as I was spending time teaching him.
I almost did the cam and lifters put after a detailed inspection and checking all the valve lifts were good I left in my originals.
And the rocker arms checked out as well.
I have to say it is a bitch doing a lifted truck.
If I could get the same job done for $1700 I would consider it in the future.
Steve
Steve
Back in a LR after 25 years!!!
71 Series IIa 88
01 D2, 2" lift, CDL. RTE front bumper with 9500# Ramsey winch
"BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time!
slouzon is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Disco2 trouble codes need help! angelfire_Discos Discovery Series II 3 09-29-2009 05:37 AM
97 Disco 1 Head Gaskets LRDMICHELE Discovery Series I 15 03-18-2009 10:17 AM
just did head gaskets and still loosing coolant kkrover Range Rover Classic 4 01-29-2007 08:09 PM
Leaky Head Gaskets 95' LWB 99,000 miles NJRover Range Rover Classic 5 11-18-2006 04:09 AM
Head gaskets on a 4.2L deadboy1977 Range Rover Classic 17 03-20-2006 11:38 AM
You may post new threads
You may post replies
